drewpy
Everything posted by drewpy
  1. drewpy replied to CadXS's topic in Classics
    AYE, Its no "Yoke" this problem I would say it was the steering head lock. its called a neuman lock, check it hasnt been inadvertantly been activated. The yoke should easily by pass the mechanism!! the bearing have cups on the stem and the headstock and need to be drifted out if renewing. drewps
  2. we could have a curry section that way we can have food AND wind like a 2-4-1 offer
  3. drewpy replied to bswinn's topic in Classics
    thanks for the info Jim, checked the european parts book and its 1L9-12151-00 x 4 so that's a start! drewps
  4. drewpy replied to bswinn's topic in Classics
    they are not handed if that's what you mean. It could be a batch number!!
  5. why not the green and white but the white in yellow to white flip tones. that would be cool?
  6. drewpy replied to a post in a topic in Naked
    millar sounds like you have an air leak or your pilot screws need resetting richer drewps
  7. drewpy replied to triggs's topic in Yamaha Workshop
    did you forget to install the ball bearing near the "mushroom" in the clutch housing?
  8. VN800 thats a lot of bolts and hard to actually put into words. In future you should make a cardboard layout and place the bolts in the cardboard that corresponds with the cases. HERE 11= m8-150mm 10= m8-110mm 9=m8 80mm 8= m6 105mm 7 = m6 80mm 6 = m6 50mm 5 = m6 45mm 2 = m8 150mm drewps
  9. Ben not sure where your habitat is in this world, but you can get them at yamaha or here
  10. drewpy replied to up.yours's topic in Classics
    I thought you could replace bushes like the xs i have. usually they are made of nylon plastic but I have a set of bronze which keeps things in check. you might be able to keep up with me on the twisties then
  11. drewpy replied to Golden Eye's topic in Classics
    goldenE its a uk based site and we are out playing coz its weekend. I'm sure you'll get some replies soon!
  12. there was a conversion doing the rounds which changed the oil filter to a larger one I beleive, maybe jim could shed a litle light on this?
  13. is it a standard bike or modified?
  14. drewpy replied to Nameless's topic in Classics
    shaping up nicley, better pics would be good too!
  15. would this not fit? have to look at the airfilters to see if they will! http://www.cmsnl.com/yamaha-fzr400u-1988_model9365/partslist/
  16. that and your new uniform
  17. that added ending spoiled it for me was that the directors cut?
  18. drewpy replied to Goldfinger's topic in Classics
    you can get petcock repair kits off ebay etc c/w new diaphram and seals. once you get that fixed, then see if the needle still leaks! drewps
  19. saw that today as well!! they just been to see a friend in hospital!
  20. drewpy replied to barkwindjammer's topic in The Bar
    :lol:
  21. bloody 'ell, worse than OG's Toe and that's saying summat!!
  22. This is the international classic japanese bike show and its MASSIVE!! planning to ride out on either saturday or sunday depending on the weather. we normally go down via knutsford and stop off at little chef, stoke (near A500)for a brew and a bit of crumpet! then its filter riding near the stafford county showground as the roads are choked with punters. I usually set off about 8am and get to stafford 10ish with pre bought tickets as the queues can be rather long (it has got better over the last few years) if anyone wants to come along,your welcome but be prepared to walk a ways as this is a big show and takes 4 hours just to walk round!! http://www.classicbikeshows.com/
  23. nice one chris "current state" liked the pun with this charging system, you have to start out with a fully charged battery as this is needed to excite the field coil into a magnet which produces power for the battery!! the actual regulation of electricity that gets produced is done by either an electromechanical or electronic voltage regulator. this device sits between the battery and field coil. Its possible that the electromech one may need adjusting. electronic ones need replacing. you also have a rectifier; this goes from the stator where AC is produced and converts it to DC to charge the battery.these can also fail causing a big short! to test; you need a multimeter over the battery terminals and check that you have 13 - 14 volts @ 3k revs. there are other tests you can do for the regulator and rectifier which are in the download manuals at the top of this forum page. BTW to the forum drewps
  24. drewpy replied to Cynic's topic in Yamabyss
    oi loiks dat
  25. tried yamaha? granby's motoward cmsnl
