carlo
Everything posted by carlo
  1. Hi I had the same prob, I took off the carb, leaving the Y carb boot on the bike, but when it came to putting the carb, back on, it was impossible so I took the carb Y boot off the bike and put it on the carb, (make sure you tighten the retaining clip before re-attaching it, you won't be able to get to itwhen it's on the bike) then put the carb, back on the bike and reattach the Y boot on the cylinders, a bit of a fiddle but managed it. (don't forget to reattach the choke and throttle cables before attaching the carb,) If you do it this way push the carb up into the air intake boot then wiggle into place, and put the bolts back in, be very careful not to break or dislodge the 2 rubber O rings that are set into the Y boot metal face's that attache to the cylinders, if you have some high temp, gasket sealer you may want to put some on the face of the metal parts of the Y boot which attache to the cylinders. Let us know if it worked for you,.
  2. I think i will do that to be syre, might save a lot of time. Cheers
  3. Hi I have what looks like a French reg, doc, not sure as it is in french, but has info, like frame no, year of manufature etc, on it, which is the year 2000, this year ties up with the vin no, as this works out to the year 2000 (0000) also have a green card from Yamaha which has the reg of the bike and yearts 2000 - 2001 with the chaps name on it who bought it new in 2000. Thanks for any help offered getting this reg, here on a UK plate
  4. Hi Would you know what would be diff, when importing a EU bike from France that was first reg, in France in the year 2000. Thanks
  5. My two pennies worth. If the leaking pipe is from the overflow to the tank then you have put too much fuel in the tank, If the leak is from the carb overflow pipe it would sound like you have a prob with the carb not shutting off the fuel when carb bowl is full. it could be the floats or fuel float needle, the floats rise and fall when fuel enters the carb bowl, if they have a hole or crack they will fill with fuel and not operate the fuel needle, the neddle lets fuel in and also stops the fuel entering the carb, bowl, when fuel is used from the bowl the floats lower and let the needle drop and let more fuel in till it reaches the correct level, then the floats rise and they push up the needle which shuts off the fuel again etc etc You need to make sure where the pipe that is leaking fuel connects to, then take it from there.
  6. carlo replied to carlo's topic in Yamaha Workshop
    Hi I only wish you were right, looked at that and it is correct setting, wish it wasn't LOL, have ordered a carb now, but thanks for yur suggestion
  7. carlo replied to carlo's topic in Yamaha Workshop
    Hi Diaphram is new and sits fine, as is all the inside of carb, jets, slide, needle etc, the previous owner put a diff, carb, on it, as I have the old carb, in bits in a bag, but think they put a replacement carb, not new but changed the inside of it with new parts. Have ordered a new carb, and if that don't work I have no idea what it could be. My mate a mechanic had a look at it yesterday and came to the same conclusion as me, in that it can only be something to do with the carb,but thanks for your suggestion.
