Everything posted by theslashman
Starter problems dt 125 x
Ive reserved the pulley and am collecting later today, Will try and have a go later today or tomorrow. Think the confusion was caused by me thinking the toothed wheel was the flywheel.Let you know how i get on, Once again thanks.
Its not the parts that are in the picture its the wheel behind with the teeth on thats got the play in it. Im having trouble removing the part on the left of the picture to see what the problem is behind it to see why there is play, Hope you understand and yhanks again for replying. Dave.
Yeah mate the nut infront of the stator housing is solid,Took it off then couldn't get the housing that is infront of the flywheel off to see if there should be any washers that secure the flywheel. What holds the flywheel inplace?
Hi mate thanks for replying,The teeth and battery are ok,Have noticed thar the flywheel has a bit of play in it,Thinking this could cause it not to line up correctly? If so how do you tighten up the flywheel?.
- Starter problems dt 125 x
Please help. Ive got a 2004 dt 125 x and have had problems with the starter. What happens is when i press the start switch either it starts or you just hear the starter turning. sometimes its grinding as if the cogs aren't lined up properley. Have fitted new starter motor and same thing happens. Any suggestion will be greatfully recieved. Many thanks Dave. - Starter problems dt 125 x
