Everything posted by clynester
DTR 125 intermittent spark problem
Hi , please help!! My son has an 04 DTR 125 and has some problems with an intermittent spark. Things renewed, new spark plug, new cap. The side stand has been disconnected, earth & live terminal On the HT coil pack Cleaned up. Bike started and after 30 mins cut out and would not start due to I think no spark. Does anyone know how to check if there is a live feed from CDI unit to HT coil ( orange wire ) one final thing! Is there anything else I need to check. Thanks in advance for any help / posts. Mark
DTR 125 Power Valve Cables
Hi, thanks for the reply, yes you are right but when looking on the link does not give the info required, I have explained what happens below- When the ignition is turned on the servo moves clockwise then anti, from the PV cable 1 ( shortest ) goes to Servo 1 or to 2 . thanks
Hi, I hope someone would be able to help as getting frustrated with my sons Bike. One of the Long power valve cables snapped. whist taking apart the PV would not move smoothly so I cleaned it and put back together making sure to get the right way round! the problem I have now when the solenoid does its cycle the PV finishes at 3 0 clock position instead of 12 and there for cannot adjust. please could anyone help. thanks
DTR 125
Hi, I hope someone would be able to help me. I have an 06 DTR 125 and the Oil light comes on constantly when the engine is hot, the oil tank is full. I have noticed it seems not to use a lot of oil. could it be a blocked oil pipe? if so what sort of job is it to take apart and clean. Thanks
DTR 125 Rear Tyre
Cheers for all your reply's. The supplier did tell me they are ok for road use.... I'm not to sure. I'm sure you are right, there is some showing off when he is with his mates! could anyone suggest decent road tyres.? Thanks
DTR 125 Rear Tyre
Hi, I am a newbe to the Forum... I hope someone can help. My son has a 55 plate DTR 125, I brought some Dunlop K550's in July this year. He has done about 1650 miles to and from work, no off road and I have noticed that the rear tyre has worn to the wear indicator, the front is like new. Could someone tell me if this is normal and how many miles do you get out of a rear tyre. The garage told me they are only good for 2,000 miles, at £90 a go its not cheap! Thanks Mark