  8. carlo replied to carlo's topic in Yamaha Workshop
    will do thanks
  9. carlo replied to carlo's topic in Yamaha Workshop
    if you mean the air filter it was a new one put on by the garage of the previous owner and still looks like new and it has oil on it. I think I will go with a new carb, can get a proff, rebuilt carb for £60 so think this will be the easiest and sure way to know. Thanks for your replies
  10. carlo replied to carlo's topic in Yamaha Workshop
    Hi Thanks for your reply. If you read through what I have tried you will see that it is not that simple, the latest, having after done everything inc, stripping and cleaning the carb 5 times, checking filters, new fuel, is as I have said, after removing the aircleaner if I block the air cleaner intake hole with my hand whilst it is ticking over and then I rev the bike as I remove my hand it revs up to the max for 5 seconds then drops back to the normal tickover, did this about a dozen times but if I don't have my hand over it as I rev, it reverts to not being able to rev, just cuts out when you try and rev it. I can't think that it is anything else other than a blockage in the carb somewhere as by blocking the aircleaner intake it is making the mix richer and also causing the carb to poss, suck harder and forcing the mix through the parcial blockage, what do you think? Thanks
  11. carlo replied to carlo's topic in Yamaha Workshop
    Hi All the hoses are ok and I cleaned the filters when i draind the tank. As I said after removing the aircleaner if you block the air cleaner intake hole with my hand whilst it is ticking over and then reving the bike as I remove my hand and it revs up to the max for 5 seconds then drops back to the normal tickover, did this about a dozen times but if I don't have my hand over it and then removing it as I rev it still reverts to not being able to rev, just cuts out when you try and rev it. I can'think that it is anything else other than a blockage in the carb somewhere as by blocking the aircleaner it is making the mix richer and also causing the carb to poss, suck harder and forcing the mix through the parcial blockage, what do you think? Thanks
  12. carlo replied to carlo's topic in Yamaha Workshop
    UPDATE after removing the aircleaner I have just tried blocking the air cleaner intake hole with my hand whilst it is ticking over and then reving the bike as I remove my hand and it revs up to the max for 5 seconds then drops back to the normal tickover, did this about a dozen times but if I don't have my hand over it and then removing it as I rev it still reverts to not being able to rev, just cuts out when you try and rev it. Now this tells me, I may be wrong, it is either a leak at the carb intake or carb manifold or blocked carb, I had it ticking over and sprayed carb cleaner at the carb intake and carb manifold but no increase in rev, so would think thats not the prob, I think it must still be a blocked carb somewhere, can't tink of anything else, any ideas ? Thanks
  13. carlo replied to carlo's topic in Yamaha Workshop
    Hi Thanks for the suggestion but there are no chips, cracks etc to body or inside, I have diagram of carb and have stripped it and cleaned it 4 times with no result. All jets are clear and airways blow freely. after removing the aircleaner I have just tried blocking the air cleaner intake hole with my hand whilst it is ticking over and then reving the bike as I remove my hand and it revs up to the max for 5 seconds then drops back to the normal tickover, did this about a dozen times but it still reverts to not being able to rev, just cuts out when you try and rev it. Now this tells me it is either a leak at the carb intake or carb manifold or blocked carb, I had it ticking over and sprayed carb cleaner at the carb intake and carb manifold but no increase in rev, so would think thats not the prob, I think it must be a blocked carb somewhere, can't tink of anything else, any ideas ? Thanks
  14. carlo replied to carlo's topic in Yamaha Workshop
    Hi Does not have these screens on it, it has a pump to the carb, seems to be plenty of fuel getting to the carb, but I will look at the flow tomorrow, but as the prev, owner had the pump repaced and the carb, I doubt it is that. The garage gave up trying to get it going in the end, after changing the carb, (but the carb does not look brand new outside but all new inside) also changed the fuel pump, air filter, engine boot to carb, boot from carb, to air filter, throttle cable, choke cable, all new fuel hoses. If it's not the carb, or the pump I'm stumped, can't see it wouldbe electrical as have a good spark, both cylinders fire, both get hot, and it starts fine, just won't rev, Thanks
  15. carlo replied to carlo's topic in Yamaha Workshop
    Hi The manifold Y connection is new, also the boot to the airbox, have tried running it with theairbox off and the overflow from crb, disconected, but still the same, ticks over but won'r rev, think I m going to buy a new carb, don't know what else o try now.
  16. carlo posted a topic in Yamaha Workshop
    Hi All Has anyone ever had carb, prob, that what ever they did to it it would still not run prop, and as a last resort put a new carb, on and it worked fine? If you look at my other post of, HELP, you will see every thing I have tried. I'm just thinking as a last resort to spend money on a new carb, but don't want to if it don't solve the prob, can't think what else it could be except the carb, Thanks
  17. carlo replied to carlo's topic in Yamaha Workshop
    nope it is fine, it's like new as the prev, owner had a diff, carb put on it and a fuel pump, just the same as the manifold to engine from carb, and air cleaner like new. Stripped it again today and cleaned every hole I could find in it, all airways clear, jets clear, and guess what, yep it is exactly the same, will tick over but as soon as you try and rev it it will cut out, doing my head in now, really tempted to just buy a new carb, even if it is expensive, I would if I knew it was def, the carb, but it looks fine, don't understand it, never had this much trouble with a carbs in my life, have stripped and repaired a few, inc, 4 carb, blocks, at my wits end now AHHHHHHH Has anyone had this prob, before where whatever they did it would not run and as a last resort they put a new carb on and all was fine?
