xt550
Everything posted by xt550
  1. hi my money would be on the friction plates and or clutchh cable. Dave
  2. hi, is the xt 600 cdi the same as the xt 550? if it is the same has anyone got one ? cheers Dave
  3. will give it a try thanks Dave
  4. thanks will check the above Dave
  5. hi the voltage was ok. basically i purchased the bike as a non runner,got it going in about 5 minutes cleaned out carb adjusted the float height,put carb back on then bike wouldnt stat.put a spare coil on still no luck.then after a couple of days i checked for spark which i have had all along and hey presto bike started adjusted tickover mixture bike running lovely.i thenthen put all the bike back together and now it wont start again do you think it could be the cdi ? regards Dave
  6. hi i got my xt 550 running great then taped all my loose wires up and now it wont start again. how do i check the wires from the gen ? or could it be the cdi is there any way of checking ? thanks Dave
  7. xt550 replied to xt550's topic in Yamaha Workshop
    any ideas ?
  8. hi i have just got an xt 550 as a non starter. anyway got the bike going without too much trouble but it will not tick over without the tickover being set to say 1200 rpm if i try to slow it down it just dies,then when i ride the bike it pulls really well up to about 4500 rpm then just dosent want to know. i have cleaned the cartb out it has a new float,spark plug is ok. any ideas thanks Dave took the carb of today just to check put it back on andd now the bike will not start petrol is getting through and i have a spark ?
  9. xt550 posted a topic in Yamaha Workshop
  10. xt550 replied to xt550's topic in Yamaha Workshop
    hi its got a new plug i have checked the carb but will check again. not done a compression test but the bike rides fine ?
  11. hi i have a dt 125 that starts straight away then stalls straight away(will not rev) the headgasket had blown i thought it was that but no,its had new air filter,new plug cleaned out carb and it still will not start properly once its going after about 6 or seven kicks and warms up rides fine and starts fine. cheers Dave
