Everything posted by NE0
Removing grips
Come to think of it I used washing up liquid to put the buggers ON!!
Removing grips
you could always wait until it rains hard! Have you ever noticed they always start to move about during a downpour!..well mine do!
Sorry to be a pain lads but....
No way.... My 1976 cb400/4 is NOT fuddy duddy!!! we're seriously going.... here boys!!
DT 175 MX Rebuild/Electrics
Looking at your earlier photos, I see your bike has the round tube swinging arm, so I assume is an early DT175MX i.e 1978-1979 (mines registered 79 but is a 78 model which Paul helped me to understand) However, knowing YOUR luck and that you've got the wrong loom it would be funny if you've got a early swinging arm on a later frame wiring looms for both the round tube and the later square tube are available. i know 'cos I bought one! Yuniparts do the earlier loom for the Earlier round tube 1978 2K4 2K4 = engine/chassis number 2K4-000101 onwards. feb 78 into 79 and it also fits 2X2 = engine/chassis number 2K4-010101 onwards. during 79 only as the wiring diagram is the same in the Haynes manual ISBN 85010 300 3 QH034 click here and Yambits do the later looms 4J4 with the Later square tube. 4J4 = engine/chassis number 2K4-020101 onwards. 1980 to feb 85 click here I purchased mine from Yuniparts, the looms become available periodically or you could email them. I swapped mine only a few weeks ago AFTER my 12v conversion. N.B these ebay Links might be invalid if you're viewing this post after july2011 They only last a few months after they have been active
DT 175 MX Rear carrier/ rack
...and now with GIVI removeable topbox in matching colour scheme!
Hi Phil, I must confess I'm very pleased with my 12v Conversion of my MX. As you've just read it you'll see I've added that I've recently upgraded the headlight to 45w and its clearly a lot brighter, I appreciate its a lot less bright at low speed i.e stopped at the lights, but thats so far not been a problem, Once you're off its bright enough, not as bright as my 400/4 light, but then the diameter of the Hondas headlight is a lot bigger and a few inches lower which clearly makes a difference. I won't be converting the bike back to 6v thats for sure.
Well no luck getting an original, one did come up on ebay recently i did have a bid but it went for a bit more than I wanted to pay (Got a feeling that was you selling paul ) I kept up a fruitless search on ebay, but in the end decided to 'modify' one I purchased a buy it now rack for a Skyteam ST for £12 being black it meant I didn't have to worry about any chrome. I promptly cut off the fixing brackets and set about fabricating a pair of new arms with my MIG welder. Keen eyes will have noticed I also fitted a helmet lock, my DT was missing the original one and on ebay a NOS one was over £50. However, i purchased one for a XS250 for £15 and fabricated a mount for it welded onto one of the arms. A quick respray later and I think it looks ok........what do you think?
DT 175 MX 12volt conversion
(posted earlier) More news.... Still not had to externally recharge the battery which means its still on the original charge. This proves the battery is being charged quite happily on the charging circuit. remember I ride with all the lights on day and night! Anyway, just to let you know I've sourced a 12v 45w/45w bulb same design as the 6v one with the 3 holes in the flange from good ol' ebay. Look for APF Bulb 12v 45/45w its a lot brighter than the 35w, and is at maximum brightness above 3500revs. Not saying it lights up the whole street but an improvement all the same. I've taken off the fiamm air horn as I think the 6volt horn (i never upgraded that part) sounds much louder with 12v supply...don't worry it can cope with it. NE0
Hi from near Brighton.
Hi Stiggy, A warm welcome to you (Suns been shining all day on Brighton) Just along the road myself from Brighton around the Portslade area. If you're into older bikes you might have seen me around on mine
DT 175MX Exhaust Baffle
OMG the producer of the video needs a course in how to edit! Made my eyes go funny, all the chops and repeats, he must be on drugs!!! OR I must be getting old..........
Trouble is I've got nothing to compare it to OG Its not that heavy, must be aluminium, so its likely to be aftermarket. I've not got all the receipts for work done so I don't know when it was replaced. I've seen the wadding available at yambits OG, is one pack enough? does it compress?
OG I can only assume its OEM. The bikes only done 19000 from new and there are many receipts for work done. Exhaust pipe welded on 3 occasions match the 3 small patches on the bend...just where its got a hole now! No mention of a new tail can. The can is a smooth black cylinder with 3 allen screws which hold the end cap on. No numbers visible? The wadding inside just falls apart when pulled. Its oily and black as expected. I've got a spare exhaust chamber for the front to fit on, (needs a gasket and connecting rubber first) I assume replacing the wadding will effect the noise level.... just trying to comply with Mr plod ..........and my neighbours i guess!!!
