neversaydie
Everything posted by neversaydie
  1. The Thundercat has self diagnosis. 0 to 8,000 rpm every 3 seconds is the fuel level warning system fault code. Check the level sender/wiring/bulb etc for bad connections. Also, 12 volts isnt a particularly healthy battery, needs to be up over 12.5 to 13
  2. Im determined to ride winters whenever the rain relents, and keep topping up with fresh. I noticed a few eeks ago that the pumps at my local filling station now have the new Ethanol stickers on them. Previously, I was assured that the super unleaded did not contain ethanol, now the sticker says E5 which means it may (or not) contain it. Its rather confused the issue again, as Id rather not have it in the fuel I buy, but Ive been unable to find find out whether or not the sticker is simply a legal requirement, or the fuel actually contains ethanol
  3. neversaydie replied to jimmy's topic in General
    Gotta take any chance to get out on two wheels. Looks like a lovely sunny day. I got about 30 miles in today, plenty of layers on so didnt get too cold, but water everywhere running down the hills and onto the roads
  4. neversaydie replied to Cynic's topic in General
    Know how you feel. Our youngest left school and went straight to uni. Lived on the campus for the first two years, then house shared for the next four, then travelled every day for another two years. Worth it all for her, as shes doing exactly what she wanted to do from an early age. I've always reckoned that if you put the work and effort in with children when they're younger, they should do ok on their own.
  5. Im not familiar with the SR125, does it have a fuel on/tap? if yes, are you switching it off when you get to work? if not, the bike might be flooding while parked. Also check that the seal is good around the filler cap, and I would suggest that the bike may run better if you use ethanol free petrol
  6. neversaydie posted a topic in General
    Had a good day out at Donny Park a couple of weeks ago, Ive really been lucky with the weather the last 3 to 4 years. Put myself up into inters this year, reckon Im pretty close to the limit of this bike/rider combination. If I lean any more, the bottom of the fairing lifts the contact off the rear I reckon. The sliders I made to cover the hole I wore through last year need changing, but they did the job
  7. neversaydie replied to nearlymadeit's topic in General
    Have you tried those companies that advertise in Classic Motorcycle Mechanics magazine?
  8. Wow, that looks smart
  9. Youll need to use a hosting site like Photobucket to upload photos from
  10. Get a jack and a piece of reasonably stout timber, place the timber under the frame rails beneath the engine, put the jack under the timber and carefully raise the rear wheel of the ground. Start the bike, clutch in, into first, watch what the rear wheel does, report back
  11. The Chunderace is a big old heavy bike, cant think for a minute the R1 would have the same clutch. If the springs are the correct ones and not heavy duty, then you might want to try lubricating the cable, and checking that the cable is routed correctly from the bars to the housing. Conversion to hydraulic is a possible solution if a kit is available
  12. Thats a great effort. Complete new wardrobe to fit the new you?
  13. Looks like part no 4jh8196001, superceded by 5sl8196000. Looks to be readily available
  14. Aye, I have to be mindful that its my only bike now
  15. Had a blast. Bit apprehensive in the first couple of sessions, but settled down ok after that. Definitely rode faster than novice group, like Finnerz says theres a good range of abilities and I was towards the slower end of the group but by no means embarrassed. The higher overall speed meant I could keep flowing better. Missed the final session as absolutely knackered and didnt want to risk it. It was packed full, and on track were Dean Harrison and Ron Haslam in the fast group. I could count road bikes on one hand, all the others were trailered/vanned in, along with all of the gear that goes with em, race bike/track bikes, some wonderful machines there. And me on the humble fazer. Next up is an evening trackday session sometime in June July, probably another in August, the the Road Bike only day in early Sept.
  16. Had another super day last week, novice group, blessed with decent weather again. Ive booked again for next monday, intermediate group this time, not sure if itll be too hot for me but going to give it a go
  17. neversaydie replied to finnerz89's topic in The Bar
    Very posh. Is the bottom pic up by the airport?
  18. No point going for a used one, likely to be in similar shape. High end ones are likely to be £400-£600, budget ones £200-£400. How about having the existing one rebuilt? Part number is 4TV2221030, original equipment is likely to be hard to come by
  19. Whats the mileage? I think that'll be fuel injected, not carbs. Easy enough to do if youve got the equipment. Always start with the simple stuff first though, plugs/filters etc, make sure the chain tension is correct and lubricated, if the fuel is more than a couple of months old, dump it and put fresh in
  20. neversaydie replied to ljr05884's topic in Projects
    Wemoto are as good as any, also M&P, then Yambits, Fowlers. No shortage of suppliers. Mudguards/fenders, try going to the Stafford Bike Show at the end of April, youll find all sorts of stuff there. Solid struts (hardtail), its your choice, but on Englands roads !!! Its like theyve been carpet bombed
  21. Hmmm. Interesting. Thanks
  22. I was having similar problems a while back, didnt want a tailpack as I struggled to get my leg over the added height, tank bag stops access to the filler, so I bought a largeish leg holster, it takes all the daily stuff, phone/cash/discklock/keys. Depends how small you can roll up the waterproofs
  23. Try having a look on the cmsnl website
  24. neversaydie replied to Cynic's topic in The Bar
    Hope so. 3 rideouts this last week, out for 4 hours today, got back home just after 4pm. Ashbourne, then the B5056, mile after mile of lovely B roads, and no traffic
  25. neversaydie replied to 2 Wheels's topic in The Bar
    3,000? I'll be lucky. Only rode 1,500 last year on the fazer, and 300 on the virago. Sold the virago last summer cos it just wasn't being used, and i'd really rather let someone have it that would. Since I retired, ive found that I have even less time to ride. Odd, really. First grandchild on the way too, ill struggle again this year. Didn't help when my youngest broke her leg and I had the four horses and dog to look after though
