neversaydie
Everything posted by neversaydie
  1. neversaydie replied to Grouch's topic in The Bar
    Can you get the bike in the house? or knock up a little lean to, doesnt have to be anything grand
  2. neversaydie replied to Dom1878's topic in The Bar
    Unmolested ones in good nick are getting rarer, and they are still sought after
  3. Cant you just create a pick list from this? https://www.yamahamotorcyclespares.co.uk/genuineparts/9005/7/yamaha%20xt125x/carburetor?uID=0
  4. neversaydie replied to Dom1878's topic in The Bar
    http://www.ebay.co.uk/itm/Yamaha-XVS-125-Dragstar-/111840465013?hash=item1a0a361075:g:vCkAAOSwxN5WYGpf http://www.ebay.co.uk/itm/Yamaha-XVS-125-/141829687001?hash=item2105b546d9:g:koAAAOSwKrhVcW5u http://www.ebay.co.uk/itm/2002-52-YAMAHA-XVS-125-/121878614650?hash=item1c6088127a:g:yCkAAOSwFqJWrAcQ
  5. The first one, the 2 point jack, to remove the rear wheel, youd put the jack near the front of the frames. for the rear wheel removal, jack at the rear of the frames I wouldnt like to work on the bike while the jacks under it though, the footprint doesnt look large enough for me. Id support on stout timbers so it reduced possibility of tipping The second one, yes, youd need additional supports to clrar the frames There is anpther sort, that lifts the bike on a leadscrew http://on-bike.com/motorcycle-lift-eazyrizer-big-blue.htm
  6. neversaydie replied to ele's topic in The Bar
    well done. if the motor is good, id be inclined to just cleanup/paint the exterior of it, then focus your time/resources on that needs to be restored/replaced.
  7. neversaydie replied to Dom1878's topic in The Bar
    Not a particularly special deal there. Another £500 off would make it more reasonable, but like all bike buys, it pays to shop around first An xvs125 in good shape, and not chopped/generally fucked up will always fetch good money
  8. First time Ive heard that one, physical plug chop eh
  9. Hmmmmm What with the "Ive put too much oil in" posts, one may be excused for thinking indeed someone is taking the piss
  10. Lets guess that you put the tubing in the engine and drained the excess oil out. Yes? And youve now got the correct level of oil? Yes, you could have damaged the motor with too much
  11. Get the excess oil out first Bike has to be vertical upright to check the level in the sight glass Send me a PM and ill reply with the setting procedure for the clutch from the XVS125 manual
  12. Yes, you can replace the internal components you know, you dont have to have the whole carb
  13. That rot on the caliper looks old decay to me, probably well estabished before you had the bike When I had the xvs125, I rode it through 2 consecutive winters, and when SMIDSY wrote it off for me, I got top dollar cos it was in top nick (got more than I paid for it) so it is possible to winter ide and keep bikes in good order. But it is time consuming Id througholy clean/wash the bike at the begining of November, dry it, and polish (chain off to wash dry lube) caliper off/pads out. Once dry ACF50 all over the bike, apart from brake disc/pads/seat/tyres. Time taken, around 6 hours or so Ride through winter, washing the bike the drying it acouple of times during the season Dont apply any more AFC50, should last through the winter. Once winters done, repeat the autumn wash Trouble is, it looks like you have some corrosion problems to deal with beforte you can get to that position
  14. Ask the instructors when you get there. Itll depend on weather/track conditions etc
  15. Good for you Jimmy We had two lasses, and I got to go and support them at the dancing/netball/gymnastics etc, all the girlie stuff
  16. neversaydie replied to Grouch's topic in The Bar
    Thats tough Groucho. I hope that you get back up an running again soon Make sure that you get a crime no from the feds
  17. neversaydie replied to ele's topic in The Bar
    Looks fairly intact, and in fair shape. Its only my opinion, but Id be inclined to see if it runs first. Does it turn over by hand/kickstart with the plug out
  18. https://www.yamahamotorcyclespares.co.uk/genuineparts/9005/7/yamaha%20xt125x/carburetor?uID=0
  19. You need to check what warranty came with the bike when you bought it. I can anticipate that the seller will say its out of warranty, and the rust and corrosion is as a result of winter riding/lack of care from the present owner Having said that, youve nowt to lose That caliper may need replacing, also the pistons and pads You say the chains loose?, could be stretched, using the condition of the caliper as an indicator, id say the bike has been neglected. Likely to need a real good going over for other potential problems
  20. Dont wait for the bearings to fail, could be nasty for you, and cause more damage to the machine Stuff like that should be ASAP
  21. Assuming that the bike has the two frame spars (like the xvs125), I used to put a stout piece of timber on the trolley jack, position the jack centrally under the front of the frame lock the rear brake on, raise the jack carefully so that only the front wheel lifts (rear stays on the deck) once high enough for the axle stands, slip them under the frame as close to the jack as you can get them lower caefully onto the stands. Should be nice and solid on that repeat the process now with the jack as far back as you can safely get it, slip your stands/timbers under the frame as close to the jack etc etc lower carefully onto stands/supports someone holding the bike while you do this is a big help, same when youve finished
  22. A couple of tips: Try soaking the bolts/screws with Plusgas first, let it soak in to ease the threads Try easing the bolt/screws both ways a little, sometime its just enough to crack the seal If a socket cap screw/bolt socket is rounded, you can sometimes get em out by tapping into the worn socket, a torx key, just so big that as you tap it in, its cuts into the socket to give a nice tight fit When re-fitting, remeber to use a little copper grease. Makes it easier next time
  23. 4 pieces of good timber, with "V"s cut into them, spaced on the same centres as the two frame rails, secured onto the lifting platforms Might be perfectly safe but Id just use that lifter to lift the bike, then lower it onto stands before working on it
  24. neversaydie replied to jimmy's topic in General
    Been watchin it (2015 races) this last week on Motors TV (channel 71 around these parts - Freeview)
