drewpy
Everything posted by drewpy
  1. I think the coils are bonded to the HT leads as were mine. There is a fix where you can dremel away the coil body to extract the lead and epoxy in a new one. or buy new link to xs11 site
  2. drewpy replied to rockstar81's topic in Naked
    Usually voltage regulator problem, stator and field coil dont touch anything so are reliable. wires could crack where the drive chain flings oil on them though!! never disconnect battery when alternator is generating as it will fry! see other thread re: ignition
  3. can't help, fork spring length is 502mm though! main jet 132.5 air jet 45 jet needle-clip position 5Z1-3 needle jet X-6 pilot jet 42.5 starter jet 30 fuel level 32 +/- 1mm conacts are reliable normally! neutronic (newtronic?) had a system which replaced the contacts, there may be some knocking around in america. I had a box made in germany which used the contacts to trigger the eletronics. so far 100% relianble and I can go back to analogue if it fails on the road!!
  4. cheers for the info, not sure about the itinery yet, but when its nearer the time I'll be in touch!! aparantly this guy knows and races with the Dunlop's so might get to meet them!!
  5. drewpy replied to Rich_B's topic in The Bar
    I keep getting IPS Driver Error There appears to be an error with the database.
  6. I used to live in Combe Martin, where the wolf man comes from. although the place is full of gerryatrics last time i visted!! great biking roads specially out of season!!
  7. Mate just booked the ferry from stranraer to belfast today. he has a friend racing in the NW 200 and he has a granny flat for us to crash in. He has also got us in the paddock and the evening soirees. Leaving on the bikes friday 15th comming back sunday late. anyone know of a good route to dumfries other than boring Motorway? Drewps
  8. drewpy replied to mervin's topic in The Bar
    :lol: I want to stroke her pussy
  9. Motorcyclists in Nigeria have been wearing dried pumpkin shells on their heads to dodge a new law forcing them to wear helmets, authorities say. Officials in the northern city of Kano said they had stopped several riders with "improvised helmets", following this month's introduction of the law. Road safety officials said calabash-wearers would be prosecuted. Thousands of motorbikes have been impounded around the country and taxi motorbike drivers have staged protests. Calabashes are dried pumpkin shells more commonly used to carry liquid. According to the new law, all motorbike drivers and motorbike passengers must wear helmets. Kano Federal Road Safety Commission commander Yusuf Garba told the BBC they were taking a hard line with people found using the improvised helmets. "We are impounding their bikes and want to take them to court so they can explain why they think wearing a calabash is good enough for their safety," he said. Fifty motorbikes had been seized so far in Kano city alone, he added. http://news.bbc.co.uk/1/hi/world/africa/7813418.stm
  10. use heat as well. the ally and steel have different expansion qualities and will break the corrosion. if it snaps off, arc weld a nut on it and the heat will also halp to remove. drewps
  11. drewpy replied to Ttaskmaster's topic in Yamabyss
    :lol: bet she felt a right tit
  12. drewpy replied to pilninggas's topic in The Bar
    just had a horrible thought, it wasn't Handai driving the car was it?
  13. but redo the final gearing ie sprockets as you will be undergeared.
  14. drewpy replied to Alex's topic in Video Section
    way, lets see og wheelying on his DT with a pipe in his mouth having a "condor " moment
  15. drewpy replied to pilninggas's topic in The Bar
    I know its painful i had a guy pull right in front of me, luckily i dismounted before the bike hit the car which proptly set on fire (gulp!) broke arm in 2 places and a cracked spine L3 and the lesson I learnt was even if you are in the right you still get punished by being injured!! that's enough of me, hope you are ok mate! the police should be able to tell you where the bike is! Get it back asap as you are totting up parking charges, the greedy bastards it cost me £300.
  16. drewpy posted a topic in Yamabyss
    the cheeky git! went to park my bike the other day and some dick got there before me!!!
  17. drewpy replied to cupranod's topic in Classics
    if you want a decent paint job, you can't get a fast turnaround as they will be busy!! can't help you with the local painters but sunrise graphics will do your decals. drewps
  18. yep its the same with mine, they (yamaha) did sometimes have different jets for each carb, so check you havn't inadvertantly swopped them over if you have those jets. did you take the pet tap completly off as i suspect the diapram is not as efficient in releasing fuel. you can get kits form HVG cycle and mikes xs
  19. still putting the engine in the frame
  20. drewpy replied to julien40's topic in Classics
    essai Ici part # 94862-09104-00 speed sport ICI
  21. drewpy replied to julien40's topic in Classics
    bonjour Julien. to the forum. yes that's O rings, you can purchase O rings from anywhere. all you need is the size!
  22. drewpy replied to Jim R's topic in General
    At least it will keep the moths away
  23. sounds like you have a fuel supply problem. is the tap really clear of crud? is there a sucking sound when you open the petrol tap? (breather blocked) could try to rig a temp fuel supply and see if it runs ok. (to eliminate the above problems)
  24. drewpy replied to anakonda's topic in Yamabyss
    what allegation?
  25. they still do that on blackpool prom (north) but don't advertise! I saw some tasty supercharged JAP engined bikes faster than the modern stuff. (well is was on methonal ) not been for ages, will have to keep an eye out (it's glass you see)
