1988 DT125r won't start?
Hi there! Have completely stripped the carb today and found that no fuel was getting into the carb. There was a constant feed out of the tank but I fiddled around with the carb until fuel was running into the carb and after 3 years of it sat doing nothing, it finally burst into life staggered haha!! Thankyou for your help! and a happy christmas to you
Hi I have tried 3 different spark plugs including the old one, and 2 new ones? but this did not work? I have today taken the carb apart and found that there isnt actually any fuel getting into the carb I don't think? Is there an easy way of testing this? Thanks Miles
Sorry my bad it is a kill switch, doesn't start the bike as it is kick start only Sorry Thanks miles
It is just a push button doesn't have a kill switch just a single button. I tried un wiring this to see if this was the cause of the problem but did not make a difference :/ Thanks miles
- 1988 DT125r won't start?
Hi there, just wandered if anyone can help me? I have a 1988 DT125r that has been sat in my garage for 3 years and not run? Now i need to get it going and guess what, it won't go!! I took out the carb and cleaned that thoroughly aswell as cleaning the jets and the float bowl. I then cleaned the air filter out and put carb back in situe. I replaced the throttle cable as it was knackered. I put new gear oil in as a precaution then cleaned the fuel tank out and replaced it with clean petrol and oil. I then cleaned the fuel filter and replaced the entire fuel line aswell. I put a brand knew start button on it but for some reason it wont go!? There is a spark when i kick start it but it will not fire. The other day i tried bump starting it but that didnt work either? Is there anybody that can help me please!? THanks miles - 1988 DT125r won't start?
milesbrunton143
Joined
Last visited
