Keiran95
Everything posted by Keiran95
  1. get some cable ties and strap it somewhere if all else fails
  2. i have read up on a website that you will need to up jet to about 10-15% higher than the normal jet size, but its just trial and error with the jets, keep changing them untill it runs sweet
  3. does the kick start feel hard to kick? if its really easy then this could mean theres no compression or very little compression
  4. Nothing atall like yours, my parents have binned the piston now before i could get some pictures, it looked like it had been bubbling on the top of the piston, but it was still running when i went to rebuild it... just with massive lack of power
  5. Keiran95 replied to davyfee's topic in Yamaha Workshop
    Would it be possible for you to post a few pictures of this pipe then it will be easier to try and tell you what the pipe is there for, and if its milky in colour then it means that water has mixed with your oil, get some pictures up
  6. i think someone is having the same problem as you on this forum, take a peek se if it helps you at all http://www.viragotechforum.com/viewtopic.php?t=17248&p=156400
  7. http://www.ebay.co.uk/itm/Custom-LED-Tail-Tidy-Rear-Light-Honda-CBR600-CBR-600-RR-/150794889570?pt=UK_Motorcycle_Parts&hash=item231c136962#ht_6745wt_1154 this any help? i'm sure you could make your own mounting bracket out of somthing
  8. i believe that the piston was running too hot due the head and the barrel leaking, thats what the guy said that rebuilt my engine for me anyway. as you know airhead i only know so much i think i have left the piston in the garage so i'll get a few pics tomorrow, its a right state.. and it seems that as the pwervalve has opened or shut it has tilted the piston slightly and left a small score all the way down it, and the top of the piston that should be smooth is like a crumpet - i was lucky and got it sorted before it smashed into a million pieces
  9. i've no idea if this would work but i am just trying to help, maybe try some exhaust repair putty?? it hardens as you apply heat
  10. why not try the brake disc alarms you can get, you lock it into your disc and ANY movement on the bike and the alarm will sound, http://www.ebay.co.uk/itm/OXFORD-SCREAMER-ATTACK-ACITVATED-ALARM-DISC-LOCK-/280856036358?pt=UK_Motorcycle_Parts&hash=item4164530406#ht_500wt_938
  11. how long should i run the new piston in for???
  12. its definetley not a 250 engine as you can see on the barrel it says, 124cm3 but if you would like to get better eplys from users here its best you introduce yourself first so people know a little about you before they assist help
  13. i will try to provide images soon as possible
  14. i would but i'm a fair trip away
  15. I have recently done a rebuild and i'm not sure i have the cables connected up correctly, could anyone get me a picture of the way there cables come from the side of the barrel all the way upto the actully black box they connect up into, or a video? although i have looked on youtube and none i have come accros havent helped Thanks again
  16. sorry for the late reply, i have been really busy.. i have noticed some scuffs on my old piston and it seems that the power valve has scored the piston. has anyone else had this problem?? Also the piston was in a serious state (looked like a crumpet on the top) i beleive this is because it was running to hot and i had a leak from the head and barrel?? but i'm just wondering if the scuffs on my powervalve is OK and it will run again? but i dont want to ruin my new piston.. any ideas?? thanks for the time and effort please get back to me as i want to do a proper job as the bike is my pride and joy
  17. okay so i have finally got down to having a rebuild but i have made the mistake of not looking up how the powervalve is set up correctly, i'm not sure if i will be able to get it to work again, is it hard? could anyone help me?
  18. i have have a look on the net and the sprocket kits all seem to be cheap crap, could i not just buy a renthal sprocket kit for my bike from somewhere??
  19. Hello all, just wanted to ask if you all if you could reccomend a good setup to have with the front and rear sporckets as my chain decided to jump of and tear both sprockets to bits i would like a blue renthal rear if its possible but i cant really find one anywhere and i'm not sure what other sprockets will fit my bike, thanks for taking the time to read all this, any help is appriciated
  20. That's a new on for me also, will the tdr wheels fit straight on without any changes of forks ect? Because I have been told that the forks on the dt RE are not wide enough for the supermoto wheels?? I just want someone to confirm what sport wheels I can easily fit without much messing about
  21. i have just been told that nsr wheels will fit straight into my bike? before i waste my money can anyone else re-assure me?? thank you
  22. are the baffells removeable form this exhaust as it seems really quiet