I was waitng at the lights today and a PC came over and tapped me on the shoulder.. 'ello, ello...your bikes a bit too noisy!! Eh?, I couldn't hear him...my bikes a bit noisy! my helmet helps drown most of it! Anyway, he was alright about it, but he said I ought to get it a bit quieter! So once i got it home I set about having a look...and listen. With my helmet off, clearly it is a bit on the loud side..... However, it doesn't help that the rubber joining the rear can is a bit perished and loose. Plus there's a small hole in the bend by the engine...have to get the welder out! I also discovered the wool inside the rear can is a bit flakey and jet black! Looking on ebay I see you can get replacement baffle wool, and hopefully a new rubber connector. But I also came across decibel killers... Can they be fitted to the DT can? Will repacking the baffle wool cure it on its own? I've not had to worry about this sort of thing before my 400/4 just purrs....
Voltage Regulator help
E stands for EARTH F stands for FIELD I is for IGNITION / LIGHTS Regulators protect lights and stop batteries from frying.
This is a common regulator fitted to many japanese bikes of the 70's My Honda 400/4 has an identical one and so did my other Hondas. It's called a Pointless regulator in that its solid state, no moving parts! The colour code is GREEN for EARTH , WHITE to the ALTERNATOR and BLACK from the LIGHTS Circuit. As long as you connect your EARTH (whatever colour YOURS is) to the GREEN terminal you won't go far wrong. If you're interested it opens and closes rapidly inside which creates a resistance in the alternator field coil thereby reducing its output...stops your lights blowing! Hope this helps.
Engine swap
Or If you're mad..........try this
Just to update you on the success of Project firefly! It's been a month now since I did the conversion. No bulbs blown and there has been no need to externally charge the battery. I ride with the lights ON all the time I've done a total of 190miles, so theres been a constant draw from the battery, including using the indicators all the time (No green laning). The timing and CDI was untouched. Everything works fine......... a worthwhile upgrade to 12volts.
new member intro xs400 new wiring harness and question
Hi Aaron and welcome, I'm sure this is not as uncommon as it appears.... Bikes and cars are all manufactured for different markets. A european bike will likely have a european wiring loom installed, but local variations to indicators and switches will be added to depending on its final destination. I'm sure the US market is similar. It's likely that your bike has a US loom and it would have been suitable for either US or canada etc. yes? If the wire ends in the plug then another plug with different wires connected could be plugged in to complete the bike. You say the diagram shows the wire and is supposed to be like that, but have you checked the wiring diagram for other countries? I bet somewhere you'll find the wire is used. It's easier for Yamaha to fit one loom than have several variants. In terms of japanese efficiency would they have installed the loom and removed the fuse if it wasn't going to be used later, or simply install the common loom and then install the next loom on the next bike and so on, regardless of its final destination? my feeling is its just one of those production issues and nothing more. After all, my car has all the complete wiring for cruise control, but the clutch and brake switches are missing, even though it has the fuse.
How to choose my helmet??
Snap! Mines a wine red one, its a very nice fit and I'm very pleased, I bought mine last year when they had the sale on and it was well under £180...not that you want to hear that! see I told you it was bloody good service...they really are the dogs dangly bits. well recommended. (what colour did you get?)
DT 125 missing part
Good to hear you've got a new MOT on your machine. I therefore assume you sorted all your starting problems out. You started a couple of threads in the workshop area but never finished them off to let us know what the problem was Starting Problem and Overflow problem One thing that really gets my goat on ANY forum is reading threads that never tell the audience how they solved the problem. New members will read posts and think, 'thats whats happening to my bike...." but never find out the actual cause, especially when there are multiple solutions. It only takes a couple of lines... Thanks guys you were right, or nope turned out to be a damaged monkey reciprocating lubricating screw!....or whatever thats it..moan over! Well done for the new MOT
I'm not far from you Jams I too went to bikes and it was the same then, its all to do with them spending time with you sizing you up and then the customer goes off and buys it online cheaper. So its a valid point. I also tried Cissbury leathers just outside of Worthing and Alfs in Worthing both let me try on helmets no problem, but they didn't have the colour I was after. I ended up at Helmet City just the other side of Crawley/M25 area,bit of a drive , but I tied it in with taking the children to the small zoo there. I tell you... bloody good service. Highly recommended. Hundreds of helmets, all colours all sizes and all in stock. Well worth the visit. I got a Shoei raid2 to match the colour of my 400/4.
