Everything posted by drewpy
Rev counter needle
there's a company called re-dial in the uk who can repair re-face your dials
auto advance
i agree, its called the flame front. as the fuel is ignitied and piston speed increases, the ignition has to start early to complete combustion. In the early days you had to retard the ignition (ie piston after TDC) just to get the buggers going (engine efficiencies/compression/shit fuel/etc)
new to biking
just jesting I feel a fool every night, but the wife is starting to object
learning to swear.
Brill..................iant
- rxs 100
83 XS400 Sproket Conversion
45 tooth sprocket will make the engine turn faster for the the same speed. on my sohc I went 1 tooth bigger on front = 3 less teeth on rear.
No clutch switch?
sorry but i don't have time to scan 150 pages of a haynes manual. i can scan the relevant section but my PSU has gone on my main PC ( on the missus laptop), so i'tl have to wait till i can fit a new one. I can do that for you later if you want?
I like this doctor....
you a were wolf?
1980 XS 250
looking at the hayes manual it looks like you have 3n6 or the later 4a2 model. changes were; larger fuel tank seat height reduced rearsets swingarm lengthened spring; revised rates front and rear stearing lock on ignition revised ignition coil rest were cosmetics
No clutch switch?
they are not fitted to the uk xs400's so i'd do it, there is a small diagram for the system in the haynes manual if your tempted to fix it! (page 138)
air filter for xs400d
you can still get the filters, try bikebandit and motogrid first
No clutch switch?
no clutch switch fitted to the sohc xs400's. if you stall, just pull the clutch in and start the bugger, easier to find neutral then or slip the clutch till the thing bites.
'82 xs400 carb removal
the rubber will have hardened with age (bit like us really) best to soften by using a hair dryer and then taking the air cleaners off first then the crankbreather (hard one, brute force needed and leave to one side connected to the hoses) then the carb to air filter hoses.They are a sod sometimes and you need to wiggle them up and down and pull back at the same time. tilt the carbs up and down and pull back like the hoses and they should come out
new to biking
what, you meant to write in a honda forum
Haynes manauls translated
nice one, thought we was getting a haynes russian translation at first. I like it when it says " remove item" then you spend an hour doing just that and the "harder" part becomes the doddle.
SEXY TALK?
Shhhhhh!!....... Don't tell anyone...... I'm gonna go down on you.... ...And you're gonna love it........... ........But it's only going to be long enough to let you start enjoying it........ ....Then I'm gonna come back up again and fuck you big time..... Lots of love, Petrol prices xx
rear shock pre-loading
i assume its on a screw adjustment which means its alloy and you have gone past the threads there for cross threading when you screwed it back! if it uses a stepped system, just keep turning the same way and it will go back to slack. i don't know the dragstar but most systems are the same
auto advance
mechanical works by bob weights spinning outwards with centrifugal force and pushing the rear points plate around to advance the ignition as the motor increases with speed. vaccuum works the same way but uses the intake manifold to move the plate, as when the engine speed increases it draws more vacuum thus moving the plate more. when i say points they could also be conactless using hall effect or magnetic triggers. on fully electronic systems the advance is "mapped" into the rev range to provide differing curves for each gear and revs.
1980 XS 250
looks like the 6N (top of my head) model which was an update between the older style xs's and the dohc. these were maily sold in germany. you will have rear sets and a rubber mounted engine along with slightly modified seat, tail, tank and oil sight glass. everything else with be as per haynes (they have an addendum at the back for the differences with your model)
Howdy yall, Im new
don't "upgrade" to disks its not worth it and the bike is worth more with those as many peeps use them to make a cafe racer. best to turn over without sparkies and a bit of oil. check battery is fully charged first. be ready to scrap tyres if over 4 years old as they can crack and fail. new oil and filter if after it starts, as the camshaft has no bearing surface and is direct in to alloy head. check also the gauze oil filter accessed from under the engine with 6 x m6 bolts
XS400 wiring issues
its an poor earth problem, the earthing is finding a way through the headlamp and to the idicator, making a circuit for them to operate. start witht the rear black wires and clean the connections and earth straps
transmission gearing change
are you sure that you cannot put an extra tooth on the front sprocket, this equals to 3 teeth on the back (did it on my 400). you really don't want to mess inside the cluster!
Big fuel leak from rebuilt Carb
good to hear
Priceless
- TR1 starting problems
or you mixed up the coils if there are two single ones - TR1 starting problems
