drewpy
Everything posted by drewpy
  1. Jimmy, plenty of guys on here who can help
  2. could try VJMC site on facebook?
  3. Ciao Andrea. di dove lei in Italia?
  4. drewpy replied to slice's topic in General
    well done, did my cam chain on the TDM, was fairly straight forward in my instance.
  5. how did the weekend go, any photos?
  6. Tommy, his bro Andy and myself had a cracking weekend at Brecon. some amazing roads there.
  7. i've booked talybont farm at brecons now for that weekend.
  8. any news on this? I booked the friday off anyway and may go to the brecons again
  9. probably local complaints about noise or facilities are not compliant.
  10. Am I booking my place or are you doing for for everyone?
  11. try and get the friday off if I can, otherwise come later on in the evening
  12. I have a '96 TDM with '99 carbs and they fitted different needles fir each carb. I have a GPR can on the back and that pops, try opening up the pilot mix screw to 3 turns out
  13. CV carbs need a liner airflow to work properly. I used the pipes to the original filters and popped some filter over them. to do a proper job, you'll need to get o a dyno to dial in the fuelling
  14. can't help on the pressures, but if its zero, panic and stop the bike. As for a gauge, get one which has clear fluid in it or it'll explode with vibration. Just keep an eye on the Gauge and you'll soon get the pressures and know if it drops (all weather dependant too) My oil was like water in Andorra (45'C) and the oil light came on on tickover.
  15. there a giant hog roast there as well as the caff
  16. Just a heads up that on BH thursday, There is a wray bike night, I recon its going to be rammed with bikes if the weather is good. I'm going to leave aroung 12 noon from Manchester and over to yorkshire and Stumps cross cavern then back through Hawes, devils bridge and then Bentham to Wray.
  17. James
  18. drewpy replied to Nobby 1's topic in Electrics
    west country windings may be able to help
  19. for carb gaskets try NRP in manchester, I also use the ethanol resistant gaskets from https://litetek.co/Carb_Kit_Yamaha_FZR600.html for photos get a link via photobucket or a free service
  20. CDI's were only fitted to 70's bike as it means capacitive discharge Ignition. as fitted to the early kawasaki KH range. TCI is transistor. Your point is still relevant as ignitions will be built to expect certain ohm readings from coils. there is a third ignition which is Digital controlled ignition. maybe that was what you were referring too?
  21. this forum doesn't do verifications. I assume you wan to register it? Do a search on the forum for Paul dawkins
