slice
YOC Member
Everything posted by slice
  1. slice replied to bippo's topic in The Bar
    Well done Bippo always nice to get a test under your belt.
  2. slice replied to Boner75's topic in General
    Hesitate to say the obvious but have you tried a bike shop? Got to be one near by you and they might know of someone selling their bike, my local one always has a bike for sale board inside and if your not to fussy they can be "INTERESTING" ie the shop wont buy them but someone might! just a thought. plus they might know a local dealer that has a good deal locally. Good luck with your search.
  3. slice replied to Grave's topic in The Bar
    Welcome home Grave, first thing when you get home get your self a deep fried MARS BAR!
  4. slice replied to DirtyDT's topic in Random
    Mike more info than I wanted thank you, now where is that mind bleach??
  5. slice replied to slice's topic in The Bar
    Just for those that kindly answered my query I have found the fault, took the bike out today and all was fine until I had gone about 2 miles then the dreaded misfire came back, been working on it for days and thought I had it pegged but this time I found that the number 4 pot was cold and fiddled with the HT cable and lo and behold found a break in the cable right up under the tank so could not see it until I had my head right up close and there was a damn great spark onto the head bolt, must have worn through some time in the last 30 odd years, so some superglue and a piece of shrink wrap and good as new.
  6. Cynics right cupcake, older bikes are smaller and you get to give an old bike a new lease of life, RD is manic but fun to ride you will kick yourself if you don't try it. And they are still making spares for them so no probs with getting parts or servicing.
  7. slice replied to lallasro's topic in Random
    Ahh now I see it! It would have been better if someone had used the LAMP POST.
  8. Hi Boner., Welcome to the YOC.
  9. Hi Grave, I think you will find that it says, Motorcycles registered AFTER 1st Sept 2001 require a plate on the rear of the vehicle only, now correct me if I'm wrong but any thing past the mid point is the rear and it don't matter if it's to one side or not. I would think that you will have no problem with a side mounted plate as long as it is well TOWARDS the rear. P.S just got this from a mate, The plate MUST be mounted (side mounts) on the right no further forward than the swing arm spindle, but most of this type are for the US market and so are LEFT side mounts but he has NEVER had a problem with it being on the left side nor has he ever been stopped and asked to move it. Hope some of this helps?
  10. Stick with it Fakhir, strip it down and remember label/photo of everything as you go, bits get moved and mixed up so make it easier for yourself from the start. What can't be repaired can be replaced but try to keep as much as possible, surface rust can be taken off with wet and dry and new paint will make it pop, take one job at a time that way you wont be overwhelmed by looking at it as a whole, good luck mate let us know how your doing.
  11. Ok Mervin, how did you get my address book???
  12. slice replied to DirtyDT's topic in Random
    Ok I want all of you to promise DO NOT TELL my wife this!!!
  13. slice replied to slice's topic in The Bar
    Thanks Drewps will fit a new filter today.
  14. Welcome back THAT MAN, glad to have you join in.
  15. slice replied to littlej's topic in The Bar
    Been driving/riding since I was 14 so that's hmmmm! well a long time and NEVER had a ticket, got zapped by a few cameras but nothing from them so assume no cameras in the box, it's not about what you do but where you do it and always being aware of who might be around the next corner. NOISE your sister sounds like a game girl!!!
  16. OK! I have to agree that it is cool and even skilful BUT did not laugh! nor can I see what is wrong with just buying a new stick for his chisel? Don't get me wrong admirable but SNIFF you really need to get out more!!
  17. slice replied to slice's topic in The Bar
    OK thanks all, will drain the tank and check out "FLOATY GUNK" and try new plugs or swap them around and if all else fails swear at it till it stops doing it , that might fail of course but I will feel SO much better afterwards.
  18. slice replied to slice's topic in The Bar
    Thanks lads, It has 4 carbs but just filled it with fuel so not a low fuel problem, new plugs this winter but always a possibility will try swapping them, I was thinking it might be a coil breaking down but it was still firing on the other 3 cylinders and I think it's not possible for only 1 bit of the coil to go bad, not sure about that tho. And NO GROUCH has not been round but maybe I have been cursed with his demon (must stop laughing at his antics), will have another look at it 2moro and see if any of your ideas has an effect. Thanks again.
  19. slice posted a topic in The Bar
    Ok folks if you will do your best to think what this might be I would be obliged. Took the bike out yesterday ran well and had a lot of fun right up till it started to fart and misfire, checked the plugs (ok) checked fuel lines(ok) was stopped on the side of the road swearing at it and it would not start, then out of nowhere it fired right up but not firing on number 4 cylinder. is it possible for one side of the coil pack to break? Fiddled with the HT cable and found it had a spark but still would not fire so decided to ride it home anyway and sod the damage it might do, half a mile down the road it fired up and went like nothing was wrong, the only other thing I had done was turn the fuel tap to reserve!! Oh and when it first behaved badly I had just passed a little sports car at about 80 so was also wondering if coil pack can break down with heat/stress? Any thoughts on what might be the problem would be appreciated as I am stumped, by the way this is NOT the first time it has done this (misfired) but the first time it has actually ground to a halt, first time was on the M5 at a steady 75 for a couple of hours. Thanks all.
  20. Don't tell me YOUR GIRL number 2 Sacha??
  21. I use "GOOP" it comes in 1/2 and 1 pint bottles, use 1/2 pint per wheel, if you get your tyres changed tho you need to tell the guy changing it that you have used it, they get REALLY pissed off if you don't tell them and they get covered in crud, not nice stuff to get off either, water soluble but takes ages to get the little bits of rubber out of all your crevices!!
  22. Hi Pewee, try WEMOTO they do lots of different parts for bikes, you may be lucky and find something on their website that will help you out, otherwise just type in your bike engine type into your web browser and see what comes up! Best I can offer I'm afraid others may have some more ideas. Good luck.
  23. slice replied to mike1949's topic in General
    Finners, if your wife reads that your are in DEEP SHIT!! Happy Birthday Mike 64 just getting your second wind
  24. Andrew, you can't tell what oil you have by dribbling it over your fingers!! unless of course your one really STRANGE lad, the only way is to actually change it to something you KNOW is bike oil, does sound like your cutch is the problem unfortunately but at least you will get to find out something new about your bike. good luck mate should only take a couple of hours to whip it off and have a look then put it all back together. let us know how you get on. PS take PHOTOS of the parts before you take it to bits, its easier than frigging around trying to guess what went where.
