DirtyDT
Everything posted by DirtyDT
  1. Come on Foamy! You always post one of these and as soon as the date is known you pretend say that you have the carrot crunchers steam rally the same weekend. Not advisable to run around naked mate. Remember Kev goes to Squires and you could wake up never knowing.........................if you know what I mean!!!!
  2. DirtyDT replied to lukewhiting's topic in The Bar
    Check the connections to the bulbs behind the headlight. Spray a little wd40 into the switchgear.
  3. Hi and welcome to the forum.
  4. +1 for the bobber idea. Welcome to the forum.
  5. I am sorry that the forum fell short of your expectations. Some people join and go and some people stay a while. To be honest I am not sure what you expected but if this forum isn't for you then so be it. Writing what you wrote will not change that. It does smack of being a little immature though. Please don't slam the door on your way out and good luck in finding that utopian forum you are searching for.
  6. DirtyDT replied to chelseasmiiiiile's topic in The Bar
    No thanks, I have just eaten.
  7. Hi and welcome to the forum. Fabulous isle by the way.
  8. DirtyDT replied to drewpy's topic in Projects
    I love the Goonies film. The bars look great Drewps.
  9. I've never burnt my belly on an exhaust and that is heading south!
  10. Soften the plastic by getting the exhaust hot. Wood block (not ply) and solvol should do it. Oh yeh............................. keep plastics away from hot exhausts.
  11. Hi and welcome to the forum.
  12. I agree with DT50 above. Type your numbers into the top parts box here to see ther models that may help
  13. It won't help!!!! I think (but you need to check) Inlet Valve Clearance (Cold Operation)0.08~0.12 mm Exhaust Valve Clearance (ColdOperation)0.10~0.14 mm
  14. Try http://www.oemmotorparts.com It seems these parts are shared with TT-R125's and TT-R's 50
  15. Do you have part numbers?
  16. I have a very unusual name Mike. A bit harsh kev. Remind me to show you my multi-pocketed waistcoat at Squires next year!
  17. 'tis Guido Fawkes Mike.
  18. Moved to the workshop. Spark, fuel and compression are all you need. The timing has to be right also so check the compression and the timing. What exactly happend if you pour fuel into the plug hole and try and start it? Cylinders can get flushed of oil so leave the plug out for a while and try a little clean engine oil down the bore and turn it over with the plug out. Then take the air filter out and squirt some wd40 into the carb and push the starter.
  19. Hi Jay. Welcome to the forum.
  20. If you live in the UK and like a smoke or drink, use the link to see what percentage of tax the government of the UK take. LINKY For anyone outside the UK that wants to play along and wants to convert their "habits"; 20 cigarettes are around £6.70 1 pint of beer is around £3.00
  21. Hi Ray. Welcome to the forum. "Bike rebuilding" and "2 stroke" in the same sentence. There is a hard core of people like you on here so pull up a pew and make yourself comfortable.
  22. 2 things I can think of are: It is a very cheap chain the adjusters are moving
  23. No. They stretch a fair bit when new but with a good lube they tend to settle down very quickly.
