barkwindjammer
YOC Member
Everything posted by barkwindjammer
  1. Going back to the start when you split your caliper, when you put it back together was there an 'o' ring or some other seal between the two halves, and if so did you carefully put the two halves together with the seal in place ?, I'll assume that you did, did you move or tamper with the pots (cylinders) or their seals ?
  2. If you have enough clean brake fluid left, would you like to give it one more go ?
  3. Ok, the fluid is meeting some resistance somewhere, thats why its oozing from the nipple thread, using the 'normal fill method' would you say that the system is almost full?
  4. Is that with the new nipples in the caliper ?
  5. Hi and welcome to the nuthouse Riley
  6. cos I r thick see
  7. I fecked a battery a couple of winters ago leaving the heated grips on (why dont these things bleep when you turn ignition off ? Speedshop ?), anyhoo, stuck it on the charger and it would only hold 6v-some of the plates had been damaged , expensive lesson that one so I removed the heated grips, I now use 'mini' hot water bottles attached to the back of my gloves with duct tape
  8. Hi and welcome to the 'ward' Beeky , nice intro m8 have fun with the bike and like Ttasky says do your own thing
  9. Welcome to the 'ward' Seth
  10. That is a very nice bike Paul-you lucky b@%l@r£
  11. Welcome to the Y-O-C Nate
  12. Hi Ally and welcome to the 'ward' , nice intro the 'divvy' is a great bike TOKNABOOT !
  13. Bleed nipples are fairly cheap to replace, I asked about the master cos I would only buy 'critical' parts off the bay if I intended to strip them and do an over-haul, keep us posted on how you get on with the new nipples (oooher missus)
  14. A purchase from the bay has no guarantee, unless it states it has a guarantee, did you buy the part from an online supplier or a private seller ?
  15. yer some kid Paul
  16. Hi Tim and welcome to the Y-O-C, nice intro m8
  17. Well done Paul 99.9% there, a great project and an interesting WIP (work in progress)
  18. Welcome to the 'ward' Dae, are you Welsh isn't it ?
  19. Aha !, I just wanted you to play your cards first as a Jock I'm a compulsary member of 'long-face-book'
  20. I'm too old and stupid for that shit
  21. The 6th of May 2011, pay attention at the back Sniff, and stop sniggering
  22. The moths in my wallet wear sunglasses, not used to seeing daylight
  23. Ok you win welcome to the 'ward' Eric
  24. You could rub both down and then paint with a matt black acrylic rattle can
  25. Your number plate is squint too
