realrayzor
Everything posted by realrayzor
  1. With the 80mm gap on ABxv535's bike it would great.
  2. I wish Found it on the big wide web. XV535 with a street fighter look.
  3. Try reading through this chart, very helpful. Sorry i'm not sure how to link it so i just copied it in. Take the time to read through it pretty much goes through all of the electrics. Razor Bike Battery Charging Problems - Troubleshooting & Fixing This procedure can help you find out why your bike battery does not charge correctly, and help you to fix that. This assumes that your bike has a permanent magnet 3 phase generator, a standard thyristor shunt type regulator rectifier (RR unit), and a 12Volt battery. You will need simple workshop tools including a multimeter with clips or an AVO, bits of wire and crimp terminals, a headlamp bulb and a soldering iron. It’s best to start at the beginning of the chart and work through each step in turn until the problem is found and fixed. It is not so unusual to have more than one problem on a bike charging system, and your bike will work better if all the problems are fixed. Please use a GOOD battery. The battery must be fully charged up first, using a bench charger. If not available, maybe you can borrow a charged good battery from another bike. Step 1 - Bike Leakage Current Test Put the battery back on the bike, but connect only the +VE clamp to the battery, leaving the –VE stud not connected. The battery voltage should measure 12V7 to 13V1 across the stud terminals on top of the battery. Measure the LEAKAGE CURRENT of the bike, by setting the meter to DC AMPS,connect one meter probe to battery -VE terminal, connect the other meter probe to the bike harness -VE battery strap / clamp. The current should be no higher than about 50mA (Ignition OFF). Press the brake lever just to check everything is connected okay - the brake light should light, the meter should read about 1A750. Note: 50mA leakage will take a week to flatten a 9Ahour battery. If the LEAKAGE CURRENT is less than 50mA,the bike leakage current is okay,please proceed to Step 2. If LEAKAGE CURRENT exceeds 50mA, there is a fault on the bikes wiring harness, maybe in the alarm. Try pulling fuses to locate the problem.If battery stud voltage remains above 12V4, then the battery is okay, please proceed to Step 3. If battery stud voltage drops below 12V4, the battery is not good and should be replaced. Step 2 - Battery Charge-Holding Test Connect the -VE strap / clamp to the -VE battery terminal, so the battery is fully connected to the bike. The battery voltage should measure 12V7 to 13V1 measured across the stud terminals on top of the battery (ignition switch OFF). Switch on the headlights (ignition ON, engine OFF). Battery stud voltage should drop slowly, maybe down to about 12v4 over a period of 30 seconds. Switch off the headlights and ignition soon. Step 3 - Functional Test of Whole Battery Charging System Complete all connections between the Generator, Regulator Rectifier Unit, Battery - just as normal. Set the meter to show DC VOLTS and connect the meter clips only to the stud terminals directly on top of the battery. The battery voltage should measure between 12V7 to 13V1 with engine OFF. Start up the engine and run at low idle speed. Meter should show battery charging voltage around 14V4 (limits are 13V6 to 14V9) at idle. Increasing engine speed should produce NO proportional increase in battery voltage, but often will produce some small and meaningless variations in voltage. Battery voltage should always remain between 13V6 and 14V9 while charging. Switching the headlight on and off creates big changes in power draw on the generator and battery, which usually results in a slight reduction of battery charging voltage. On older bikes it may be necessary to increase engine speed slightly (maybe 2500RPM) so charging can keep up with the headlight current. Charge voltage between 13V6 and 14V9? Everything is good, battery charges perfectly. Please clean up & go have a beer. Charge voltage >15V? RR is defective, needs to be replaced. Charge voltage <13V5? Please go to step 4. Step 4 - Simple Meter Test for RR (Regulator Rectifier Unit) Disconnect the RR from the bike. Select DIODE test range on the meter. This causes the meter to push out typically 1mA of test current, the display shows the resulting voltage across the test piece. When no test piece is connected the meter output voltage goes higher than about 2 volts so the meter displays “over-range”. Connect the RED meter clip to the BLACK RR wire, and use the BLACK meter probe to test in turn each of the YELLOW wires on the RR. The meter should read between 0V350 and 0V550 for each of the 3 measurements. Connect the BLACK meter clip to the RED RR wire, and use the RED meter probe to test in turn each of the YELLOW wires on the RR. The meter should read between 0V350 and 0V550 for each of the 3 measurements. • Any readings higher than 0V550 indicate an open circuit or bad joint within the RR. • Any readings lower than 0V350 indicate a short circuited rectifier or thyristor within the RR. Although this simple test can never prove an RR is good, it can often show that an RR is defective. All readings >0V350 and <0V550 means no problem