drewpy
Everything posted by drewpy
  1. its a soft cell......tainted love, ohohoh
  2. they look great Tom, 400's a looker
  3. Had our St Georges day parade today, 290 beavers, cubs scouts and explorers turned up looking their best.
  4. so photoshopped!
  5. so shite its good
  6. you know when things are so bad, they are good. this is it..all sing now, Jeneeee and meeeee
  7. if school chemistry was this good,i might have stuck with it
  8. drewpy replied to rwd's topic in Yamaha Workshop
    If the contact gap is changed and it's a new set (the heel will be larger) the timing will change. Happened on the gilera Sent from my RM-914_eu_euro1_280 using Tapatalk
  9. I also use Motoward, martin is very helpful also try governors bridge as they buy containers of NOS parts, fonseca and motowurx near 3 sisters wigan specialise in grey imports
  10. The Oil Can presents the IK Classics Spring Car Meet & BBQ. Saturday 3rd May 2014 starting at 4pm A meeting of like minded classic vehicle enthusiasts Bring along your classic car, bus, truck, can or motorcycle! 'RAIN OR SHINE!' http://holmfirthevents.co.uk/event/ik-classics-spring-car-meet-bbq/ Dobroyd Mills, Butt Lane, Hepworth, Huddersfield, HD9 1AF
  11. drewpy replied to drewpy's topic in Video Section
    I liked the "jump" where he goes into the mound of sand rather than over
  12. I'm not in here BTW
  13. I assume you mean mini disk? couldn't afford one
  14. drewpy replied to drewpy's topic in Projects
    that's sounds a good idea your last post wouldn't work, it will have to be magnetic and probably pretty close to the pickup
  15. bloody wacked it tonite at scouts and expleted a few anglo-saxon words. £2.5k was the limit and is about right for the ped. you dumbasses thought it was £1600? that 65% of 2.5
  16. drewpy replied to drewpy's topic in Projects
    my next Port of call would be to try and re gap the pickup. the main issue is its screwed to the cover and the only way to check was maybe a bit of plasticine on the mag and see where it hits. for reference, all the ignition and charging electrics and motor are '91 xj600
  17. got a call and the driver has admitted fault. so solicitor coming round tomorrow morning and awaiting the assessor to look at the bike. as I am on agreed value, the ins normally call it if more than 65% of value. This means that I have £1600 to play with, so should be ok.
  18. drewpy replied to drewpy's topic in Projects
    I think it works by the raised magnetic "Castles" on the magneto passing the pickup coil with sends a small impulse to the ignitor. whether the ignitor sends anything through the other wire (there's two) is anyones guess. They do have to be the right way round, but if wrong doesn't affect the ignitor ie not destroy it. I think you need an oscilloscope to see the effect as its very small voltages we're dealing with.
  19. drewpy replied to drewpy's topic in Projects
    2.1 ohm coils from '91 xj. the fz's are 2.5 off the top of me head
  20. drewpy replied to drewpy's topic in Projects
    yep and i have all the right connections in place with 12v to coils, all safeties bypassed, coils within specs, ignitor tested and working, earths checked. 3 month gel battery resting with 13volts on and kept on an optimate.
  21. drewpy replied to rwd's topic in Yamaha Workshop
    its timing then or you put the piston in backwards?
