jimmy
Everything posted by jimmy
  1. jimmy replied to Variomatic's topic in The Bar
  2. jimmy replied to Variomatic's topic in The Bar
    ..-. ..- -.-. -.- .... .. -- Nod if you want
  3. That must have been why I got the funny looks when I ordered them
  4. You could always buy these spares
  5. jimmy replied to Variomatic's topic in The Bar
    Heading over to Ireland 1999 on my auld XS1100 and I was stowed beside two fellas on brand newish bikes....Look says I we are all T plates (mine '79 theirs 99)...The look of disgust on their faces made me chuckle, as did their (failed) attempts to get away from me between Larne and Enniskillen.... Just sat behind behind them all the way until I cut off and headed up to Ballyshannon
  6. jimmy replied to jimmy's topic in Yamabyss
  7. jimmy posted a topic in Yamabyss
    I'll not get back Looking for a pic, couldn't find it in my 'pictures' so remember that I had posted it on here. Went to my profile, looked in posts and then spent the next 3hrs looking through a load of auld posts. Finally came out with 30 pages still to go......found the pic after about half an hour, but kept trawling
  8. jimmy replied to WillyBeez's topic in The Bar
    Its all downhill from there Seriously, listen to Slice and have a safe happy lifetime on bikes
  9. Two in my house and the whining never stops. The newer model a Y2K version is probably the whiniest As an aside, I was away for my annual medical for work t'other week and after the hearing test the bloke says I have some hearing loss in the higher frequency "that will be the pitch my wife speaks at" says I....Mr Politically Correct was not at all amused
  10. jimmy replied to Jay ybr 125cc's topic in General
    Probably, It's also a waste of time posting the same question in different areas
  11. Hmmm, You sure you never went round it.....just asking like That said, if they have no evidence of you passing the sign on the wrong side of the road, then as advised, fight it
  12. Over here on the bigoted West Coast it was ok to join the Scouts no matter what religion but the BB was for non RCs.....As you say Bud, it's all so wrong
  13. jimmy replied to Toutsuite's topic in Video Section
    Cheers Matey, My type of bikes every day of the week
  14. jimmy replied to Jack R1's topic in Projects
    C'mon Jack, you've kept us hanging around for 10 days now....we need updates
  15. jimmy replied to Variomatic's topic in The Bar
    As Slice states, you may damage the engine casing. If you can cut through the bolt at the inboard side of the frame lugs that will allow you to get the engine in a better position to remove whats left of the bolt Look up Galvanic Corrosion on t'web to get a better idea of what happened
  16. jimmy replied to Spike101uk's topic in The Bar
    It is against the forum rules to post a link to free manual downloads, but they are out there if you look Change the oil and filter, clean / change plugs, drain carbs (try this first before puling them apart) Fresh petrol and away you go. If it is hydraulic brakes, think about changing the fluid. If it is drums, oil the cable inners. Also oil the clutch and throttle cables Ask on here if you need more details
  17. jimmy replied to jimmy's topic in Yamabyss
    I tried to "like" it twice, but couldn't
  18. jimmy replied to jimmy's topic in Yamabyss
    Same old, same old
  19. jimmy posted a topic in Yamabyss
    Nice to see you've shaved your beard off
  20. Nice one bud...Looking through some stuff t'other day, I found my Chief Scouts Award from around 1979. I'll scan it and stick it on Edit......Here it is 1980....
  21. East Coaster, They shared, and John was last on it
  22. jimmy replied to Dee's topic in General
    Take your bike back. Look on ebay and find a set of clocks (ask here if they'll fit if you have no other help) and buy them for about £30. We will give you a step by step guide to switching them over. Same with the ignition switch
  23. Part numbers 9 and 10? https://www.motorcyclespareparts.eu/yamaha-parts/motorcycles/xvs125-dragstar-2004/handle-switch-lever-352522.aspx
  24. jimmy replied to Noise's topic in Projects
    When I was an apprentice, we used to call that type of weld a 'snotter' Did you put slugs in the frame
  25. I have always considered myself Elite.....Although not for the reasons stated above