Yamaha DT 125 Starrting problem
So I guess a 'thank you' would be in order.
Carburettor overflow keeps dripping
Invaribly fuel coming out of the overflow is caused by the float 'stuck' in the down position allowing fuel into the carb from the tank. My 400/4 has 4 carbs and one occasionaly tends to stick after I've stopped. But its a bugger to get at so it will have to wait until they really need to come off! keeping the petrol tap turned off after stopping solves the problem. (it only happened about twice last year hardly regular but I know the cause) In your case stale petrol may well have gummed up the float pivot, or the float axle part. I did say in your previous post cleaning all the fuel lines and ways is essential.I also noted that your earlier problem was caused by I don't think you cleaned it enough. As Paul says don't try correcting problems when its caused somewhere else and often the simplist explanations are the main cause. I think you really need to clean everything inside and out. A carb strip down is just that, you strip it right down to its component parts and clean everything. If there's one bit of crud on the axle pivot the float will stick and you will have problems. Every little nook and cranny needs to be so clean that you'd be confident you could it your dinner off it!!
Expecting a bike to start after a few years of storage is a bit optimistic. Its surprising how the damp penetrates everything and old petrol literally gums up the works! Over time stale petrol will lose its ginger and if left in carbs even for a few months it starts to coat the workings with a shellac type varnish. Its a bugger to get off but cleaning all the fuel lines and ways is essential. Spark plugs seem to absorb damp, and so does the HT side of things. Spraying WD40 over everything does help, but I'm afraid if its been a few years since it last started you've got a bit of work to do. However, stick to it once you've got her all cleaned and dry with new petrol, you stand a better chance of starting the ol' girl....
Part 6 Avoiding the Big bang How to connect it all up Changing over to 12volt is hassle free, There is no need to cut any wires of the original loom, so if you don't like it or you're not happy reverting back to 6volt is easy. Don’t be tempted to install the battery first then turn the lights on! its not a good idea as all your 6volt bulbs won't last very long! Changing all the bulbs is clearly straight forward and obviously should be done first! The indicator flasher unit needs to be replaced along with the bulbs, (I did try seeing what would happen with the 6v one still attached but it flashed far to slowly,) The flasher needs to have the two pins at right angles, and rated at 12v 18w~23w. A suitable one is a universal type WRE04 and comes with the rubber mount. The combined regulator/ rectifier used is from a HONDA C90 cub G model 4 pin version suitable for a late 80’s. bike. SH570-12 / 6.7 011 I mounted mine next to the indicator flasher so the wires from the original rectifier attached directly. The C90 regulator has a separate earth tag so does not need to have the body in direct contact with the frame, so for the moment I just secured it with a couple of cable ties. Once you’ve secured the reg/rec then unplug the old 6v rectifier and plug them into the positions in the diagram. The C90 reg has all 4 Lucar male spade terminals. My old 6v rectifier has a male and a female connector, If you want to keep the option of returning the bike back to 6v, don’t cut the male spade off just make up a short female to female connector to connect the wire from the rectifier to the new one. Disconnect the old 6v regulator and run a new length of wire from that connector in the loom to the New reg/rect as shown. Finally connect another length of wire as an earth lead and find a suitable Earthing point. As I fitted the new reg/rec next to the indicator flasher, the lead can connect to the common earth under the HT coil. The Main headlight will now run off the generator. The rest of the lights and horn will, as before, run off the battery. Only this time it’s 12volt. That's it! Simple! If it doesn't work out for you, you can swap it all back to 6volt. No cut wires. I'll report back on the success of project "Firefly" soon. So far everything works perfectly. Not had to externally recharge the battery. Hope you enjoyed the posting its taken quite a few hours to write it all up. References: Yamaha Haynes workshop manual 210 ISBN185010 3003 Mastering Electronics john Watson ISBN 0333 408233 Hillier's Fundamentals of Automotive Electronics V Hillier ISBN 0748726950 Automobile Electrical and Electronic Systems ISBN: 0750662190 Yamaha club forum, Honda C90 website, Remember this is a 12v conversion for a 1978/79 DT 175 MX UK 2K4 and 2X2 models. I’ve also checked the Haynes wiring Diagrams for UK 4J4 which is compatible. Yours may be different and may require additional research before converting
