finnerz89
YOC Member
Everything posted by finnerz89
  1. Ah OK. Like cynic says you need the meter on it, not sure what you should expect to see signal wise though Sent from my E6553 using Tapatalk
  2. Hmmm. How much tension have you put on the cables? When I first got my DT the PV didn't operate and someone had overtightened the cables. Sent from my E6553 using Tapatalk
  3. Oil on what? Or do you mean in the engine? Sent from my E6553 using Tapatalk
  4. Sounds like you need to adjust the clutch cable Sent from my E6553 using Tapatalk
  5. Any sign of damage to the cable or corrosion on the servo connections? Sent from my E6553 using Tapatalk
  6. finnerz89 replied to Noise's topic in Projects
    Ooooh now I look the look of that exhaust! What make? Or is it a custom jobbie? Sent from my E6553 using Tapatalk
  7. finnerz89 replied to jimmy's topic in The Bar
    Sounds like a great idea to me! Every young lads dream Sent from my E6553 using Tapatalk
  8. How much mileage have you put on it since? Having said that, that looks pretty bad and probably like it for a while Sent from my E6553 using Tapatalk
  9. Woohoo! All sorts of good things happen in pub car parks Sent from my E6553 using Tapatalk
  10. Welcome! I really need to rebuild my DT Sent from my E6553 using Tapatalk
  11. Most likely the clutch, probably just needs adjusting. Also double check your chain is adjusted and in good order. Sent from my E6553 using Tapatalk
  12. Ah right. I don't think you can go wrong with the loobman for the price Sent from my E6553 using Tapatalk
  13. Looks good, only lubricates one side of the chain though! Sent from my E6553 using Tapatalk
  14. I'm just glad Bippo didn't start giving us tips about growing beards.... Sent from my E6553 using Tapatalk
  15. Yeah they're the fuses, in fact one of them is just a spare Sent from my E6553 using Tapatalk
  16. All comes down to quality equipment, inks and aftercare as well though! Sent from my E6553 using Tapatalk
  17. Yeah it's all different. I should hopefully have my first full sleeve finished next month, and then I'll have to even it up and get my other arm done! Haha Sent from my E6553 using Tapatalk
  18. Keep meaning to order me one of those! Sent from my E6553 using Tapatalk
  19. Mine cost £80 an hour.... Sent from my E6553 using Tapatalk
  20. You said it was low on fuel, have you topped that up? Sent from my E6553 using Tapatalk And also make sure your battery is fully charged, simple things first! Sent from my E6553 using Tapatalk
  21. Actually yeah for the past few days. The suzuki is being a pig lol. You'll be pleased to know however I polished the zorsts and they look mint! Lol
  22. I'm looking into automatic oilers now my commute has increased. I've been having to relube it virtually everyday with all this bloody rain! Lol.
  23. Wurth dry chain lube is great. Just not at this time of year. I've taken to just brushing on some gear oil
  24. True. But a change in wattage affects the current and resistance therefore the speed. I probably didn't word that brilliantly but hey ho
  25. That should be fine. Funnily enough it's only the wattage that affects the speed lol
