drewpy
Everything posted by drewpy
  1. drewpy replied to drewpy's topic in Projects
    with this "new" engine I got, Yamaha decided to upgrade their engine to digital ignitions which are not compatible with the FZ system. Hence I am after an Ignitor marked tid-14-78 3km-01 I can also use the tid-14-79 3lt-00 as I have been assured that that will work too. Anyone got one for cheap please? any working alternatives would be nice too eg fzr600!
  2. https://www.catalyst-findit.co.uk/index.php?c=03860a9239e3aa1a8b94be6f5796b331&preview=6&dest=prod&p=400&pid=35567310%20S they're from 2006 so you may not find much else online
  3. easy to google http://www.agriandgarden.com/valve-grinding-paste.html?gclid=CLGqz73S2LsCFUzHtAodvmAAfQ 1) clean the valves in situ with brass brush in drill 2) take out valves 3) you can also clean valves in drill if dirty, but watch your not reducing the valve stem width 4) grind in valves to seal with linky posted above
  4. I thought it was just showing a photo, bloody 'ell Grouch!
  5. drewpy replied to drewpy's topic in Projects
    Bob Wright has just emailed me to say the final parts are on their way, yippee have the frame and fork legs at the local TIG welder to make a better job than me. Get the frame to the powder coaters next week and then should be on the final build
  6. leave the valves in and get a brass wire attachment for the drill and decoke the heads. the vales need to be out to check the seal between valve and head (pock marks, bits missing) otherwise you can lap the valves in with grinding paste. you can get a kit of two types of paste and a little suction cup on a stick to spin the valve around to grind them to the head. don't forget to use your cardboard to put the vales back in the same order.
  7. chill factor-e roof has blown off twice now, so its not surprising bikes get blown over
  8. got family in Capetown, in fact 1 works for cape fruit export
  9. brake fluid is supposed to be good at gasket removing too according to classic bike mag
  10. when i rebuilt the xs I put mineral oil in and rode like I stole it. dropped the oil after 20 miles and filled with semi-synth. this theory is the bores get bedded in and this worked really well. the only caveat was that i reused the good parts so essentially, they had their "edges" knocked off and I could do that. with a totally brand new bike, you got all that broken off shite lurking in the gearbox etc and cane-ing it won't do the bike much good recirculating it around the engine. I'd drop the oil and put new in and then think about giving it some
  11. what was the question?
  12. probably, you have to understand that its a 600cc engine in a 400cc frame. very tight for room
  13. get the green solid tyres, no punctures
  14. i would have taken off the large nut on the adapter and kept the thing whole. But that's academic now. remove all electrics first (including that neutral wire) and alternator/starter wires
  15. I'd keep it intact as you disturb the seals otherwise
  16. not from the area, but it's a legendary event and now the council want to ban it FFS register your complaint here http://present.brighton-hove.gov.uk/mgEPetitionDisplay.aspx?ID=410&RPID=11175561&HPID=11175561
  17. wow, nice one/ Look forward to seeing some more on this and the openface with gigs. Got a NOS goggles despite its glass (laminated I hope) should be up for some longer touring escapes then?
  18. depends, the Rd xs650/400's go regularly and I'm sure Merv has a stash or get them from ebay
  19. don't hold your breath, still waiting for the 2014 calendar
  20. JAn sales will start soon and maybe you'll get some xmas money off someone!
  21. that's just a gasket kit. a rebuild kit has all the oil seals in as well
  22. rebuild kits? tell me more
  23. drewpy replied to pilninggas's topic in The Bar
    result
  24. instead of running the bike, which unless it really hot, will promote moisture. the best thing to do is get a little oil heater and stick it under the bike over winter. Keeps the moisture out as it warms the bike up and keeps it that way.
