Everything posted by DirtyDT
Hi im new here
Hi and welcome to the forum.
Tesco Dating Agency
Jorian Ponomareff _Drift
I see they have changed the CBT again. At least they kept the figure of eight in it.
- Introduce a 30yr road tax exemption - e-petition
Yamaha dt 125 head warped 1992
Oh, hello!
- Hi
Hi from the Bahamas
Hi and welcome to the forum. Can you send us some sun please.
- 2 replies
- Aerox 50
- Spain
- The Bahamas
- No idea
Tagged with:
Hello Peoples :)
Hi?
Hi and welcome to the forum. Love your tea, by the way!!
Hello!
Hi guys!
Hello!
fz750 genesis
At least you are getting somewhere. It could be the relay. I hope guess you have checked; The engine run button was set to on. The clutch was pulled in (not sure if it applies to this model but some bikes need the clutch in and in neutral to start them) You should, with the ignition off, undo the starter motor +ve connector, Put a tester to this and earth, turn on the ignition and push the starter. If you get a voltage reading then it could be the starter or starter isn't earthed. If you get nothing then it is further up the chain between the starter and the battery, check the smaller fuses also as there could be one for the starter as well as the main fuse. You could also run a thick wire from the battery +ve to the starter +ve terminal to see if it spins.Wires can get hot, melt and burn. I would do this with a jump lead. Only do these tests if you are confident you know what you are doing. and touching anthing from the +ve side to the frame or earth is NOT a good idea.
Where are you in the 7 billion population?
http://www.bbc.co.uk/news/world-15391515
fz750 genesis
No worries One fundamental question I didn't ask is; have you ever had it running or had the lights come on? If you haven't then the worry is someone has er........................ attempted to fix it already. If you have then this part should be pretty simple. Another check is that the battery earth is actually earthing. There are a few wiring diagrams around on Tinterweb. You may have to zoom in to this one. http://i40.photobuck...02/DSCF0026.jpg
fz750 genesis
If you have no power to anywhere then it should only be something that stops more than one thing from working. A dodgy rectifier etc. wont do this as the lights will come on. Get a multimeter - or a bulb connected to 2 wires like an old indicator and test the electrical circuit from the battery. Always from the +ve of the battery to; Battery to frame earth Battery to main fuse, before fuse battery to main fuse, after fuse Battery to fuse box Etc. Make sure the ignition is on, although some of the tests do not need this. If you have no power to anything I would be surprised if it was as far from the battery to the fuse box as it will split past this so you would have power to something.
Long time reader
Pretty Pi$$ poor first post in my opinion.!!
fz750 genesis
Assuming the battery is charged and fitted correctly, main fuse?
new prototype I made yesterday
So from the biggest issue being "awareness for bikers", you have decided that bikers should do more! This obviously means more expense for us. Plus it will then probably be made compulsory, be part of the MOT and we would get points if the batteries ran out part way through a ride for "failure to comply". I do not consider it being a good idea, whether it was retro or designed in. I have seen these on cyclists helmets. A retro fit would have to not disturb the integrity of the helmet. Not really an engineering project. Easily knocked up with a medium set of Meccano or Lego Tecnik. Also, one of the beauty's of expensive helmets is that they are light. Not sure what a battery pack would do for that feature. If the answer to drivers being more aware of bikers is lights, then add the lights to the bike. This solves the majority of issues with a helmet light! Give everyone involved in an accident a minimum of 3 points and £100 fine, this would also help the economy. Can you design a bikers disintegration ray gun to blast anyone who pulls out on us?
And So It Begins,,,,, Mini Bike
Looks in focus to me..................................................................... A good little project 2wheels. I am not sure you are going to get all of your stuff on it for Squires though!!
What SPARES do you keep in stock?
Too many, but not as many as OG!! Good find BTW OG.
Happy Birthday Kishan
I will second that Drewps. Have a great birthday.
xj600 pre, carbs
The floats not working, the float needles not closing or the float heights too high, normally.
- Link Sugestion
Sorting out DT 125 ignition.
Put some fuel in it and see what happens. Don't forget to make sure the 2 stroke oil is in it and the oil pump has been bled.
