jimmy
Everything posted by jimmy
  1. Agree. I always wanted a Triumph Bonnie, an xs1100 and an xt500......I've owned a couple of Bonnies (only because the 1st was stolen.....Bastards....or I would still have that one) an xs11 which lived up to my expectations (including the rubber frame, ah 70s handling!!) but never the xt500....maybe one day
  2. Power of deduction.....His title asked the model of bike, his post mentioned a song. YouTube showed the video....Put it all together and you get a Tiger Cub
  3. Its a Tiger Cub
  4. and no good for an Easter Egg run
  5. jimmy replied to jimmy's topic in Projects
    Are we talking the same conrods....I'm on about the rods connecting the original gear selector and the rear set. I'll measure up the tank length and let you know bud.
  6. jimmy posted a topic in Projects
    Not a Yam, but my auld Speedtwin so delete if offensive to anyone Mrs Jimmy just bought me these for my birthday, albeit she doesn't know that yet. Anyway a few questions for those who have done such things 3mm Stainless or 5mm alloy or what for the plates Where is a good source for the connecting rods and fixings Re:- The tank...Alloy tanks are funny money so thoughts on a decent looking tank (as long as it it single spine, I can fabricate and weld lugs to suit)
  7. Even the thought of potholing scares the shit out of me
  8. As an aside, Alex, can you have a look at my posting in the Forum Help section Forum Issues (17/03/17) Even tho I have managed to delete all cookies, shortcuts and cleared caches this reloading still happens Cheers Jimmy
  9. Awww c'mon, can't anyone help this poor unfortunate one poster who just wants to take take take with no sign of any chance of giving
  10. jimmy posted a topic in The Bar
    Hey Drewps This may be a nice addition to your stable. Right colour, right brand
  11. Yeaaa, I'll organise the T Shirts
  12. Would look forward to it matey. A months notice for work and it would be a go-er
  13. Furry boots mate. I stayed local but got a nice pic or two
  14. That sounds a very good tip mate. Have you thought of numbering each 'hole' so the screws/bolts can be kept in a chronological sequence to aid rebuilding I do the photos on stripdown on just about everything, but usually by the time I get back to it I've either forgot my phone or the battery is flat, so the above would be a wee aid to remembering
  15. I need to ask, What is in the boxes?
  16. Will there be T shirts, bit of deja vu here
  17. Thanx mate, I was unsure whether to post an intro or not but decided to go straight to the problem
  18. DV'd so quite good clearance I tried the forgotten password links and it stated that it had sent the link to my email' but it must have been intercepted by GCHQ or the CIA cos I never received it Edit// Well, I was able to log out, delete all short cuts then log back in. Unfortunately that does not cure the page reloading issue. It doesn't reload on my phone or tablet, and no other page does it on my laptop so it must be an interface issue between my laptop and this forum. Ah well something to bugger about with today before the rugby
  19. Yesterday I tried to access the forum but got the message that work was being carried out. Back from work, forum update complete and access regained. My issue is that now every page I open loads up then reloads which is starting to make me twitch. I'm thinking if I delete all my shortcuts and then open up the forum again this may help but I do not know my password so would be unable to log again (yeahhh I hear some shout) so any chance either Alex or one of the Mods could pm me my password so I can change it
  20. It could be the battery. Put a meter over it to check the battery condition, alternatively If you have breakdown, ride a few miles from your house, call them up and tell them the engine management light is on. They should be able to read the code
  21. You can insure it on a frame number, then MOT it on frame number, then get an age related plate. If you're interested in hanging around for more advice/assistance/patter or whatever, it's probably a good idea to head over to the new members section and post an intro. It has been proven that those who do, receive a lot more of the above
  22. jimmy replied to bippo's topic in The Bar
    Another thread without mention of Yamaha.. Anyway, did I tell you I'm looking for an alloy tank for my auld Triumph if anyone has one
  23. I wouldn't worry too much about the black liquid coming out your exhaust. Does your bike sit outside, if so, does the cover pull all the way over the end of the silencers. With the amount of rain and wind lately, it's probably just water mixed with carbon soot (unless of course you have actually checked it and it is oil) Re: The back wheel. Assuming it is a drum brake, .You need to check the brake is not locked on. Firstly check the pedal moves up and down freely and then look at the brake pivot at the rear wheel/brake plate. You may need to take the wheel off, remove the shoes and pivot. Clean up the pivot with degreaser and fine steel wool, then something like copaslip on it before reassembly If it is a disk brake, then you'll need to check the piston is retracting in the caliper. Over the winter this will attract a load of crud and could cause some corrosion thus preventing the piston from releasing. You can buy an overhaul kit which will include new seals. It may also be the master cylinder again you can buy an overhaul kit for that. Either way, you are only talking a few hours work with minimum outlay (none if it is a drum brake)
  24. Is the bike turning over when you press the starter switch. Have you tried jumping the starter relay
  25. Yes, I looked them up on fleabay after I posted, but couldn't be arsed editing it
