Preload
Everything posted by Preload
  1. Preload replied to a post in a topic in General
    YAMAHA FS1E-DX DT100 RD250D RD400D XS250 Special XS650 Custom XJ750 Seca FJ1200 XJR1300 FJR1300 RD350B RD400C HONDA CB125S CD175 CD200 CB200 CB250N VT250F CB400N CBX550 CBX750FE Kawasaki AR80 AR125 KH100 KH125 KH250(x9) Z750L Suzuki AP50 GT185 GS550 Other Nippy Norman Scooters Aprilia Ditech Leonardo 125 Habana 125 Yamaha XP500 TMax. That's all I can remember at the moment.
  2. Hi Jakub, It looks like you have fixed your problem.
  3. Scotchbite pads or rotary they will come up like new.
  4. I can see what you are doing Rossonza and it would be cheaper & quicker to remove the 2mm, but it would have to be line bored absolutely bang on, slightly out and it would be scrap, a new axle made out of tougher material would be my fix. On a MotoX bike the bearing carrier is there to spread the load across the axle, they are not fitted generally to road bikes as high impact doesn't happen that often. If you are doing a Supermoto conversion just for road use you should be okay.
  5. Removing 2mm will make it weaker as the outer wall would be obviously thinner so beware.
  6. Preload replied to gaerc's topic in Yamaha Workshop
    Sounds like the carb to me but the only other thing is fit a new spark plug it could be breaking down!
  7. Measure the height & width of both and you'll have your answer. Just make sure the bar diameter is the same.
  8. Your right there Dirty good barrels are tough to find.
  9. I had mine machined as the bore was getting too big. I also reduced the squish while I was doing it.
  10. Preload replied to Daviddahl1993's topic in Classics
    Thats not the one I was thinking of! I'll have a look on the web.. This what thought? https://www.google.co.uk/search?q=yamaha+h3d&espv=2&biw=1206&bih=559&tbm=isch&imgil=8Q6cHVtONYgC1M%253A%253Bhttps%253A%252F%252Fencrypted-tbn0.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcSZ671Z-Q4cJoitxXg-FlTRZMUOTTW9N4KiUHg4mNuSwVTUYgfRjg%253B351%253B326%253BhycgEDwVFKiOiM%253Bhttp%25253A%25252F%25252Fwww.ebay.com%25252Fitm%25252FYamaha-AT90-FS1-G6-G7-L5T-YG1-YG5-YGS1-YJ1-YJ2-YL1-YL2-Rear-Brake-Stop-Switch-JP-%25252F250863916756%25253Fforcev4exp%2525253Dtrue%25252526item%2525253D250863916756%25252526vxp%2525253Dmtr&source=iu&usg=__G6-EPtiwXlX9dqHJzJBobRNaB-A%3D&sa=X&ei=4paJU_eUOYasO8bEgbgL&ved=0CFsQ9QEwAg#facrc=_&imgdii=_&imgrc=8Q6cHVtONYgC1M%253A%3BhycgEDwVFKiOiM%3Bhttp%253A%252F%252Fi86.photobucket.com%252Falbums%252Fk83%252Fcreaterseed%252FMotor%252520Bike%252FYamaha%252F1967YamahaU5D.jpg%3Bhttp%253A%252F%252Fwww.ebay.com%252Fitm%252FYamaha-AT90-FS1-G6-G7-L5T-YG1-YG5-YGS1-YJ1-YJ2-YL1-YL2-Rear-Brake-Stop-Switch-JP-%252F250863916756%253Fforcev4exp%253Dtrue%2526item%253D250863916756%2526vxp%253Dmtr%3B351%3B326
  11. Preload replied to Daviddahl1993's topic in Classics
    I'm not that familiar with the H3D is that the one that looks like a C50?
  12. Soak the piston in diesel or coke first as this can help. I got my RD350B pistons out and that hadn't moved since 1986. PS. Did I mention that I'm totally Jealous.
  13. Do the work yourself after all its only a 2 Stroke or do most of it and save some cash. You'll also know that OEM parts were fitted.
  14. +1 on checking the spokes and also checking the wheels are true.
  15. Yeah been there. That's what make you human and not a robot.
  16. A warm welcome Tomy.
  17. Please say hello and introduce yourself first!
  18. I have the early Morgan mercury gauges which were good, I also have 4 bank of Davida dial gauges I dont use either of these as over 30 years old now. I have used a Twinmax electronic carb & injection syncing unit for 10+ years as its far more accurate, you have to calibrate it everytime so you know its going to be working correctly. I cant recommend it enough. I'm even trying to use it on my RD's which isnt easy.
  19. At lest you can calibrate your gauges off it.
  20. Looking good, can I ask how much they are from Allens as I'm getting low now on Jets?
  21. I've seen worse than that Dutch, I would check the sprocket carrier bearing these can fail and feel like there's grinding sensation.
  22. Going by the last 7 digits I would think there were the same however, the Virago is a twin and the FZR is a 4 so the displacement per piston is different unless the stroke on the Virago about twice as long. I'm assuming your looking at the Virago pistons as you found some cheap.;-) I'm only guessing myself though so its your choice.
