drewpy
Everything posted by drewpy
  1. its not a voltage regulator its a rectifier in your pictures, which is it?
  2. drewpy replied to drewpy's topic in Projects
    nearly done the valves, ordered a 260 shim off ebay for #4 exhaust valve and I could mix and match the other shims to suit stripped the clutch down today and replaced the dowel pin with a split pin mod and it tightened it right up. put the plates back in and there's too much gap as though a plate is missing I did replace a thick washer between the basket and the inner hub and the spline shaft ran out and it sat on a shaft area which seems odd. need to take it back apart and check orientation. primary gear could be undone by hand too which was a bit scary
  3. drewpy replied to mervin's topic in Yamabyss
    need to do better guys we don't give them away for nowt ya know.
  4. will do, thanks
  5. Off to Belgium with the scouts in a few hours so see ya in a week's time. be good and not too much drinky poo foamy
  6. I still have the non-pro Halford socket set and had it for about 10 years, nothing broken and built 4 engines with them! the biggest issue is the plastic box they come in, the clear front broke years ago and if you kick it, some sockets come out
  7. drewpy replied to Noise's topic in Projects
    looking good Noise, I love building engines but they are so expensive and time consuming £177 for gaskets
  8. looks like you had a great time, must get out there soon meself
  9. looks like Foams on his way to squires on the DT50
  10. drewpy posted a topic in General
    ist a flipping advert, but the game is fun for, oo, 2 mins http://toys.usvsth3m.com/pump/
  11. Barley says - brwow mm whma mioaw
  12. I have tools from Aldi and I use the old adage " the job comes first" that is, if I need to modify the tool for the job, then that is what I do. So far they have been ok except for the screwdrivers. you don't have to buy expensive, just wisely and always ask opinions
  13. ...and a 1" penis, what's he complaining about, its double the size of Foamy s
  14. drewpy replied to jont's topic in General
    I like Darley Moor, usually go and see the last race "Stars of Darley" with some classic bikes thrown in the mix. not sure on a sprint there though, Aintree or North Blackpool prom is better for that
  15. drewpy replied to Preload's topic in General
    whoo hoo
  16. just replace the rear cassette and have done with it, go to a local independent bike shop or Halfrauds
  17. drewpy replied to GREIGE's topic in Projects
    google is your friend, no posting on this forum regards links.
  18. drewpy replied to GREIGE's topic in Projects
    get a part manual too, comes in handy chasing spares. just cleaning carbs on the fz (xj motor), rewired alternator and other bits and bobs. doing clutch tomorrow (weather permitting)
  19. chain and sprockets worn
  20. ..and over you and yours too
  21. Glad to hear he's ok Tommy. £900, blimey
  22. OK, Eddie wants 2, need to see what they cost edit found the thread, they are £3 each + post
  23. chain and sprockets worn
  24. do you have a fuel filter on the bike, fine powder rust will open up the float valve slightly and will need cleaning
