mcnamara1710
Everything posted by mcnamara1710
  1. Where the turn arm goes into the unit,it rests on the plastic moving part.the circuit board with 3 wires solder to it snapped in half
  2. Quite hard to get one from the UK the whole unit.I've got my m.o.t in 2 weeks so sods law that it would go now.just wanted a quick. fix but unsure what to buy.hi anyway blackhat
  3. Hi all my indicator switch broke to day so unable to signal at all.have looked at new unit but the nearest one to get is from Indonesia.I have exposed the 3 wires is there something like a switch I could buy for now till I can get it fixed,as the police would pull me for non signal.my bike is a Yamaha Rxs 100 many thanks in advance
  4. Thanks guys will doo cheers
  5. Hi. guys just getting my bike ready for m.o.t.I was told they check back break lens for a reflector.I've checked mine and it didn't have one.is it ok to buy one and stick it on,and if so can I put it anywhere on the back.not sure if this topic should be in bar section.if so sorry in advance
  6. Thanks for the info,if I was to buy this would I be able to get a modern top box to fit on it.many thanks in advance
  7. Hi all does anyone know how I can get hold of a luggage rack for my Yamaha,I'm looking for a modern top box if anyone knows it. would fit this model.otherwise just the original ones.many thanks
  8. Thankyou ever so much mervin for the link,yambits fantastic site loads of parts that I would need for my bike fantastic.also sorry dirty dt for posting wanted in workshop forum.thanks to all you guys.one happy dude from Wales
  9. Hi all I'm looking for a horn button for my Yamaha.have tried my usual site wemoto with no luck.anyone know where I could buy on at all.many thanks in advance
  10. Thanks DT.lot of info there,the oil is new my friend works at a garage near me.don't ask how he got it lol.cheers mate
  11. This one has low ash.and yes mineral.can be diluted with fuel to 50:1 ratio.requirements API tx jaso fb & ISO l egb whatever that means.may give it a go then
  12. Hi all my friend has given me 4 bottles of lawn mower 2 stroke oil which is green in colour.I'm using red 2 stroke oil at the moment.would I be able to use the oil he has given me,or stay with what I know.thanks all
  13. Ok thankyou neo will try that,I am waiting for a Hayes manual for my bike but no sign of it yet.I'm wanting to get to my bulb,but I am unsure how to get to it would you know by any chance Yamaha RSS 100
  14. Ok thanks airhead.will have a look at my switch tomorrow.I have a new bulb,but don't think that's the problem.like I said very dull when I switch to main beam..
  15. Fill77 I will see what happens,but something is wrong as my main beam just glows like a match when I switch it on.can't see anything on the road at all.where I work have to ride 8 miles through lanes so ride always on dip beam.if that ever blew I would be stuffed.as for yellow wire on headlamp will have a go and see what volts are going through hat
  16. I did look a bit hi tec for me i think lol,yes confused with my main beam for sure.i topped up my battery today and charged it up so all good i hope.right you say to check voltage on a connection,tell me how and where to do it and i will and ket you know.very neewbie as you can see sorry guys.
  17. Sorry airhead,will do with levels in my battery top them up.in main beam i havve pointed it at a wall and moves about an inch above dipped beam level.but it is very dull for sure compared to my dipped beam so unsure.but i know these models use dinamo too,when i use dipped beam in idle mode more i rev brighter my beam.also unsure if it is a 12v why when i bought it it didn't blow my bulbs,have looked at my indecator bulbs they are 6v.had no problems when i drove it on 12v at all confused much lol.
  18. Hi airhead yes i have a rectifier just like the one you have posted,it sits on the frame under my tank.this is brand new.the guys on here said to buy a new one.also what you say about battery levels,my battery is 3 months old and have noticed my levels have dipped to min level in that time.when i say my high beam has blown,my main beam is fine but when i turn on my high beam,there is a delay and my high beams comes on but with no effect can't see passed my nose.so back to main beam i go.
  19. I have 6v bulb on it that works fine.just my high beam has gone.what do i have to do ref to the voltage issue guys.when i bought the bike i rode it for 3 wks no problem and when i came to check the battery it was a 12v.i was told to change to 6v as that was the correct battery for the model of bike.
  20. Hi all does anyone know how to get to the main headlamp bulb on a yamaha rxs 100.i am waiting for a hayes manual,but i need to change my bulb as soon as many thanks in advance
  21. Hi all i have a 6v battery on my yamaha,when connected to a volt meter in idle tick over.it reads 8.5 is this correct many thanks.
  22. Airhead and dt rich.thanks for your help,i did what you said rich took 3 attemps but all sorted now thankyou.
  23. Dr rich maybe it could be that,how did you get over that.put it on and check,and if not take off and move slightly and so on was it.
  24. Dr rich maybe it could be that,how did you get over that.put it on and check,and if not take off and move slightly and so on was it.
