NE0
YOC Member
Everything posted by NE0
  1. Good news, all the parts are back at home and all looking the dogsdangly bits in gloss black. 5 parts in all:- swinging arm, chain bracket and tensioner arm, sidestand and brake pedal. £50 the lot. Just waiting on a new chain roller to arrive and I can put it all back together.
  2. Yes Paul you can put me down for a scan, be good to read it. I've also only just noticed but the tank graphics are slightly smaller on Clives restored version. The original coloured panel takes up a lot more of the tank than Clives new decals. Clives before photo has the same tank graphics as mine.
  3. Latest news...the company who's doing the powder coating has mislaid the parts with someonelses order! When i phoned they asked which parts did I bring to them and could i describe them! They took some notes and said they would phone back...that was yesterday, today no phone calls! I'm not over concerned (at present) afterall they have had a finite number of parts since last week and a finite number of customers. Shouldn't be too dificult to trace the parts....one hopes! Plus I guess someone else may be wondering why the swinging arm for a DT175 doesn't fit their Harley!!
  4. Anything and everything is possible!, sometimes you just need a bit ingenuity. You don't mention which year it is so i guess its similar to this one, http://www.2dehands....x-84589864.html As you can see its got a rear rack fitted and if you can get a rack then most top boxes come with universal fitting plates to take a top box. and if you can't find a rack then a rack can be easily modified with the aforementioned ingenuity! I modified a rack for another bike and put a Givi box on it with its universal bracket for my DT
  5. I've been busy recently, swinging arm rerurbishment, new brakes and bearings and I've NOW I've repacked the rear can, and made a video of the process, just got to find some time to edit and upload it.....that won't happen soon, thats a wet weather day!! and the news?................it sounds a lot better now!...and slightly quieter too!!
  6. I'm currently having the swinging arm and some minor parts powder coated to match the frame, I've got new swinging arm bushes and bolts along with new bearings for the wheels and nice new brake shoes. Hopefully have all the parts back by early next week....
  7. We ought to start a 1978 MX appreciation society! I paid £1200 for mine in january and have spent an additional X amount on it since!! Mines got slightly larger graphics on the side panels? I assumed they were genuine but looking at the brochure cover and Clives I see the D and the O centres are blacked in, so I guess mine are replicas... This was before I put on the rack and mudflap a few weeks ago.
  8. NE0 replied to dt1001978's topic in Classics
    Hi welcome to the YOC but you might want to read this post first in the new members section Then pop along to the index and at the very top is the new members section...
  9. You know I didn't even spot that! I must confess I thought the photo on Wemoto was just a stock photo of a barrel.....I'll get me coat! (Fast Show)
  10. well its out.... I tried a bit more local heat then sprayed it with pipe freezer...did that a few times. no luck. tried a bit more brute.....and a brass drift.....no luck. resorted to putting a hack saw through either side of the shock. that removed the shock. Then with a sawn off bolt, a socket, and the vice, I pressed out the offending ends. One side came out with a lot of force on the vice, the other side.....well no way was that going to budge on any of the above methods, I couldn't budge it, put an extension on the vice handle and tightened it then just when i thought I couldn't muster any more strength...BANG! the loud crack of steel and it moved about 4 mm...thats all, after that I just pressed it out in the vice. Paul, there wasn't any special washers either side, just a pair of thin metal flat washers, same diameter as the shaft , no nylon I can only assume the originals were long gone.. Any ideas on a replacement shaft?
  11. hi folks Whilst the frame had been powder coated for some reason the swinging arm was just painted and now its all coming off. I decided then to reburbish my Dt's swinging arm so i've removed it for a proper clean and respray. However, now its detached i think i've discovered why it was never powder coated along with the frame.....the monoshock appears to be well and truly joined at the hip...so to speak! it won't budge. The haynes shows the joining pin as a shaft which should just drift out. I've soaked the pivot in Plus Gas overnight and tried gentle tapping, and I've tried a bit of heat from the 'ol blow lamp and i've tried a bit of brute..not Brut33 mind you!! perhaps I should pour that on it!! I'm fully aware not to burr over the pin otherwise it won't drift out ...but any ideas are welcome....
  12. fear not Paul it would appear that Replacement barrels are available NEW from Wemoto (same page for whatever year you put in) you just gotta find a mere £113
  13. NE0 replied to NE0's topic in The Bar
    Thanks for the offer Paul, but I was hoping to still be able to use them! I don't suppose you can guarantee that they will still work after you beat them?
  14. NE0 replied to Throttled's topic in Naked
    Seems he's got more than one video...
