drewpy
Everything posted by drewpy
  1. to the forum Devine I suppose standard 2 stroke tuning techniques, lightening the bike of all superfloues fittings and up grading suspension, tyres and brakes! its a matter of how far and how much you do yourself to keep the budget down! Personally I'd go for sticky rubber, progressive front springs with 15 - 20w oil (depending on body weight), rear hagon dampers, homemade rear sets, ace bars and better brake material. you can always go round corners flat out drewps
  2. drewpy replied to DKWraith's topic in Classics
    good basis for a cafe racer here are a few pickies to whet your appetite
  3. saw these todsay at the toy run and was thinking of getting some for the flat tracker. can anyone shed some light on them (sic!) and where i can get them (or a link)
  4. I used this link to do mine, I thin they will be 6 over (thats 6 spoke holes over to the next spoke fitted) http://www.instructables.com/id/Rebuilding-a-Spoked-Wheel-for-the-Royal-Enfield-Bu/ also used youtube... drewps
  5. look like triumph nacelles, TBH most 50's brit bikes had those so i'd check out Equipe in rochdale or dragan motorcycles or Carrot cycles.
  6. as always there are 2 thoughts as to what to do. TBH powder coating is great and so far mine has lasted really well and shines up nice with a plastic/vynl cleaner. the issue is if you cut it then the water can leach in and corrode under the coating ( i have touched up with blackpaint and you can't see and its kept the water out). Also it goes on thick so be prepared to trim caliper slides etc along with retapping threads. If you use a reputable powder coater they should seal all holes and threads. see www.triple-s.co.uk/ for info. painting is not so forgiving and will show up rust lumps etc and is more expensive. you can touch it up but i think it doesn't take knocks as well as powder coating. if powder coating get all the stuff done in one go as there can be slight differences in black between each supply of powder!! drewps
  7. drewpy replied to kevin10529's topic in The Bar
    poss knackered battery which the heated grips supped all the juice. nothing for the ignition to use till it charged up again!
  8. weather was great and nice to see OG there. Kev went but was fasionably late so we missed each other. anyways here are a few pictures OG tinseling up A rose between thorns the 3 amigos the final destination the oldest bikes there must have been at least 600 bikes there it was a shame that the police pulled out of any responsibity so we had to fend for ourselves and it fragmented the riding group. will do it next year though drewps
  9. drewpy posted a topic in Video Section
    I defy you not to sway in your chair to this <object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  10. drewpy replied to mervin's topic in The Bar
    my 12 yr old son bought his own poppy with his dinner money, made me feel proud that did. we're marching this sunday to eccles cenotaph (scouts)
  11. saw the blue peter exhibition at museum of film and photography in bradford, very good, not a lot on bleep and booster though (for those old enough to remember!) i must recommed a visit as you can do blue screen stuff and read the news via autoque. great animation floor as well drewps
  12. RFS nice to have you on-board
  13. drewpy replied to kevin10529's topic in The Bar
    have you checked tyre pressures? it could be moving slightly in the bead!!?? try deflating and reinflating, it might just need re-bedding in the rim!
  14. looks like you are going the right way about it. don't forget to take LOADS of pictures as you go. break the work into modules, eg brakes, engine, electrical, dials etc, label and box everything in its modules with bubble wrap. list every thing you need and tick it off when bought, I find I buy at least 2 items of the same part try not to rush, but don't stall the project or you'll get peed off with it. have fun..... drewps
  15. or a chimp from brook bond
  16. Hi
    drewpy replied to HerbalRick's topic in The Bar
    Ricky doodle dandy nice to have you on board
  17. no problem Mukka!
  18. probably all the fuel and choke cleaner you put in the engine. has it settled down yet or still reving? could also indicate a very weak(lean) mixture!! Air getting in somewhere ( use easy start or similar to check for leaks) drewps
  19. there are some which actually move as well. saw them on youtube last year but can't remember the link
  20. drewpy replied to waynemorris's topic in Yamabyss
    :lol:
  21. cloudy you have to post in the wanted section mate as posted wants anywhere else is Vorboden! drewps
  22. if no-one can answer that try the VJMC they will bound to know drwps
  23. a few pointers here http://www.factorypro.com/tech/carbtun.html http://jrs.uk.com/JRS_Home.html make sure you have al gaskets, you will need an impact driver for those bloody float bowl screws ( unless they are allen type) borrow an ultrasonic cleaner for the parts. have a manual handy and work CLEAN!
