Everything posted by Snakebite68
So, I have 'badges'...
I noticed that... lol I'm always late to these things! Damnit!!!
I R Spammer! rofl
Accidently clicked on my name, and it would appear that I have 6 badges... What's all this about then? And how many badges are there? And is there a list??? I want to collect them all!!! lol And I've just been promoted to 'Contributor'!!! Wots all this ere then? 😛
Newbie.
Welcome in. That looks in bloody good condition!
yamaha xvs 125 2003 model electrical starting issue
First job appears to be a new battery. Don't forget to grease the contacts to reduce corrosion too...
What's it arcing 'to'?
Allen Millyard Channel
Just watched that video, I didn't understand a word of it..! Was interesting though! lol
XVS 125 - Mystery Problem..
That's a 7 year old Thread... Your best bet would be to introduce yourself in the New Members Welcome Area... Tell us about yourself and what bikes you have and after a bit of a 'chat', post your problem Thread in a suitable Forum. Don't go straight for the cl*t dude! It's just not done!!!
2014 wr125R Startermotor will not engage
First job would be to remove the starter motor and make sure there's an undamaged cog secured on the end of it...
high beam dt 50
How many switches are there on the left grip? I'm finding pictures that show one or two... If it's two, the right one is on and off, and the left one is low and high. If it's one it's just high & low...
high beam dt 50
There's only so many switches on the handlebars of any bike, if you're not finding a switch that works the high beam, have you checked to see that the bulb is good?
1998 dragstar 650 wiring
Haynes will have it I believe... Yamaha XVS650 & 1100 (Drag Star, V-Star) '97 to '11 (Haynes Service & Repair Manual): Amazon.co.uk: Editors of Haynes Manuals: 9781785212697: Books Google is your friend!
XS850 special Generator
What's that thing in the last picture, and is it meant to be welded solid?
Yamaha FZS 600
You'd be amazed at how you 'mould' into a new bike... It's going to feel large to you for a while, till you relax. I'd see how it goes first before adjusting the ride height, after a couple of months you may find that you can put your feet much flatter than you originally could.
Hello from Cape Town
Welcome in! It looks in pretty good condition...
Xvs dragster 125.... and a newbie
sorry, Alex has a strike on his account if peeps post links to manuals
Rd50mx clutch slip after rebuild, hmm
Almost certainly NOT something you want to attempt, even if you're SURE that there's no real traction going on!!!
One for the technical types.
Not certain I'm going to be able to explain my idea properly, but here goes... A 2 piece spindle... Assuming one fork is threaded and the other isn't: First side slides in the threaded fork and has a thread to match up by the bolt end to engage with the threaded part of the fork. The other side of the spindle slips in as normal. The two parts thread together (don't think it will matter which is male and which is female). So, threaded side in first, tighten up, non threaded side next and screw together. The downside to this is that you will need to torque up BOTH sides separately (and how you'd work that out I don't know lol). P.S. I'm certainly NOT an engineer, and you'd DEFINATELY need an engineer to work out your torque settings. Although, getting a custom spindle made DOES give you the option to go for Titanium or Stainless Steel...
- Kindness of strangers.
XT 125 R carburettor Joint
Intake Manifold Yamaha XT 125 R Enduro Type 3D6 - 1A Japan Quality - Induction | eBay Have you tried google?
Wierdly, it wouldn't be the first time I've had a passenger fall asleep against my back! The bonus with sports bikes is that unless they're restless sleepers, they just kinda stay there, against your back! lol
Newbie in Gloucestershire
Yo! From Yorkshire... I'm sure there's others here from Gloucestershire...
Yamaha 2005 XT125R front brake not holding pressure. Please help!
Aaah, ok, I was wondering because depending on which way you do it, that bubbling out of the threads can cause you problems. Using the leaver or a pressure bleeder isn't bothered by it, but if you use a vacuum bleeder, there's a chance you can actually suck in some air at the end (been there, bit of a bugger!). A bit of thread tape cuts down the problem to the minimum...
No worries. Which way were you doing it?
I've got soggy knackers..!
The seams of mine are internally taped, however, I think I've found the problem, part of the tape is loose. What I need now is some rubber cement! I still want some better waterproofs though.
