Malleus
Everything posted by Malleus
  1. Thanks - I know you guys always say to do it yourself and I admit I didnt out of laziness and lack of time - but in the long run I have wasted more time and should have just got to it myself!
  2. Just an update in case anyone else comes across this thread with a similar issue. Finally got round to getting the fuel tank and air box off this weekend. Synced and cleaned the throttle bodies. Issue resolved immediately - so after 8 months or so and having been in checked by two seperate mechanics (one holding it for over 2 weeks and unable to fix) it was as simple as that. Pretty unbelieveable and slightly peeved as at the second garage, I said on the phone 'have you synced and cleaned the throttle bodies' and was told this would not be the issue and if it was it would have been picked up by the diagnostics (no idea what diagnostic there is outside actually stripping the bike down and attaching a manometer to the throttle body - but hey I am no expert.)
  3. Haha.. at the peak of irritation this did cross my mind! (Also saw a brand new Street Triple for £125 per month which was tempting...) But yea PC sounds like a good idea tbh and my thinking had arrived at a similar point. I am going to run through the basics myself when I have time (which at the moment is never - maybe I can spend Xmas day in the garage!) Then probably look at doing this next year. Was thinking about getting a Yoshimura exhaust fitted, i figure I can justify the expense slightly more having saved on maintenance
  4. Interesting read. I would assume though that vapor lock would occur when the engine is shut down regardless of whether the ignition is still on? Which is not the case here. I will see if fiddling with the killswitch does anything. tbh i never use it and it is always just off with the key. Its such a niggling issue that i have left it for ages. Just made me crap myself a few weeks back when I left the petrol station having to sustain throttle to keep it idling, tried to beat the lights at a junction and whilst shifting down, the engine cut out, leaving me stranded in the middle of the junction (for like 2.5 seconds, but with lights all changing feels longer) I guess one fix is when I turn the ignition off just leave it to cool down. Shouldn't be too hard in this weather!
  5. Hi all, So over the past 6 or so months I have been having an issue starting the bike when it is hot (+80 degrees) This only occurs when warm and when the ignition is turned off fully. If I kill the engine and restart it starts just fine. When it is hot and the power is turned off - the bike will not idle, I can get it to go with some throttle, but this is risky as it will still drop below 1kRPM if this is not maintained. I have had no time to really investigate this myself so finally I thought I would drop it off at motorcycle repair shop. After 1 week and lots of phone calls it is not solved. I have asked them to email over what they have tested and received this: "Just to confirm that the following has been undertaken on your bike. Firstly the battery was fully charged and the spark plugs replaced. After speaking to Yamaha technical they suggested that a number of the bikes temperature sensors be checked to ensure that the temperature differential was correct, this has been completed & no issues found. This results in the bike starting fine when cold and with application of a bit of throttle when warm.At this point Yamaha technical has suggested that the next stage is to strip the bike and investigate the wiring loom. As the bike is now out of warranty this cost would be passed onto yourself, we initially estimate that this investigation could take 3-4hrs minimum which would be charged at £75hr + VAT." - (Plugs were checked and cleaned and battery fully charged when the issue first appeared and I had told them this!) Now I do not want to pay £75 x 4 for possibly no resolution, but looking at forums I did see that some people had luck fixing this with either a throttle body sync or by flashing the ECU with the latest stock version. When I said this to the shop they said 'throttle body sync' would have been picked up with the diagnostic tool and that they 'cannot download the latest ECU from yamaha' anymore. Does this sound right? Does anyone know a dealer in the London area that can reflash the ECU with the latest stock version? Also AFAIK the throttle bodies do not have any diagnostics to detect the vacuum (could be wrong.) So again looks like this was a waste of time and I will have to set some time aside to investigate myself. Any advice appreciated.
  6. Been a while, this made me laugh though - out of curiosity I asked a main dealer in London about costs of replacing brake pads and headstock bearings (Yea I know I should do it myself but I been really busy lately! and am being pretty lazy - I have the parts and my local garage will do the lot for £100) This is their response: "The cost for parts with labour is £457.81 inc VAT." "Do you have a breakdown of how you arrived at £457.81? Off the top of my head; OEM bearings cost £25-35, brake pads cost £15-£30, so if we are saying the top end for parts is £95 and labour cost is £90 ph, - that comes out at 4 hour job?" "The labour is 3 hours with a cost of £75 ph plus VAT PADS £82.32 +VAT In stock BEARINGS £74.19 +VAT in stock" Not sure about anyone here but I have never seen brake pads at £82 or headstock bearings for £74
  7. https://i.imgur.com/8R3L0R2.gifv
  8. Welcome, hopefully you will have better luck with this one, These expensive 125's are big targets, most bikes I hear about being stolen are in this category. (well for every 600cc something or other I hear about 4 or 5 125's going missing.)
