Everything posted by drewpy
Lotherton Hall 27th July
bring back a burger then
I think its a given, love it in there
we'll meet at maccy D's again leaving at 9am
smile, your on camera
Fz600 Gulf
we have bike shops, but don't stock everything especially non-resistor spark plugs
Whats your worst ride
z400, what a dog that was!
Fz600 Gulf
thanks felix, i have an fz engine in the shed. just ordered some non resister plugs as maybe the dynas have resister silicone leads. ordered some oil for opie too
wanted: Edited by DDT
nope! to keep the forum going, it needs money
Fz600 Gulf
I'll check it Tommy, but there's only the loom in the upper frame that's original.No chance of any oil soaked wires there.
nah, riding comes first! so long as the weather is ok (and its supposed to be)
1982 RD350LC - Stood 20 years
for the gilera tank I used vinegar, worked a treat. Watch alloy though, it eats it
Fz600 Gulf
wouldn't rec over 1200, no airfilter on and no exhaust too it was loud! might go with the non -resistor plugs, maybe the silicone leads are resistor leads!
Help with XS 250 valuation please
we tend to find that peeps who do an intro first and then ask q's later tend to stick around and helping those peeps out tends to feed other posts which keep the forum alive. someone posting a question as first post only gets peoples back up as, happens all the time, we never see them again and we feel used because of this. Hence DT's post
Fz600 Gulf
well this is strange, wired in the new pickup coil and it didn't spark again. shortened the lead and it sparked! got continuity in the loom, so maybe its the ohm thing. got the engine going, but wouldn't rev at all, pulled the carbs but they were clean (from the last job) I do have another pickup but its 290 ohm with 1.5acv as opposed to 98ohm with .8 acv any thoughts on using that one?
The next project, cafe racer or streetfighter
I always like to clean the engine before I strip it, bolts etc get stick on the grease and get lost. did you put some oil down the bores or was that already there on the stripdown? you don't want smoothbores but a nice 45' cross hatch hone for oil retention
Fz600 Gulf
found me spark; combination of things 1) couldn't get to fire manually off battery, so took off the caps and the spark was very weak. even though Dyna say it doesn't matter which way the connections went,I turned them round and got a better spark. 2) kept the 5k caps on and resistor plugs as both = 10k ohms which is correct for the bike 3) tried an R1 pickup/trigger coil and it gave our 1.5volts, 3 times the old one. this told me that the one I have must be faulty 4) there was some rust/paint on the raised parts of the mag, so cleaned them up with wet and dry 5)installed a new trigger coil and got spit back out of carbs, so got sparks. still need to wire it in properly, but its had quite a downpour today so hopefully will get out tomorrow and see what's what she's not running as yet, but at least I'm getting there
- FFS
unfortunately its worth about £800 to £1k tops there just isn't the love out there for them.
1989 xj600 with all the glam of spandau ballet !
if the gear moves, its worn. I had to drill the hole larger to accept the pin and drive it in. being spilt it will deform to fill in the wear.
please read my post above re:pins
Euro tour
Can't wait to see your handle bar videos in different countries
Fz600 Gulf
ok I managed to get a spark from the dynas off the bike taking out the 5kohm cap and resistor spark plugs and using a nail instead I've earthed the TCI in the right places to the frame and confirmed its earthed. basically the TCI is a posh earth switch controlled by a chip to change the frequency of the switching.
RD350LC No brakes
yay, well done
Fz600 Gulf
I was taking off the neg, will try the feed (+)
Fz600 Gulf
I'm off tomorrow, so in the mean time