  18. carlo replied to carlo's topic in Yamaha Workshop
    been there and done that twice, also blown out carb twice with comp, air. I'm only thinking of this as I seen something on youtube with a guy that had the same prob, and he upped the pilot only and it cured the prob, this was after him doing all the usual stuff, ie stripping carb, cleaning jets, jets not being blocked etc etc, I have the old carb, that is in bits that came with the bike and the pilot is 17.5 and looks ok, so will try changing that on it's own. I have noticed that the old carb is diff, to the new carb, in that the choke cable does not connect to the, wheel next to where the throttle cable attaches as it does on the old carb, but it screws into the carb, on one end is normal nipple that connects to the choke lever the other end has a bolt and thread with a spring and kind of plundger, this screws into the side of the carb, never seen this set up before.
  19. carlo replied to carlo's topic in Yamaha Workshop
    wow lemon! to be honest I will try anything now. Will strip it again tomorrow, I really think this is idle jet/pilot jet prob, the hole is really small, smaller than any other carb I have seen, think I will order a largr size, book says the pilot is 17.5 and main 135, so maybe up it 2.5 or 5.0 not sure if I should up the main jet as wellor by how much, any ideas? Thanks
  20. carlo replied to carlo's topic in Yamaha Workshop
    hi do you mean the whole carb or just te jets, don't know of anywhere where they clean a whole carb, and as I said the jets are not blocked when I strip it. What do you think the best stuff to use to soak the carb to clean it, I mean the whole carb not just the jets thanks
  21. carlo replied to carlo's topic in Yamaha Workshop
    Hi It's def, running on 2 cylinders both cylinders red hot
  22. carlo replied to carlo's topic in Yamaha Workshop
    Hi Not sure if it was a new one or not, it has sat for 10 years as he could not get it going.The pet cock is fine and the fuel pump that is pumping the fuel to the carb with no prob, I lso drined the tank and put new fuel in. I have taken the carb off and cleaned it all and the jets twice now, the only diff, is that it will run now on tickover without having the choke on full but you can't rev it, it will cut out. When ticking over and I adjust the pilot screw the revs will increase, but still can't rev it. Every time I strip it the jets are clear, not blocked, thinking now that it's maybe blocked somewhere else other than the jets. Will prob, order a main and pilot jet and se if tha work, maybe jet up with a 17.5 and 145, if that does not work I guess it will be a new carb, Thanks for the suggestions
  23. carlo replied to carlo's topic in Yamaha Workshop
    forgot to add it has a new air filter as well, also does the same thing with the air filter removed. Theres no prob, with the clutch or side stand switch either. Will engage gear when ticking over on the choke (won't start or tick over without the choke out) and will pull away when clutch let out, but without revs as it will cut out if you just twist the throttle a tiny bit. I'm thinking this has to be carb, prob, even though they changed the carb, ay ideas anyone!
  24. carlo posted a topic in Yamaha Workshop
    Can anyone help, I have a virago 125 year 2000 that hassat in a garae for 12 years with only 869 on the clock.. The owner had a prob, ith only running on 1 cylinder so took it to the garage, they changed the carb, the pump and all the hoses, but it was still the same. It will start but only on full choke and then if you rev it it will cut out straight away, will not start with no choke. Have replaced the petrol and battery, and there is no knocking etc, from the engine or smoke, has a good spark on both plugs and comp, is ok on both cylinders. Any ideas anyone Thanks
  25. Hi All Can anybody tell me what size chain should be on the Virago XV 125, year 2000, how many links, pitch etc, Thanks
