drewpy
Everything posted by drewpy
  1. you need to RIDE THE BIKE! this is the best way to keep the engine in good condition. the engine isn't getting hot enough as it need to be under load.
  2. drewpy replied to Goff's topic in General
    I'll be on the xs400, what your riding?
  3. drewpy replied to SophicMan's topic in Classics
    should go faster than 55 I get the ton out of my 400, 250's will do 80mph bike on centre stand, level ground, unscrew the dippy, wipe it, then rest on top without further screwing ( sounds a bit rude this post!) pull out and check level. I recommend using 20w 50 millers classic sport oil semi synth or equivelent oil in states http://www.millersoils.net/1_Millers_frame_BIKE.htm
  4. I used a file and did it by hand,its only alloy and easy to do on the caliper mount. I left the hub alone
  5. drewpy replied to Goff's topic in General
    I'm booked in the barnsley M/C festival this year!! I'll have to get your autograph then
  6. when I changed to twin disks on my 400 the cast wheels where fine, but when i had spokes put on I had to shave a few mill off the caliper mount.
  7. drewpy replied to DeBortole's topic in Classics
    about bloody time!!
  8. don't forget tx 500 as well!!
  9. drewpy replied to drewpy's topic in Classics
    I think there was a discussion on aircooled rd site and the consensus was they were too fragile. Don't forget that these were one of the first production "alloy" wheel and Yam were still learninig their craft. That's why I spent over £400 on flanged ally spoked wheels, much lighter (and sexxy!)
  10. Dat's funny
  11. there was one on ebay not long ago!! typical eh? I sourced mine from usa and got them zinc plated, now looks like new. Item number: 320213545092 just found on usa ebay, no wire hook though for compressing rear swing arm if you want i can show you mine I assume that they are very similar comming from the same stable!!
  12. drewpy replied to smokie's topic in Classics
    I wouldn't as the varnish lifts after a bit and looks horrible. I did consider all the merits when I rebuilt my bike. so in the end I opted to hand polish every now and then and after 2 years it looks as good as when i first did it!!
  13. drewpy replied to divvyman's topic in Classics
    It shouldn't do!! make sure the battery is fully charged and functional as this is required to charge up the battery (sounds daft, but the stator is excited by magnatism via the field coil and needs a good 12v) you should be reading 14.5 volts @ 3k revs across the battery
  14. drewpy replied to smokie's topic in Classics
    belive it or not, the white powder is protecting the alu underneath! best way is to use wet and dry, start rough and work your way to 1200 NEVER USE WIRE WOOL, it embeds into the soft alu and then rusts!! I stick mine on a polishing mop then peeks polish to keep it that way.
  15. i'll be there 26th!
  16. drewpy replied to redd's topic in Yamaha Workshop
    mine does that and I totally rebuilt the motor. thats why there is a cover there. A tiny little bit will come out when on main stand, but will piss out on side stand. to check if condensor has gone, open up the points cover and if the points are sparking, then your condensors knackered or not earthing properly.
  17. drewpy replied to mervin's topic in The Bar
    bloody hell ,that's some haul. can't belive the balls of some people, I hope they catch them soon!!
  18. if your desparate, who ya gonna call? http://www.motogrid.com/pages/parts/viewby...d/2/yamaha.aspx hope your $700 desperate
  19. drewpy replied to DeBortole's topic in Classics
    try new cam http://www.megacyclecams.com/catalog/page57.pdf dial in your carb settings on a rolling road cheapest way i know the get better performance is to lose weight, so go on a diet!!!! .... welcome to the forum!
  20. kids aren't cleverer, its the crap exam Questions they get and the school system. My kids are in school and even though the schools are in the top 10, they flit from 1 subject to the next and if you don't get it, tough. then there are no winners and losers , just participants. and playing certain games like "tikky it" is banned due to health & safety!! no wonder private schooling is on the up!!! don't know if you saw that programme where the kids did the old O level standards, 2 passed out of 30, enough said
  21. I'd drain the fuel out, put in the best octane in and then thrash the bugger. running an engine for 15mins will only coat the engine in crap, especially if not under load. riding like you stole it, is sometimes the best way to maintain an engine as full bore is the most efficient for an engine. I do this with my bike and car and you can see the crap burning out the back. just my 2p worth
  22. nah, winking is good for you!! its the quality of schooling today and to much txtng and l33t sp33k!
  23. sounds like a relay. if it persists get it replaced as it will draw a lot of current and will blow your fuse
  24. eh!? my blacks can pull and the osme starting was fine. unfortunalty my hand can't kick start with the big spring on me crutch!!
  25. drewpy replied to 78special's topic in Classics
    sounds like a fuel supply problem, check fuel flow and put an inline filter on. check float bowl height as last resort
