Everything posted by spacemanps
xs360 new headlight
so at night riding my bike is kinda scary bc the light is not too bright... is there any way i can switch to an LED or a higher wattage build or something
1976 xs360 carb intake boots
Thanks, and love the sig! ha and im sure what to call it, but its the piece that connetcs the carbs to the heads...when i look up "xs360 carburetor intake boots" what comes up is the splitter from the air filters to the carbs, thats not what i need... Bike bandit lists it as " JOINT,CARBURETOR" (they r 40 a piece there... hell no) would these fit on my 1976 xs360? (even tho it says for 77 xs400) http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390235575429&_trksid=p2759.l1259#ht_1420wt_883
so i finally figured out what my major problem is... my carburetor intake boots were cracking and they were leaking too much air after the card... sooo now i have covered them with electrical tape for the short time... but i need a place to get reasonably priced new ones... its a 1976 xs360
Convert to switchblade key?
So i recently had to get a new key since i only have one... and the only keychain like thing i had in my house was this lame nautica float thing that came on a pair of shorts i bought i was thinking of how to go about converting my little yamaha key to a switchblade style key... any one have any ideas?
xs360 fast idle? please help... cant figure out...
i went up a bit more than one size but i hope it will end up working out..
bump for input...
temp solution was the 3.5 turn on the low speed mixture screw. But after riding 30 min riding, idle started to be too low.. so when i raised(idle) it the problem came back. guessing i need bigger low speed jets? because 3.5 turns helped a bit but not enough (the rpm would stay high but drop slowly down) Background info- i just changed the stock air box's to pod filters. Current jets: Low- 15 high- 135 Opinion jets needed:?? Low- 20 high-140
okay thanks guys, i will test it out tonight.. keepin my fingers crosses... a friend thought it was the timing advance...
http://www.youtube.com/watch?v=ISzwJeLWlME 1976 Yamaha xs360... if you listen, you will hear the bike idle fine, but once you rev it a little bit, it will keep going and just sit at about 3-4 rpm. You have to use the kill switch to slow it down to a normal idle. Just so you know, its not the throttle cable (checked). thanks for any help!!
XS360 Air filter advice...
So i recent switched to pod filters. I kept the stock splitter thing and attached the pods to that little extension that is connected to the carb. I used the metal neck on the stock air filters to be able to connect the pods to the splitter thing..
1976 XS360 replacement key...
For any one looking for blank keys... i found this site and emailed the guy the 4 digits on my ignition, and he is mailing me a blank key... $9 total with shipping. He said for an extra 10 it will be cut and ready to go when it gets here.. but i can get it cut locally by a friend for free... But he has a HUGE selection of keys.. And he responds VERY quickly to emails and is very helpful.
I decided to just order a set of pod filters (45mm) from ebay someone was selling... 20 bucks.. worked out good. Im going to change my exhaust and do the pods, then see how lean it runs, and depending on that, depends on what jets and to what extent i change it to. (im running rich right now any way... soooo we will see how it ends up..) But thank god i decided to replace a few things on this bike, esp handlebars... the throttle cable was fraying and was holding on by the last 3-4 strands and finally snapped when we were timing the new points... would have been SOL on random day.
There was no page linked... ??? I am planning on connecting the pods to the spliter thing that connects to the carbs.. and a 45mm filter will connect to that (i measured) im thinking i will have to take the carb apart to see what jets i need... well that is after i put the pods on and run into any leaning issues.. im pretty much all stock as well http://www.motorcycle-superstore.com/2/9/427/7841/ITEM/Uni-Air-Filter-Clamp-On-Pod-Filter.aspx?sst=RR|7841 those any good?
he writes that the pod ripped.. im not sure if getting a over sized one would be the best move, but i think i have found some where to get 45mm pod filters... but any one know what size jets are on a stock xs360 carb??
Finding a 2-1 exhaust & exhaust tape
or some sort of 2 pipe collector..
Great find! thanks! but... i have the exhust, i just need the one pipe that will combine the 2..
Wont that be too much gap? 45 vs 54?
You by any chance know off the top of your head what diameter that weird rubber thing is.. i was going to pull the lil metal neck off the filter and put the pod on there and then slip that into the plastic thing.. edit, pretty sure its 45mm.... (guess its a hard filter size to find compared to others)
Have a 76 xs360, i want to find a cheap 2 to 1 pip so i can divert my exhaust out the right side. \/ NOT MY BIKE, JUST AN EXAMPLE!!!! \/ ( something like that, but i would want a different muff and black tape. and where can i find cheap black exhaust tape..?
bump for some help?
XS400 handlebar rubbers same as XS650?
i ordered the ones from mikexs for my 76 xs360... they fit perfect, i verified with bikebandit part numbers that it was the same at the 76 xs650, and they were... im not saying that yours is and will be the same, but consult bikebandit part numbers..
New Guy with Questions
Ive been trying to figure out also what the best, most cost effective way to go about doing the filters are also. Re-jetting actually wont take very long... i just dont know what size jets to get for my 76 xs360... and i just need to order pod filters if i were to go down that path. In my opinion, pod filters look better. Does your bike have the battery in the middle of the 2 air filters? if so what do you plan on doing about that? relocate? or get pods that would not hit the battery and such.
any one with input?!
i hope someone will come alone with pics would be greatly helpfull!
So i was looking at my air filters (r and l) and the previous owner ghetto rigged a new filter with new material and hot glue... So i was thinking is there any one that has seen some sort of mod i can do so i dont have to go buy the stock air filters (which are impossible to find, or realllly expensive) I was thinking of using pot filters and just strapping them to the carbs, but i have that whole battery separating the two air filter gaps. any one got any ideas?