  15. NE0 posted a topic in The Bar
    Having replaced the ignition switch on my bike as you could start it with a screwdriver blade, it was so worn you could start it with the handle end!! I've now got yet another key! I really could do with only ONE key, trouble is I can't see how i can!!! I've now got 5 keys! The original key for the steering lock and another for the helmet lock which is non original. The new one for the ignition switch and one for the top box,plus the chain lock key! I was thinking about getting a locking petrol cap but that means getting yet another key!! making six! Surely I'm not the only ONE? Can anybody beat my set of keys?
  16. NE0 replied to Throttled's topic in Naked
    I've just seen this , sent to me by a friend, I didn't see this original posting. I'm not sure if he's irresponsible or reckless or simply just mad! he's certainly got balls made of steel?...titanium if its stronger! I was always taught to ride on the assumption "treat everyone else on the road as a complete idiot.....that way if they do something unexpected you won't be surprised!" He's obviously got no regard for his own safety or the other drivers! This guy, clearly believes EVERYONE on the road will NOT turn into his path, change lanes unexpectedly or even open a car door.... On the various comments of the video on you tube and elsewhere (where I saw it) it mentions he's doing 87KPH on average (54mph) worryingly he's obviously done it before It does promote the question. Don't they have Police in Moscow? they obviously don't have cameras like we do! having said all that I must confess I find the video strangely addictive, (I could never ride like that) but in a sense you have to admire his ability to make split second decisions,even when there doesn't seem to be any seconds left to decide! then picking his way through the traffic, and fitting his bike through some unbelievably narrow gaps between cars....(especially after the 4 minute mark) This link fills the screen, press play and turn up your speakers!! Worth a watch, but I won't be trying to emulate him......I'd like to live another day or a few more decades yet at least....something i think the black devil will not be doing....... Anyway good music...I think it comes from the Matrix! NE0
  17. German site? I think you're looking at the wrong post, mine was links to ebay for Yuniparts and Yambits wiring looms at £46 mark
  18. NE0 replied to clarke's topic in Yamabyss
    Yup you're not alone, I too was riding to work on my 400/4 when some nameless bastard decided to pull out of a side road across in front of me, I slamned the brakes on and sounded my airhorns....he then shouted out "IMPATIENT C U Next Tuesday"!!! As if i was in the wrong!!!! hope he drops down dead with a massive coronary.....
  19. Nev its a lot cheaper to buy a new one and fit it straight on, see this other thread for details, look for my post on page 2 and the links to ebay should still be valid, but they're under £50 new. thats a £20 saving and that doesn't include your time in making it!! DT175MX Electrics
  20. Well done dave, seems like having cleaned the choke you solved it..... but looking at the thread, pauls first question was.... see he knows his stuff
  21. just my pennys worth..... its not something simple like the engine kill switch being on OR a faulty ignition switch is it? Its just that I purchased a new ignition switch from yambits the other week, fitted it and the bike would NOT start, no matter what I tried. everytime i turned the key to ON it was being grounded, yet everything checked out fine until I turned the key... you can see the culprit arrowed, I simply moved the leg away from the solder and it all worked. I appreciate this seems unique and you are getting a spark, but are you testing the bike one way, and when it comes to actually trying to start it doing something different. if you're confident fuel is getting through, and you've got a spark...... is there anything else which is different........... i.e you're turning the key, setting the kill to off, the fuel tank breather is clear. Is there anything your doing at the time different which is causing the problem. I'm just thinking out aloud here... Are you cranking by hand, or standing to one side of the bike, are you doing anything different which might give you another clue where to look. Are you getting a spark at test start, Perhaps sitting on the bike causes a wire to be under stress and grounding like the kill switch...stuff like that?
  22. yeah but it was a response to a feedline which, you got to admit he did set himself up for it,...I couldn't resist
  23. Each to their own mate!....... If you like the taste of them thats your choice
  24. As I said at the very beginning........
  25. Obviously this thread is about converting a DT175MX, however, the principle will be the same for other 6volt machines with similar layout. The ignition side though, whether CDI or points, is a separate circuit and should be unaffected by any conversion. Remember, this conversion is about changing ALL the bulbs from 6v to 12v & Replacing the 6v flasher for a 12v one.( no need to change the horn) The major parts are the 12 volt battery and replacement of the two 6v parts: the rectifier and regulator and exchanging it for an all in one regulator/rectifier. However, I've had a look at the circuit diagram of the DT100B in my haynes manual and i see there is no regulator and the headlight is run directly off the generator whilst it charges the battery via the rectifier. Therefore its likely that the LIGHTING coil appears to be of low output and only capable of doing these two tasks. it would need a regulator if it was any more powerful. As regards to.. I think you mean the HEADLIGHT is still a 6v bulb but the rest of the bulbs are 12v and THEY all run off the 12v battery (which is charged by the LIGHTING coil) If someones gone to the trouble of changing all the bulbs and battery to 12v, In essence YOU have a 12v bike...but without a regulator I doubt you could fit a 12v headlight bulb.
