drewpy
Everything posted by drewpy
  1. thats how you change the float height!! keep moving them and they will snap off eventually!!
  2. not uless you want to weld on new tabs. An xs400 seat fits an xs400
  3. drewpy replied to rockstar81's topic in Naked
    stick a multimeter on dc volts across the battery terminals and you should get between 13.5 and 14.5 volts @ 3000rpm. for the charging system to work you NEED a good battery as it excites the field coil to generate the electricity. if after you have a good battery and you can't get the volts, it is usually the voltage regulator as they are electro mechanical in operation. drewps
  4. drewpy replied to Scythe's topic in The Bar
    not too far from stafford county show ground, get there in april and see a HUGE classic bike show ( modern ones there too) to the forum
  5. its my best bike
  6. drewpy replied to rockout12001's topic in Classics
    you will need a special tool which are common to all mags. looks some thing like this
  7. no probs, the only major change with the 500's was the redesign of the cylinder head AFAIK
  8. best getting a manual as it explains how pistons are oval and wear fore and aft etc.
  9. the tube method is the best as it takes into account the vagrates of each carb. why not get a matching bolt and drill/tap for a nipple?
  10. Been busy this week and after buying an NOS engine case from XS360's estate ( god bless him) I have now rebuilt the engine. it just needs timing and the wifes help in shoe horning it into the frame( she does have her uses)
  11. drewpy replied to Jim R's topic in General
    I think Goff has a spray booth for all her leathers so long as the leather is fed and keeps supple any product is good enough, I use dubbin on my boots to keep the weather out!!
  12. It amazes me when I see the duke videos of them doing 170 near curbs and the bars are tank slapping. I don't think rossi would do it as its a completly different way of riding!!
  13. drewpy replied to Goff's topic in The Bar
    didn't you leave your helment attached to the bike when it was trashed?
  14. drewpy replied to barkwindjammer's topic in The Bar
    I did hit a plastic hub cover on a bend over snake pass doing 60mph. It happened so fast it never got the "stomach pit feeling ", just straighted up the bike to the other side of the road and after I ran over it, carried on turning. Thank god no-one was comming the other way!!
  15. drewpy replied to little dave's topic in The Bar
    aye, seen it before its in a series about women drivers. should see some of the parking ones
  16. 'kin ell! get a haynes manual and do it yourself. build up tools as you go. I am self taught so it can be done!!
  17. all the sohc clutches are interchangable AFAIA make sure you get the primary gear as they are matched.
  18. drewpy replied to pav's topic in General
    I have to have agreed value insurance, and carole nash does the deal for me but only after a get a cheaper quote from somewhere else. Just say you want to stay with them but they need to make it happen. Puts the ball back in their court!
  19. drewpy replied to wild foamy's topic in General
    can you get to stafford bike show in April? get textile jackets for £25
  20. drewpy replied to wildone's topic in General
    this is why you wore platforms in the 70's, plenty to wear down when using additional braking!!
  21. drewpy replied to wildone's topic in General
    wow 69mph!!
  22. what abot XTR600 ?
  23. drewpy replied to mervin's topic in Yamabyss
    I can can just feeel my neck hurting laughing at this, Merv can you give me your insurance details please?
  24. drewpy replied to mervin's topic in Yamabyss
    Lazy girls, i expected them to clean that room by 1:07. should use yakety sax for the music just like benny's
  25. that reminds me, i have a video short from the 80's called "blood runner" a bit more blood than running tho'
