Gaza-23
Everything posted by Gaza-23
  1. Name: Yamaha YZF600 R Thundercat (1997) Date Added: 23 September 2012 - 12:42 AM Owner: Gaza-23 Short Description: None Provided View Vehicle
  2. Gaza-23 replied to Gaza-23's post in a topic in The Bar
    Hi thanks for all of the replies, i have had the bike looked at and have been told that the output shaft is warped due to heat, i have traded the bike in with the shop as this was too much money to make it worth repairing, and have now got a Yamaha YZF600 R Thundercat. Thanks again for all of the suggestions.
  3. Gaza-23 replied to Gaza-23's post in a topic in The Bar
    Hi thanks for your reply, And ok I will keep that in mind about the intro. I have checked the front sprocket today and it is in good serviceable condition, the chain is new and also lubed and the rear sprocket is good too. when i removed the front sprocket cover, put the bike into 1st gear on the stand... i noticed the noise was actually coming from behind the sprocket, i don't know if the shaft that the sprocket sits on is damaged but it seems to be ok as there is no movement in it and no signs of leaks. The wheel is aligned fine and also spins true. i have a bad feeling that it could be the gearbox on its way out after only 24000 miles. Thanks again.
  4. Gaza-23 posted a post in a topic in The Bar
    Hi i have a 2001 Yamaha fazer 600 which i have only just bought, the problem i am getting is that when i am driving and open the throttle quickly... i get a jerking through the bike as if something is making it hold back. i have replaced the coil packs anlong with the spark plugs so i know it cant be a misfire, it is as if it is coming from the front sprocket area. when i put the bike on the centrestand, and put it into 1st.... the chain seems to jump about and make a horrible noise like a banging. there is also a clicking noise when i spin the rear wheel. i am really stuck for ideas. Thanks.
