AMB
YOC Member
Everything posted by AMB
  1. AMB posted a topic in Projects
    I got this little heap and since I have the US custom as a stock bike, this one is getting altered a touch. Stripped it all down and just playing with ideas at the moment.
  2. Stripped the engine out of the bike and put the rest in my new shed. Then I took the engine apart. Judging by all the oil hanging about on the non working side, I think it needs new gaskets and piston rings.
  3. Well it looks like the engine has to come out again and have the head off. Only runs on one cylinder, got spark, got fuel, won't run on the left side. Vlaves are not stuck, so engine out, head off and we need to have a look inside. never mind.
  4. This is what it would have looked like originaly. So the seat,sissy bar, front mudguard and exhausts have been changed.
  5. Fitted rear indicators and finished the wiring yesterday. Everything works which is unusual for me. Waiting for some parts now, so I am off to weld up a lounger frame.
  6. Why is there soooo much wire to squese into the headlamp shell...sheeesh.
  7. Sorted. I had the wiring right, but one bullet conector was not home tight. Re did the join and she fired second kick, BRAAAAAAM!!!!!. bit loud with no silencers...sorry neibhours. ;)
  8. I took pictures of the pirana electronic ignition wiring, but I am still a bit confused. any instructions out there for this. got all the electrics working, just cant get the engine to fire.
  9. My bigger pictures are too big to upload on here. Anyway. Getting on with the wiring and refurb of the instrument binacle. Air filters fitted and the side panels plopped on...for now. Tank temp fitted, waiting for new silencers and chain and sprockets at the moment.
  10. Slowly getting the heap back together. Want to refoam and cover the seat to try and slim it down a touch. Would also like to lower the rear end a touch, that huge gap between the tyre and the mudguard...yuk.
  11. Right, it's time to get back to work. Engine is back in. Wiring, carbs, exhausts,chain, claen and polish to go.
  12. Replaced the front indicators this morning and sorted the speedo. Now tackling the switch gear, kill button was not working and the starter button was missing. Lucky I have loads of spares that came with the bikes. Waiting for front caliper seal kits x two, then I can get the front brakes working. Tony.
  13. Yeah It's a job to be done when the engine is back in the bike.
  14. Morning. The starter motor was not engaging properly so I have taken the alternator cover off for a look see. There apears to me mucho slack in the starter chain, is this normal? I have about 15mm of slack? :( Or shall I just do away with the electric starter altogether.
  15. Wheels cleaned and fitted. Center stand does not seem big enough to hold the bike properly, will fudge it for now with a bit of wood. I expect once the bike is done I will just stick with the side stand and take it off.
  16. Today we have been maily doing. Front forks. Yolks and bearings sorted. Polished up the fork legs and fitted them along with the headlamp brackets. Next job is front mudguard and centre stand, then I can lift it down and fit the wheels. Tony
  17. Started cleaning up and putting bits back on the frame. Not going to be a pristine restoration but a minor refurb. Tony
  18. Swingarm bearings are great, no slop or play in them at all.
  19. Frame being painted. Can't do anything with it now for 48 hours while the paint hardens. Tony.
  20. I ended up using a mixture of petrol/gunk and a stiff brush. Then I pressure washed the whole lot off, then cleaned the fence afterwards. ;) Some rust and a couple of small holes to weld up. Tony.
  21. Oh the black one will be staying stock. This one on the other hand will be tweeked a little. Anyway, I have finished the stripping down. Need to clean all the muck off the frame next, then I can finish the strip and get the frame ready for paint. What degreaser do people use these days. Tony
  22. Todays little jobs. Started stripping aall the rear mudguard off. Then took off the rear shocks, chainguard and took out the rear wheel. If I get a chance tomorrow, the front end will be coming off. Tony
  23. I take loads of pictures and store them on the pc in their own folder. always useful for when the memory plays up on re asembly.
  24. After some tree pruning this morning and a nice coffee and belgium bun, yum yum, I made a start. Crap silencers and down pipes came off, not sure what to do to rectify this mess. But anyway coils came off next, followed by the luminition box and wiring. Then the front crash bars, foot rests, brake and gear lever pedals. Lots of bolts later and some swearing and the engine is out and on the floor. I will continue stripping the frame down when it gets cooler. Tony.
  25. I got 3 spare sets in the bits pile as well.
