Everything posted by drewpy
XS400 taper bearings
as far as i can remember , both the bearing races are the same size. i remeber this as I thought i'm made a boo boo and drifted out and swapped round to find exactly the same I took off the rubber seal on the bottom of the lower fork yolk to assist with fitment!!
- New Member
Henry 8.0
briliant comedy from auntie Beeb <object width="512" height="400"><param name="movie" value="http://www.bbc.co.uk/emp/external/player.swf"></param><param'>http://www.bbc.co.uk/emp/external/player.swf"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><param name="FlashVars" value="config_settings_showUpdatedInFooter=true&config_settings_showPopoutButton=false&config_settings_skin=black&config_settings_bitrateCeiling=1000&playlist=http%3A%2F%2Fwww%2Ebbc%2Eco%2Euk%2Fcomedy%2Fforge%2Dassets%2Fextra%2Fplaylist%2Fp005bqp0%2Exml&config=http%3A%2F%2Fwww%2Ebbc%2Eco%2Euk%2Femp%2Fiplayer%2Foffschedule%2Exml&config_settings_showFooter=true&"></param><embed src="http://www.bbc.co.uk/emp/external/player.swf" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="512" height="400" FlashVars="config_settings_showUpdatedInFooter=true&config_settings_showPopoutButton=false&config_settings_skin=black&config_settings_bitrateCeiling=1000&playlist=http%3A%2F%2Fwww%2Ebbc%2Eco%2Euk%2Fcomedy%2Fforge%2Dassets%2Fextra%2Fplaylist%2Fp005bqp0%2Exml&config=http%3A%2F%2Fwww%2Ebbc%2Eco%2Euk%2Femp%2Fiplayer%2Foffschedule%2Exml&config_settings_showFooter=true&"></embed></object>
up.yours woolly hat
- big f*ck off ski slope
- hollywood vs New york
good hollywood film montage to rapsody in blue clicksy here- carburator cross refrence question
xs250 and common in uk- XS500C needs timing chain and link
have a look here- xs400/ xs250 exhaust`s
not standard coils, made more room for an under tank brake master cylinder. it is a fork brace made out of 10mm stainless rod. front brake will be installed the plate is fully visible from behind so should be ok! no just some 31" laying around a friends garage which looked right, so the cables still fit. if you want longer cable you can get them made from carrot cycles or use SE version cables as they are for the longer handlebars no probs, don't mind critisism at all so long as its constructive! sounds like not enough amps or holding wrong, just keep practising drewps- Wok 'n' woll, Daniel san !
bloody 'ell, i thought i could play.- xs400/ xs250 exhaust`s
I just got a motad and cut the can down a bit, used an arc welder ( its all i have) and came out quite well!!- The Enemy
singer looks like richard Hammond, good sound for a trio.- Just new here
- i`ve just joined
Cool got some pikkies on this forum somewhere..... just making contact with someone to build me a tank as I have an under tank master cylinder that needs building round.- secret to long life
A doctor on his morning walk, noticed the old lady above, sitting on her front step smoking a cigar, so he walked up to her and said, "I couldn't help but notice how happy you look! What is your secret?" "I smoke ten cigars a day," she said. "Before I go to bed, I smoke a nice big joint. Apart from that, I drink a whole bottle of Jack Daniels every week, and eat only junk food. On weekends, I pop pills, get laid, and don't exercise at all." "That is absolutely amazing! How old are you?" "Thirty-four," she replied.- 1981 XS400S Not Starting after Throttle Cable Replacement
if the worst comes, you can buy gasket kits to repair and clean out the tank at the same time!!- Just Joined
- i`ve just joined
pepp enjoy your 400, check out the classic section where there is an xs400 sticky links- Help with XS250 Special
R K Leighton of brum will recover your seat for you. they have a web presence and do a great job! motad one here- Replacing rear tire
can't go wrong with the bridgestone BT-45 check here for tyre size conversion- Hello from Malaysia
- Gas up - Lets go!
- white lights
I think he honks everynight, especially after a few beers and a curry- NEWBY
kawa ( crap name for a yam forum) enjoy the forum - big f*ck off ski slope
