Batman
  1. Al it was when i was going and slowed down then went to go again with the throttle, turned out to be carb =]
  2. root of the problem was half red ex, n half carb needed cleaning. to be honest ive had to get my carb cleaned every other month due to coal dust from where i work, now i have a problem of a new spark plug, clean carb but with possible low compression, i am guessing it needs a new piston anybody know a cheap place for piston kits? also what else would i have to change in order to replace piston with a big bore 70cc kit and has anybody got any experience or views on this modification, i.e pros, cons, prices and source's of products. any info much appreciated!
  3. Right i bought my scootay coupel of weeks ago it had a flashing one bars worth of petrol in it and was stood from may, ive changed spark plug, cleaned air filter, gone through 2 full tanks of petrol with red ex in and done around 130 miles. i was told when buying it a week before he had a new piston in not sure if he got head done and it had the clocks reset n i got it at 170 miles, i got it put through its test so it has a years ticket on. right thats the background of the bike. right the problem. ill start it up to go to work and its fine and pokey until about a minute down the road then when i stop to turn ill try to go n it will like bog down n have no revs, then ill switch key off then back on n it generally will pick up n go. other times it will be goin n bog down n then rev to about 20mph n stay there n slowly really slowly pick up to a max of 35 it usually sits at about 35/38mph n generally wont go over that, and website says it will go 45mph but its only ever hit about 42mph once. any help would be much appreciated or any buyers would be better lol please help as im clueless!
  4. anybody with brain matter want to post a more beneficial answer?
  5. Right i bought my scootay coupel of weeks ago it had a flashing one bars worth of petrol in it and was stood from may, ive changed spark plug, cleaned air filter, gone through 2 full tanks of petrol with red ex in and done around 130 miles. i was told when buying it a week before he had a new piston in not sure if he got head done and it had the clocks reset n i got it at 170 miles, i got it put through its test so it has a years ticket on. right thats the background of the bike. right the problem. ill start it up to go to work and its fine and pokey until about a minute down the road then when i stop to turn ill try to go n it will like bog down n have no revs, then ill switch key off then back on n it generally will pick up n go. other times it will be goin n bog down n then rev to about 20mph n stay there n slowly really slowly pick up to a max of 35 it usually sits at about 35/38mph n generally wont go over that, and website says it will go 45mph but its only ever hit about 42mph once. any help would be much appreciated or any buyers would be better lol please help as im clueless!
