DirtyDT
Everything posted by DirtyDT
  1. DirtyDT replied to Norcot's topic in The Bar
    Nothing wrong with an SV. Bargains to be had too.
  2. DirtyDT replied to anzimazor's topic in Projects
    That's the cc (engine size) marking fella. Lets get the engine id sorted first. I am on my phone so can't post up what to look for but search around the engine, the gearbox part. And there will be a flat surface with a number stamped on it. Don't panic yet . I couldn't find the engine number on. One of my bikes to start with.
  3. DirtyDT replied to anzimazor's topic in Projects
    I could be wrong by the way but that is what I get for an engine number starting 24X. It cant be a 24X because the sprocket is on the right of the engine on those, I think, and in your pics, the chain is on the left.
  4. DirtyDT replied to anzimazor's topic in Projects
    Frame number looks right for a DT125 LC '87 English. The engine number - 24X - looks like a YZ125K '84 according to my list.
  5. DirtyDT replied to anzimazor's topic in Projects
    They are normally different. Post up the first numbers and letters of each - not the whole numbers, leave the last 3 off. 35A - 025*** Something like this?
  6. Sorry I spoke.
  7. DirtyDT replied to anzimazor's topic in Projects
    Frame number should be on the headstock. This will be where the forks are. there should be a fat tube that is part of the frame inbetween the forks. The frame number will be here, stamped downwards. The engine numbers vary but are often on the left of the bike engine at the top. There should be a flat part, with raised groves along it and the number should be stamped there.
  8. Depends what you want really.
  9. I have a '88 DT125R as having a 125 MJ.
  10. DirtyDT replied to anzimazor's topic in Projects
    Brake pads - see how much is left on the metal part of the pads. Normally you can look through to see a grove in the linings. Bearings - see if you can wiggle the parts. Wheels, swing arm and forks. Fluids - Make sure it has some and how clean it is. Engine oil, 2 stroke oil and brake fluid. Best to change all of these anyway. Chain - Slowly spin the rear wheel and check the play in the chain at the midway point between the front and rear sprockets (up and down). If it is about the same then this is a good sign. Also look at the rear sprocket for any teeth that are starting to get sharp or are twisting at their points. The area that the chain fits into should be circular, not an elongated crescent shape. Look for any leaks anywhere. Check the oil pump is working Check the colour of the spark plug I don't know what the bikes value is, it depends on too many factors and isn't my "cup of tea" but I would guess that £600 is OK for a fully legal DT of this age if not on a insurance register and with the original engine.
  11. DirtyDT replied to anzimazor's topic in Projects
    The first thing I would do is check everything to do with the safe riding of it. Brake pads, chain, sprockets, tyres, bearings etc. Then oils and fluids. Then engine then cosmetics. Pointless having a shiny DEP if the engine has blown up or the brakes don't stop the bike. As for the swing arm and plastics, the swing arm has to come off to do a decent job and the plastics need to be rubbed down and primed with plastic primer to get a good finish. Looks like there is some red paint showing through the blue in some of the pictures. All do'able
  12. DirtyDT replied to elsie125's topic in Projects
    Keep it as stock as possible without getting anal would be my choice.
  13. No back up, no idea of where you were going, no spare cash and no idea how to fix things - Everything stupid seemed to be a good idea.- Good old days.
  14. DirtyDT replied to Rickylee's topic in The Bar
    I can't help on specific oils for a bike however, I always use Castrol Power 1 racing two stroke oil.
  15. Hi and welcome to the forum. Great intro!
  16. Hi and welcome to the forum.
  17. DirtyDT replied to kearnsy123's topic in The Bar
    The first thing I would check is how long you can use it in the UK without doing anything. I think it is a year but not sure. Get a V/55 form. An import pack is available from here LINKY which may help. Taken from another forum "........For Republic of Ireland, you Insure the car on its VIN plate number, then take it to an MOT station in UK. Once you have that certificate you take all the documents you have for the car to a DVLA office. There is a registration fee and you pay for the TAX then they send you the new REGISTRATION document and TAX DISC with the UK reg plate they have given you......" Check out if you need to apply for a UK driving license too.
  18. Hi and welcome to the forum.
  19. Hi and welcome to the forum. A good picture for the YOC calender I think!
  20. Hi and welcome to the forum. Start a new thread in the project section and post lots of pictures.
  21. Hi and welcome to the forum.
  22. Hi and welcome to the forum.
  23. Hi and welcome to the forum. I would drain the oil and change the oil ring. Best to do the job once and properly. Just to let you know that there are lots of people older than you on the forum.
  24. DirtyDT posted a topic in Video Section
    http://www.youtube.com/watch?v=-5QAJ8P3BIM
  25. If Carlsberg made questions.............................
