Everything posted by drewpy
My 1978 Yamaha XS400
looking good, keep at it and you'll soon have a finished bike. watch out you don't over polish anything as it will stand out and the next thing you know the bikes all stripped down coz that shiny part didn't look right on its own!!!
- xs400 burning oil
xs400 - Tachometer wire
german ebay or shops in germany will stock them, as this was a popular bike there http://translate.google.com/translate?hl=e...hl%3Den%26lr%3D
RD400 F Rear Brake Master Cylinder
http://www.geocities.com/motorcity/flats/3...buildup04b.html this explains how to modify an FZR400 rear for your bike or try Jonny at PGM www.pgm1.freeserve.co.uk
RUST IN TANK CURED
you can get it from www.frost.co.uk
Petrol Proof Paint Type
I use and recommend PJ1 as i used these for my engine casing and is really resistant to petrol WHEN CURED!! ie heated in an oven. for a tank I would be inclined to go for 2 pack or whatever its called nower days (i think 2 pack is old hat now coz 1 painter laughed at me when I mentined that!) get a reputable painter to do it. My tank was original but my painter laquered over it and after 2 years theres not even a blister around or under the fuel cap!!
- Grumpy
Aint been there for a while.......
i ended up in a right shit hole!!!!
xs 650 rear wheel options?
you'll find other xs650's had rear 19" wheels same as xs750/850/1100. xs400 and rd's had 18" front and back
What is this thing?
XS Triple Frame & Engine Numbers Model Serial Number Year XS750D 1J7-000101 1976 XS7502D 1J7-100101 1977 XS750E 1J7-220101 1978 XS750SE 1J7-300101 1978 XS750F 1J7-240101 1979 XS750SF 1J7-350101 1979
my electrical just dropped out today
you didn't flick the cut off switch when you kicked it over did you?
- Enfield Bullet
XT350 Trouble
check its not running at 45' ie too lean!!!
Xs400 kickstart problems - clutch?
the thing with a kick start is that is only turns the engine over 1/2 at a time whereas the electric boot can keep the motor spinning. could try bump starting to get the engine turning! clutch slip will affect the engine starting, as that is the only thing that connects to the gearbox and hence the kick start. electric start is direct on the crank.
my latest resto
very nice Merv, hope she goes as well as she looks!! ( or is that a he!)
few questions on new bike '83 maxim 400
could strip down the carbs and check for blockages, check also your rubber manifolds for cracks.
"plop" is the sound of my crap hitting the bog water, "thump" is what i do to the kids when I'm trying to watch MotoGP
sounds like carb diaphrams either perished, hard or holed. also check the slides move freely and drop with a "clonk"
Electwickery.........
Sounds like an earth problem. indicator lamps usually have separate earths and pulling the clutch makes an earth conract.
Help with steering head bearings
I used a plastic waste pipe as its just the right size, keep the seal on the bottom. and drift the bearing into place after warming up.
General questions about the xs400sg
1. by all means check the rod, as if it is bent you will have clutch problems 2. zerk? I assume you mean nipple? whereabout is it? 3. do the forks yourself, 20w oil use an impact driver to take off the lower screws (1 either side) and pump forks till all the oil is expelled. fill up with correct amount. I'd let the shop do the master cylinder, although I've seem a couple on NOS ebay which would be cheaper!!
smoke?
is it just slight oil vapour or is it puffing out like a chimney?
79 XS400 - Hard starting and poor idle.
I was thinking more like 50 psi, as that is what I did my carbs. 100psi will be too dangerous as it can pierce the skin along with the other bits of crud. My little compressor can only make 60 tops.
what certain things?
