Everything posted by drewpy
81 xs400 SH Headlight
http://www.norbsa02.freeuk.com/goffybulbs.htm
clutch cable/return spring wear...
I'm a bit confused what you are trying to say. do you have a picture or link to the part?
xs400 starter- just spins and spins
looks like you will have to get a starter pinion set. I've seen them on mikes xs I think. the left hand casing will have to come off, but you shouldn't need to drain the oil if you leave the bike on its mainstand. you will also need to get a special tool to break the rotor as the starter pinion is behind this. I am assuming that this is the sohc version drewpy
Big fuel leak from rebuilt Carb
the service manual says it is 1st edition may 1981 from engine # 3F9-000101
No 6th gear on my 83XS400!?
if you can read german there are loads of 12R stuff in german web sites www.xs400.de you will find sig links to the correct site. they have the detuned version for the german domestic market. i have the '82 and '83 parts manual on cd along with most of the sohc stuff. i think pioneers x got the '83 off me and hosted it on his site!!
CLEANING VALVES AND OTHER BIKE PARTS DURING ENGINE REBUILD
take out the valves and put them in a drill, use fine wet n dry and spin away dead easy. keep an eye on the vavle seats as there maybe a stepped seat and has to match the cyl head. always keep valves in the same place you took them from. ideal for alu engines is vapour blasting some companies can do the complete engine with no stripping involved. i had my head ceramic cleaned in a drum by steve smethhurst in salford uk. and its till as clean 2 years down the line.
for an xs400sg
found a supplementl section in my official Yam service manual, here goes; model id 3F9-00 main jet #135 needle jet Y-2 Pilot jet #42.5 starter jet #35 jet needle 5GZ9 float height 27.3 +/- 0.5mm air jet main #45 air jet pilot #155
I hate to tell you this but I just viewed the 83' parts manual and there are only 5 gears listed
my '80 xs 400 frankenbike
love the flat tracker version, what tank is it? and yeah those pipe are way cool
chello'
1. correct so when you open up the tang it shuts the fuel off "earlier" and gives you a lower fuel height. You hold the carbs right way round and gently blow though the fuel inlet whilst raising the floats. when the air stops, that's where the measurement is taken. 2. I thought 111's were for the dohc xs400? correct me if i'm wrong. 3. I don't do inches only metric
The float height is measured at fuel shut off NOT bottomed out as in pictures!! bend the tongue down towards carb to shut fuel off earlier and lowers the level of fuel in carb bowl are you sure they are 111's? the tickover adjustment is on the outside and have plastic floats
Xs400 kickstart problems - clutch?
its been covered to death on other posts.
NEW TIRES ON 83 XS400! 1.85 width on front
my bad, just checked the parts book and they are the correct wheels and 19" front. just seems a retrograde step when the thinking at the time was going over to 17". I know that yam used 16" with higher profile tyre on "factory customs"
for a start the tyres should be 18" wider front tyres will slow the steering down the optimum would be BT45 bridgestone 90/90
VJMC Uttoxitor show this sat and sunday
VJMC's 2nd Ux show at the racecourse. see and hear classic bikes, Sat and sunday
Electrical Question
why are you disconnectng the battery when the bike is running? you will f*ck up the rectifier and burn out the alternator and all you are doing is killing the juice to the coil thatr's why it stops!!
bending the tag outwards ie opening the gap, will get the floats to close the fuel off sooner
Leak in brake line xs400?
not usual, need to get either new seals or new brake hose depending where the leak is. seals are only supposed to have a 5 year life and fluid 2 year!!
1978 XS400E
its usually the front studs rusting in the barrel. need to get some plus gas/diesel down there and leave to soak for a week. empty and then heat and gently tap the block.
woohooo at last
1981 xs 400
just had an idea check your brakes arn't dragging, when i had mine powder coated, they partially seized and it felt like evry time i changed gear the bike slowed noticably. I just gave the caliper a kick and a bit of shaking to free up the seizure. it took a while to keep doing ( ijust rebuilt them so i knew i had no seal issues) and now no problems
'83 XS400K Maxim fires "harder" on the right cylinder?
use a carb balancer and get the needles pointing the same direction. if you can't get them to match then you have ignition or compression issues.
how to stop the suspension creaks and groans
yep, stop the wife riding pillion,works every time for me
