Everything posted by drewpy
sh1t happens
thanks for your support, its still sinking in. Probably take a few days to sort my head out
XS 400n pistons 1978 markings
size is usually stamped on the front top. nothing there means standard bore
sh1t happens
minimum. £388 per year of service plus holidays owed
spark plug/spark plug cap question
the R in the plug designation means resistor type. yamaha service manual says; BP-7es NGK or N7Y champion they are always have a little post screwed onto the top, which needs to be removed before installing the plug caps which are rated @ 10Kohms
sh1t happens
Hi Guys, bit of a downer, just been told I'm redundant last day = 31st October 13 years with the company, great just before xmas
My RD350LC
Has OG cleaned it or summat?
Blackhats other hobby
saw thast ages ago, good though although can't remember the series still prefer the this; start from 1:20
- hi to everyone
Fall out from a duff bulb....
ah well, at least it'll give you something to do over the winter
hello guys
Jheeta, there's a few old soldiers on here stick around!
hunter shoots bear NWS
sorry merv, already posted this
More electrical gremlins...
here's the 400 wiring diagram with the condensor ringed off
not unless your running electronic ignition!! contact ignition needs a condensor to stop arcing of the points!
Cardboard Dave is this how you did 95?
already stripped Paul, did it same day its a peice of piss to do. just need to finish the tracker and prob start on the baby late next year!!
xs400 flat tracker project
would be nice to introduce yourself to the forum, just to say "hi" i'm using the stock rims 18" with 3:50 front and 4:00 rear chen shin tyres from wyldes up in Leeds wheels are xs250 drewps
oil light problems!
what, a look in the bathroom mirror?
as it happens i have an xs650 wiring diagram
on the XS there is a continuous live feed via the ignition switch. the contacts earth the coil to charge up the primary, when the earth breaks, the secondary coil discharges that energy to ground (the spark plug) this is in very simplistic terms. with one wire, all i can think is the live is triggered!
he he if I catch my son doing that on his Garelli, I wouldn't know whether to pat him on his back or bollock him. As a one off, OK, its when you get blase and take stupid risks. (ps he wouldn't do it anyway, not a bit like his dad) what was the speed? bit quicj for me on the vid!!
Iridium Plugs !
got a set in mine, fit and forget, been i there 2 years and still look as good. Mind I only needed 2
XS 500 Gaskets
there's a blag by a TX/XS 500 enthusiast which may help
when I was buying new coils I came across those. Figured that there was no satisfactory way to use them as you need a + supply for the coil and an interupted earth for the points. the only way to use them would be to isolate the coil form the frame and run a negative to the points, not the best. check the ohms rating as they could also be for electronic ignition systems!
should be 2 wires, pikkies please?
This could be the funniest thing I've seen for a while.
new tyres have their moulding coating still on. they need to be scrubbed in before gunning it!
New member... So... Hello :-)
orange moggy miao!!
