drewpy
Everything posted by drewpy
  1. drewpy replied to jrhendryx's topic in Classics
    loosen top nut (11) and clamps (12) around top stanctions. tighten #8 till no more movement, don't over tighten as you can load a ton weight upon the bearings. check that there is no notchiness now as the bearings will be running in their cups properly. re-tighten the top nut and then the tube clamps. those cables do look tight and I've never seen those daft handle bars on an xs500. get BT45 tyres, as they are the best for this type of bike drewpy
  2. drewpy replied to TamzSR125's topic in Classics
    I got my carbs cleaned professionally by JRS in swansea. Did a fantastic job and good communicator. check out his web site by googling JRS carbs. cost me £100 for 2 carbs
  3. drewpy replied to jrhendryx's topic in Classics
    check tyre pressures, steering bearings for notchiness, check they are not loose by rocking bottom of forks fore and aft. (nautical, but nice), wheel alignment with the rear wheel, check front wheel runout, check brake caliper is not sticking. let us know how you get on please, for other forum users drewpy
  4. drewpy replied to TamzSR125's topic in Classics
    woha! slow down Tamz, wer'e not a call centre and sat nights are for pubs and clubs. Is there any other symptoms like smoky exhaust, loss of power, spark plug is a light shade of brown? If the bike has been standing, its likely the petrol has evaporated in the carb and gummed up the tiny internal passage ways which will need shifting by cleaning. give us more to go on and you will get a better prognosis
  5. if you are feeling flush, use a pingel fuel tap
  6. I knew that was comming (well the mouse behind was!!)
  7. drewpy replied to thebob's topic in Classics
    you could be wet sumping, where the non return valve from the oil tank drains into the engine rather than stays put. the oil pump may not be able to scavenge the oil quickly enough. Iwould also check for any oil gauzes as they block up and not help with oil flow. the amount of oil in your engine could prevent it from turning over 3.5k revs.
  8. Fangs for the tip off!!
  9. there is a computer program called yamx which cross references all USA spec yamha's. I have the progrm but don't have the code to use it get it here
  10. I looked into this for my flat tracker and the xs400 can't run without a battery due to the way it needs 12v to magnitise the field coil. I have seen an xs400 cafe racer which looks like it has one and emailed the owner (to no response) on how he/she achieved this. until there is an answer I am going to ditch the starter motor and fit a small battery where the starter was. this will give me that open look i'm after through the frame. you can see the bike here
  11. drewpy replied to thebob's topic in Classics
    sounds like your burning oil. need to check valve seals as they may have hardened with age. Also the piston rings could have stuck allowing oil to get past. I assume you have checked the oil levels, i think the SR is dry sumped, oil in frame?
  12. way yaa! I see that you're doing a tracker. have you got the bits and pieces or are you just starting out?
  13. is the bike a "custom" model?
  14. I have two torque wrenches both 1/4" for my socket set. a low 6lbs to 30, and a larger 10lbs to 80lbs. I got mine from ebay but one is a draper in Nm which is a pain to convert for my use.
  15. carbs gummed up, you will need to strip or send off to a specialist for cleaning. I use normal unleaded Petrol Also high reving is due to the mixture weak, check inlets on carb for cracking.
  16. drewpy replied to eyedee's topic in Naked
    title not flash it, now Flash Git!!
  17. could be an earthing problem, make sure that you check the earth straps and connections for continuity. other than that, the solenoid is kaput. there is a ebay company in Aus who has yam bits as I have bought from them a few times and was really cheap.
  18. drewpy replied to mervin's topic in The Bar
    sorry to hear that Merv. I'll keep my eye out on the classifieds
  19. engine and frame number would help as we don't possess ESP yet! picture would also be nice
  20. certainly a good point about no load as this could prevent the grease from penetrating at the load point.
  21. Talking to a tech guy today at local bike dealer, and he recommends using 140w gear oil for greasing the swing arm as opposed to normal grease. The thinking behind this is that normal grease hardens with age and stops doing its job. What do you guy's and Gals think about using 140w gear oil?
  22. drewpy replied to dsligh's topic in Classics
    try ebay germany. they liked the euro styling of this model and there are quite a few there. I def saw a (white) Guilari seat for that model on ebay not long ago here you are ebay #'s 280111501642 260206738584 140187893259
  23. just a note on woodrough keys, they are only there as a guide and don't stop the magneto from turning, this is done by the taper on the crank and why you have a puller to separate the parts.
  24. drewpy replied to socalyamaha's topic in Classics
    in less air. As a guide, should be 1 1/4 turns out from the bottom
  25. Well, guess what I'm doing at the moment Jack the bike up, or leave on main stand but raise 2" off ground undo caliper and tie up from frame (or if drum don't do this) Take off speedo drive and front wheel undo the clamps for the legs and twist down and off the bike (that's why you jack it up) tricky bit..... use an 8mm (i think) Allen key under fork leg and clamp leg in vise. (you have left the springs in didn't you?) using a shock/snap motion, loosen and undo the bolt. you still have oil in so be careful. leave standing on a bowl to let oil drain out (pref overnight) If the bolt turns but doesn't undo, come back on here as now it becomes a pain. Repeat for the other leg get the wife to take out the circlip whilst you push down on the top spring securing plug. (my missus has done this before and is really good at it. If you're lucky you can get her in a position so her tits rub on your arm, Bonus!!) take off the lower fork leg circlip Prise out the seal with a tyre lever and use heat. Mine has come out easy as i did this a few years ago and greased (ACF50) the seal watch for a spacer under the seal clean all the crud at the bottom of the leg drift in the new seal making sure it is the right way up anneal the copper washer for the allen bolts and check for any signs of wear reverse procedure for assembly (inc the missus help!)