evident. Please proceed to Step 5. Any readings <0V350 or >0V550 means RR is defective. RR must be replaced. Step 5 - Generator Leakage Current Test Disconnect the wire harness from the generator stator to the RR (Regulator Rectifier unit). Set the meter to measure OHMS, and probe into the open end of the block connector. Measure the resistance from any of the generator stator wires to the frame ground (battery -VE). A reading of less than about 10kOhms indicates damaged insulation in the stator winding, which often is indicative of a shorted turn fault at engine running temperatures. A reading of greater than 10kOhms does not actually prove the generator is good, but a lower reading always indicates an insulation problem. Leakage resistance >10k, no problem evident. Please proceed to Step 6 Leakage resistance <10k, generator stator is probably defective and should be replaced. Step 6 - Generator Low Power Load Test You shall need to make a special tool for this: Solder about 30cm of wire to the terminals of a spare 55W headlight bulb. Fit suitable crimp tags on the flying ends of these wires to insert into the connector block on the generator stator. Attach the meter clips onto the soldered joints on the end of the headlight bulb. This “bulbtool” allows voltages to be measured while pulling a handy 4 or 5 Amp test current through the headlight bulb. Leave the RR disconnected from the generator. Set the meter to read AC RMS VOLTS. Start up the engine. Connect the bulbtool across any 2 of 3 phase wires from the generator. Measure the AC RMS VOLTS, at low IDLE speed. The voltage should be between 12VACRMS and 15VACRMS. Do NOT blip the throttle or rev up the engine, the bulb can burst with too much voltage applied. Repeat this measurement for each combination of 2 probes on 3 wires, and write down the readings. The readings should all be similar, say 13V21, 13V00, 13V31. If they are different or have any low values, say 13V21, 10V77, 10V82, then this indicates that the generator stator has an internal turnto-turn short circuit and the generator stator must be replaced. The generator connections have to carry very high currents, typically 20Amps or more per phase,and all the time. If replacing terminals or crimps in the shop, these MUST be soldered after crimping. All readings closely similar and within range of 12VACRMS to 15VACRMS shows generator is good. Please proceed to Step 7. Low readings or diverse readings shows generator stator is defective. Generator must be replaced. Step 7 - Load Check of Wiring Between RR and Battery Set the meter to measure DCVolts. Connect one meter probe to the Battery -VE stud. Stick the other meter probe into the back of the connector block on the RR to contact onto the -VE battery charge crimp (normally on the BLACK wire). Start up the engine and rev up to about 4000 RPM. The meter shows the voltage drop “along the wire” in the -VE charging circuit, it should ideally show zero volts. Any reading above about 200mV indicates a defective -VE charging circuit. Switch off engine and reconnect the meter to measure the voltage along the +VE charging circuit. One meter clip on the +VE battery stud, the other meter probe in the back of the connector block on the RR to contact onto the +ve battery charge crimp (normally the RED wire). Start up the engine and rev up to about 4000 RPM. Again, the meter shows the voltage “along the wire” in the +VE charging circuit. Any reading above about 200mV indicates a defective +ve charging circuit. Both readings <200mV indicates good charge circuits. Please go back to Step 3. >200mV indicates bad conduction somewhere between RR and Battery. Please proceed to Step 8. Step 8 - Bypass the Charging Circuit Completely Step 7 is actually pretty difficult to execute, and it is not always conclusive. This Step 8 is a stronger technique, a bit trickier, but absolutely effective in overcoming the same set of problems. Please build and install a special “charging circuit bypass wires”. The Bypass Wires shall bypass the entire bike wire harness between the RR and the battery. The Bypass Wires must have appropriate crimp tags inserted into the connector block of the bikes harness which connects to the connector block of the RR; and M6 ring tags at the other end for connection directly to the battery studs. The wires must be THICK, minimum 2.5 square millimeters (30Amp wire). All crimped tags must also be soldered, there are very heavy currents in these wires. Twisting & taping will absolutely NOT work. It is necessary (for safety) to temporarily disconnect the battery +VE clamp in order to eject both the RED wire terminal and the BLACK wire terminal from the connector block housing on the bike wire harness, where the bike wire harness connects to the RR unit. Tape up the loose tags to ensure they cannot short to each other nor the bike frame before reconnecting the battery +VE clamp. Quick test - start up the engine and monitor the charging voltage directly across the battery stud terminals. Everything looks good? Please go back to step 7 to test fully. If everything works, and the Bypass Wires are all nice and tidy maybe you can leave it just like this Still not charging correctly? RR is defective, and must be replaced.
