Everything posted by Simon46
- Project hakka
6v idiot light bulbs to led
I can now confirm that the led idiot light will not illuminate on the flasher cct. So 3w incandescent bulb for that one!
Hello
In the 80s took my new bike for a spin when my parents were at work. No provisional borrowed my mates helmet. Came off it due to inexperience. Destroyed my mates helmet a front rim buckled and tyre marks across my school shirt where it landed on top of me. I cringe now what could have happened. Regards Simon
Bought an eBay batt. Optimiser fitted but the volts are 5.2 under load. I dont think the batts that good. Loom is new charging is good. Need more amps. Neutral light is like something out of bethlehem!
Trying to find every last available mA on this system replaced the neutral bulb which has turned silver again with an RS 209-428 as a test before doing the others. Will have to see what the indicator flasher unit will think of it in due course.
Bike got stolen
What are your thoughts on devices you can text with sim card inside that text back with GPS info should bike be taken?
Dt175mx mikuni choke
Well arrived as promised. Slid back rubber cover slid clip imto slot but got it 180 degrees out and it flew off upwards into boost bottle area. Reading glasses on Telescopic magnet retrieved it then fitted all is good!
Well finally pulled the dt out of the garage to have a look and the clip is missing. So ordered one from fowlers £1.86 plus carriage and vat and hopefully it arrives tomorrow. Ended up with helmet and gear on and went for quick ride. Felt like a new person when I arrived back! Thanks Johnny
A hello and a big problem after engineering work
Been on grampian motors Liverpool who sell mitaka pistons. If your going too far oversized for they recommend a yzr piston. Looks same dome height etc.
Dt125r will only run on choke
I burnt the lips off my brand new gearbox seal in under a week. It was pumping oil everywhere because I forgot to lube it. My bad
Did you fill the seals with grease/oil between the lips?
Dt175mx for 5 grand
You wouldn't want to ride it. Bubble wrap heated garage etc.
Dt175mx for 5 grand
Look on the bay 35 miles on the clock since 1977. Woman bought it and left it at the dealership.
Bike got stolen
So sorry mate. Hope u get it sorted. That makes me angry. Cant imagine what u feel. Regards Simon
Padgetts Robbed over Xmas
Will be widening my followed search on eBay for parts from these bikes. They cant hide. Barstewards!
- Ktm lc4
- Ktm lc4
- Ktm lc4
Grim Up North
Ah now the lecky has gone off.
Grim Up North
Just got up to sun and blue sky.
DT175mx clutch judder and rattle
Unsure yet. Read a post somewhere that if screws/bolts are used they can be higher than rivets so the guy ground the heads lower after tapping threads into basket.
When ive gor time I will drill out the rivets and order the Rd 200 rubbers. Then refit my old basket.
I have the same problem on my 175mx after rebuild. Replaced clutch basket, fitted EBC heavy duty friction plates ball bearing is there, steel plates evenly spaced and lever is set to pip on crankcase. Makes a grrr noise unless clutch lever pulled in slightly and pulling off can end up with front wheel in air from judder. Did you replace clutch bearing on yours? Regards Simon
I love his ichiban moto forkseal replacement toolkit!
- May need help
