Everything posted by Janie
fsz fazer 600 starting problem
Flat battery definately. Mine does exactly the same thing from time to time when I haven't ridden for a while. A quick tickle with a battery charger always sorts it out. Did have a problem once with it going flat after a couple of days even though it was a brand new battery. Problem was traced to a knackered alarm that was drawing too much juice. Disconnected the alarm and the problem disappeared.
this is bloody awful
I got to 1:03 before....... sick as a dog..... gonna vom.......
'98 FZS 600 Misfire
Got a new clutch on order from Fleabay so that'll be going in as soon as it arrives, and yes you're right, Alan is now deputy editor of Superbike magazine.
'98 FZS 600 Misfire
Hi Tone, Yeah it's bike specific oil from my local bike shop and the freeplay at the lever end is set right. I've had the bike for a number of years now and before that it was owned by a guy called Alan Dowds who at the time used to be road test editor for Ride magazine, and I've got various pictures of it being used and abused by members of the editorial staff. The fact the clutch has lasted this long is a minor miracle given the amount of time the bike spent on it's back wheel while under the "care" of the Magazine staff lol.
'98 FZS 600 Misfire
Big up to everyone who suggested stuff but special hugs go to the YPVS TONE massive Drained the float bowls.... Went for a ride....... misfire gone. How chuffed am I :D On my journey though I did discover that now it doesn't misfire when you whack the throttle open....the clutch slips instead Ahh well, on with the overalls and out with the toolbox again. At least this is a straightforward job.
Foamy has a new ride!
I hope you have as much fun on her as I did Steve. There's a lot of good memories that go with that bike and I know she's gone to a good home. Me and the old gal go a long way so be kind to her and she'll give you as many smiles as she did to me Well done Stevie
'98 FZS 600 Misfire
Taking the tank off and rigging a remote fuel supply is no problem. 2 allen headed bolts, a fuel pipe and a multi plug for the fuel gauge and the it's off. I wondered about seeing the sliders moving myself so had a look in the Haynes manual to see what was involved in removing the airbox. The first sentence reads........ 1. Remove engine... I stopped reading at that point I need to get this sorted soon as all this messing with oily bits is ruining my nails
'98 FZS 600 Misfire
Right lets answer these one at a time The bike doesn't have a vac tap on the tank, the carbs are fed via an electric fuel pump and there's no Scottoiler so the fault's not there. The carbs were balanced about 2 weeks ago when the fault reared it head. I've been told by one or two people that an air leak might be the cause so when it decides to stop damn raining I'll have a look at that too. Someone also suggested that one of the sliders in one of the carbs might be sticking when i wack the throttle open. Have no idea which cylinder it is that dies but we've swapped the coils over just incase there was a fault there and the misfire feels the same whichever way we wire them up. All these suggestions are really appreciated guys and I'll keep you posted as to what we find.
'98 FZS 600 Misfire
I wondered that myself but the bike has a brand new battery on it and the charging system is pushing 13+volts into it when the engine is running. My fella has gone over the entire ignition system with a multimeter checking resistances, continuinty etc and looking for faulty wiring but found everything to be in perfect order. The only real anomaly was the resistance in the plug caps. This is quoted in the manual as 10K-Ohms @20c. We got figures ranging from 9.1 to 12.4. or there abouts. Not sure if this would have a discernable effect on the spark or whether the values are within tolerance for the bike as no +/- figures were given in the manual.
'98 FZS 600 Misfire
Cheers Tony, I'll try that tomorrow
'98 FZS 600 Misfire
My '98 FZS 600 has developed a bit of a strange misfire. From cold it starts, runs and pulls just fine. After just a couple of miles if you crack the throttle open suddenly it loses a cylinder. Backing the throttle off brings the cylinder back online. If you then roll the throttle on gently it will accelerate as clean as a whistle all the way up to silly revs and speeds (Honest officer, I was just trying to trace a fault ) Changed the plugs just incase I'd got one breaking down under pressure but to no avail. Re-calibrated the TPS because that was out and the problem seemed to go away for a little while but now it's back with avengance. Had the tops off all of the carbs to check for damaged diaphragms or bent needles. The bike was rejetted when the stainless race system was fitted but the problem exists whether I've got my standard can or race can on so gawd knows. Any suggestions would be greatly received. Thanks Janie
weres foamy
Hey Foamy, My stepson is starting on Sept 16th. He's absolutely stoked about it and can't wait to start. If you're there when he is I'm sure the 2 of you will bump into one another at sometime. Anyway good luck and hope things are going well for ya
Hello! Newbie pls help! ;)
OOhhhh another girlie biker ..... Helloooooo Bex and welcome to the forum
Cleaning the chain.
[reminiscing music] I used to have a Beetle. Gorgeous she was, called her Bluebelle. A 1972 1300cc, so low she used to ground out over speed humps. We went to Tatton park vw show once and got stuck on a hump in the field LOL. [/reminiscing music] We've got a VW camper now, same year but him indoors has stuffed a 2.2 subaru engine up it's back end and made it stupidly fast....... Oh sorry, off topic. I'll be quiet now
Cleaning the chain.
OOhh a proper beetle or one of these new fangled watercooled wanna be thing-a-me bobs?
Cleaning the chain.
- Allow me to introduce myself!!
Hello Steve and- Just back from Greece
Thanks Mike (or should I say efxaristo ) We always have a great time on the island. Our holidays have turned into trips to see friends as we seem to spend most of the time driving or riding round to see people we know as we've made a few very good friends out there. There's one girl who lives in Patras who always pops over on the ferry to stay with us for one or two nights. I love Greece with a passion and can't wait until I can call it home. The road users aren't that bad on Zakynthos.......... actually I'm talking crap. They scare the hell out of me which is why if it's got more than 2 wheels I make him drive me around. I'm ok on a bike over there because I can dodge out of the way but driving anything bigger is a big no no for me MUST............RESIST............URGE...........TO...........COMMENT........... ..- Just back from Greece
No grey.....? Oh if only that were true LOL Yes we found that out. Handy little things and great places to store bits and pieces too- Just back from Greece
Yes Dan I know what you mean, It's absolutely gorgeous. Oh and Young Mr Foamy... Yes of course it's my natural colour. Are you insinuating that I dye my hair to hide the grey- Just back from Greece
It's Zakynthos. The picture was taken on the coast road as you head up north and you can just see the salt flats at Alykes in the background. Yes Peter you are right. I'm lucky I didn't get pulled over by the Greek police and booked for that one- Make your own WD40 !
I just clicked out of curiosity.......... Honest- Just back from Greece
Just got back from a lovely week in the Greek islands. While I was there they gave me one of these to gallop around the island on As you can see I'm wearing all the regulation Greek safety gear so in the event of an accident I'd be completely protected- New member
- New member
No foamy, mentioning no names at all....... nudge nudge ;) - Allow me to introduce myself!!