  4. I like the look of the short shock. If you put the same seat and rear bumper as the bike in the pic it would make it a sweet looking ride. Razor
  5. HI all, finally got the wheel sorted. Brought it into my nearest bike shop and they sorted it. They took off all the spokes and checked the rim, it had a slight inwards kink. The guy said it was right on the point where the rim was joined together??? That worries me a little but he said its as good as new again. I'm gonna collect it this weekend and see how it feels on the bike.. Finally have figured out the paint work so gonna start that this week also. Changing it to a royal blue with silver stripes down the middle of the fenders and tank. Shud be good. Thanks for all your help and suggestions. No doubt i'll be back on again Razor
  6. Can you post a pic. Razor
  7. Shhh don't tell the wives we give the bikes girly names. Welcome Im also a noob who goes around with a silly smile. Razor
  8. That is a scary thought I went tightening the spokes on a bi-cycle one time and wound up with something looking like a pringle.. Woops Razor
  9. From what the oldboy who had it last said, a dog ran out in front of him and he just fell to one side, slid along the ground and slammed into kerb. I'd say the wheel took the brunt. Poor bloke nearly had a heart attack from the fright. Flippin dogs Razor
  10. lol it took me as long to read. Us clare boys aint tha clever . I did check to see if the wheel was true, it is out by a couple of mm on one side. But it really surprises me that it would cause the wheel to shimmer like it does. 1 thing i noticed when driving the bike was when turning right it seems worse. Strange that! I think ill admit defeat and take the wheel into the nearest bike shop and ask them to sort it if they can. Peace Razor
  11. Phew Wee!! I could see myself on that. That should take the wrinkles off my face and leave a smile. Razor
  12. Right,, i did the balance test "Correctly this time" and i reakon the balance is ok. I had to move the weight just one spoke and that gave a good balance. As far as the spokes go,, i don't get the same ping from every spoke when i tap them with a spanner. I suppose the correct sound i'm looking for is a high ping and not do, ray, me, fa, so, la, ti, do. Is tightening the spokes a job a noob like me could try or should i leave this to the experts? If its not the balance or the spokes that's wrong is there something else that i have over looked?? Cheers Guys Razor
  13. Hmmm I like V-Max Razor
  14. OK I'll give that a go again. Razor
  15. Here is my 1st bike, been working on her for a while now. Still got a bit to do. Wanna change to paintwork maybe get some airbrushing, change the pipes, bars etc, etc. I could go on. This is a bike i fell in love with while on a trip in Japan last year. Anyone care to educate me what it is! Razor
  16. Ha lol. I knew i was being a plonker. Right i get ya. I'll try that again tomorrow. But explain to me when i find the heavy spot,, what then?? Thanks again for your help Razor
  17. Update on the wheel is: I took off the wheel and propped it up and spun it. It is very sligthly off through but its hard to think that i could have the shimmer ìt has when driving. I tried doing the test that oldgitonabike suggested and took off the balance weight and spun the wheel to see if it would stop at the same spot. To be honest i could not do it right. The wheel turned too easily and would make about 3 or 4 turns, it was inconclusive. Any other ideas. Thanks Razor
  18. Thanks oldgitonabike, thats a good idea, i'll try that and post the results. Razor
  19. I'll take it off tomorrow and see if it is just the balance. I checked the tyre pressure and it all good. When i run a spanner across the spokes the spoke with the weight on does sound different but that could be because of the balance weight??? Razor
  20. Ha LOL. Thats forks not frocks. I dont have my bike kitted out in a little black dress.
  21. Thanks lads, I'll check out those web sites. The buckle is very small and hard to see with your eye but when you drive the bike you can feel it. Have n't had any look finding a second hand wheel, have been watching ebay like a hawk but no luck.
  22. Thanks, Cant wait to get out on the road proper.
  23. Hello to all on the site. Been reading this forum for a while now and decided to join and add what little knowledge i have. Recently got back into bikes and bought my 1st bike a crashed XV500. BeEN lovin putting her back together and learning all about the mechanics of bikes. Made a few mistakes, put one thingy where another thingy should have been. But thats all part of it. Looking forward to reading more in the site and maybe i might be able to add some thing meself. Cheers Razor
  24. Cheers Mervin, Ya just in the middle of updating the profile and i'll get round to saying hello also. I'm in Ireland. Haven't a clue what sort of business would fix a wire wheel. Would a standard bike shop have someone to do such a thing. Asked a few of my mates who are into bikes but they had no idea. Razor