  9. Reminds me a bit of a band called Medicine
  10. Just to close this; turns out the negative lead from the battery was oxidised (under the insulation) I assume changing the battery pushed it over the edge somehow. So guess it is a case of adding 2 and 2 and getting 6 really. (or my fault for assuming the error code was accurate!)
  11. Top tip right there!
  12. I don't have one. To be honest I wouldn't know where to put it!
  13. So after testing, the battery does loose charge after 48 hours. Got the mottobat replacement worked great! Now I have a new powersource I figure, why not install some extras. So I removed tank, ran wire from battery underneath/next to tank, out near air scoop and up to handlebars. Test everything, works fine, put everything back together. Great. So before riding I thought I would do an extended test, start up bike with everything on. Sitting for 3-4 mins, shudders to a stop... Now displays error code 12 > malfunction with the crankshaft position sensor. Removed tank, checked connections, checked fuses, removed additional items I installed. Still nothing but fault code. On top of this my alarm went a bit mad, with ignition on it now rearms itself and goes off, after messing about it seems to have stopped working completely! I have flicked through service manual, not had time to test everything, If anyone has any thoughts or initial advice let me know!
  14. My two cents: If it is essentially resetting and performing same actions as when you turn the ignition on, I would guess that a connection to the speedo was loose or corroded. (Maybe check the cable guide is not snagging the wire?) Not sure how that could link to acceleration, unless it is the sudden jolt moving the wire or something. Perhaps as a test turn on the ignition, the go full lock either way a few times and see if this causes the meter to reset? Also maybe a long shot but have you tested the battery (assuming you have no issues starting the bike, so guess it is working correctly!)
  15. Malleus replied to jonny5's topic in Yamabyss
    I think I remember something similar when I was using phone browser, maybe try downloading a diff browser. I think I had to log out/refresh page to make it go away. Some people on here use an app - no idea about that though.
  16. I had always thought these were linked to the 'BikeSafe' scheme run by the police so never really gave it any thought, but just had a look and it does not seem like it.
  17. Nice, I had wanted to add some electrical outputs to the bike. (Though with current battery performance did not seem wise). I have not done it mainly due to my aversion to 'mess' , not really sure where I could run the cables, I think I would have to run them under the fuel tank to come up neatly by the meter.
  18. The lithium battery is being advertised as suitable for MT-09 (actually the only option on sportsbikeshop I think!) so would hope it would work well with the bike. I also have parasitic alarm system, which is why the low capacity of the lithium battery made me wary. I think I may go for the mottobatt, as I am not trying to save weight, it is cheaper and sounds more like it will last when I leave the bike in the garage for 4 weeks. (With the weather now is likely!) I do have the Oxford Optimiser, but occasionally I leave my bike at work for periods, and don't really want to have to leave it attached to a charger. I have started to leave mine connected when at home after last few times of having to quickly charge the battery before leaving the house. It does say in the instructions 'do not use in a garage' but I suppose that may be in-case of fires or if the clips pop off and causes sparks? Once I install the new battery I may add the permanent cables.
  19. I may do a few more tests before splashing out on a new one. From what I can tell if the battery reduces to 75%, the voltage drops enough for the engine to not start up. But I have not ruled out basic things like people bumping the bike whilst it is in the garage and setting of the alarm whilst I am out, also I may have been an idiot and left it in 'Parking' mode. Hard to tell as it does not actually have parking lights (AFAIK) but still drains the battery
  20. What do you hope to achieve by changing the tyres? Perhaps you could get away with an extra 10mm but I doubt much more would be advisable without changing the wheel.
  21. I mean at 188KG weight is not really an issue, but if performance/price is same or better I guess I should go for it. Just wary that there may be other issues I do not know about. Also I noticed battery compartment is currently filled with spacers underneath and at the side, so potentially I could fit a much larger battery? I suppose what I am looking for is a battery which I can just forget about for the next couple of years and leave for up to 4 weeks without any hassle.
  22. So, really I have no idea about batteries. Mine is ~4 years old and after 2-3 days of non-use does not have enough power to start the engine. I have been looking at a few options; Replace with stock battery - Yusa YTZ10S - but it is £100 or so! (CCA:190) Replace with this AGM battery which as I understand will stay charged longer without use. CCA same as stock (CCA:190) but it is only £50. It has 4 terminals, I have no idea why. Replace with this lithium battery. The capacity is half stock (4ah) but CCA is 240 due to some wizardry I don't understand. Also £100. So I know nothing really about batteries, if you have any opinions on each of these (or others) let me know. I am leaning toward the lithium one, mainly because it is blue and has charge indicator LED's
