drewpy
Everything posted by drewpy
  1. the xs750/850's have theirs twixt crankcase and oil filter housing. ie from the oil pump, round the cooler and into the filter.
  2. and a different flasher relay http://www.norbsa02.freeuk.com/goffybulbs.htm do hals for older bike fitment. he attends stafford shows in uk as well.
  3. yeah like that opera bird on luc besson's 5th element film!
  4. only cos its cheap. used it the other day and it works a treat, used warm water and a surficant cleaner (w/up liquid type stuff but no salt) more expensive ones have a heater and larger capacity for speed, i just turn the part around just takes longer.
  5. drewpy replied to Iellei's topic in Classics
    bikebandit motogrid yamaha top dog
  6. AAARRR he's gone kwakers!!!
  7. its a sure fire method of cleaning your carbs using ultrasonic sound waves
  8. just get a socket and undo the bugger. it may be tight if its not been touched for a while as the unit sits in line of the front sprocket. if you are really pernikity, take off the whole sprocket cover, unhook the clutch cable and undo the worm unit from inside. put in a vice and go at it from there!!
  9. ultrasonics the way, I'll tell yer!!
  10. crud/swarf making a connection. undo the left sprocket cover and there should be an iory colored plastic thing with 3 countershrunk screws and 1 connection. take this off and clean it. BTW
  11. its an air leak or too much air getting into the mix. mixture screw should be 2.5 turns anti-clock wise from bottoming out. check intake rubber for cracking
  12. its the starter clutch, there are little cylindrical "bearings" which are pushed aginst the crank by little springs and when the engine is stationary the starter motor can spin the clutch up and the "bearings" grip the crank and turn over the engine. when these wear flat they just spin round the crank. to repair you need to take off the left covers and pull off the stator to get to the clutch. special puller is needed to extract the stator. and you can buy clutch starter kits from mike xs which i think fit yours drewpy
  13. thats a lot of oil to burn. yes you do need a battery power to start. its not a magneto bike. check your contacts for pitting and check for flashes from them when a friend kicks it over! (condensors knackered) most prob your carbs have varnished if left with fuel in over a period of time, have you tried easy start?
  14. drewpy replied to grizzlydan's topic in Yamabyss
    good one. btw; for the americans here, its not a vietnam vet we a talking about !!
  15. The National Eczema Association are currently fundraising. They've just launched a scratch card.
  16. i'd go at least 3 sizes = circa 500rpm
  17. drewpy replied to jrhendryx's topic in Classics
    might just be Psycological
  18. i would say 10 mpg, depends how you ride it
  19. drewpy replied to jrhendryx's topic in Classics
    on my xs400 the level is measured with the dipstick removed and placed on top of the orifice without screwing in, that is where the meaurement is taken! if you have overfilled and want to remove some oil, would it be easier to loosen the front oil filter housing and dump that and refit, then turn-over engine to re-prime?
  20. cos it was revving higher for the same given speed!!! 360 sprogs should fit
  21. just switch on your lights before you move off if your that worried!!
  22. at first i went 43 rear sprocket (37 stock) and i could keep up with more modern bikes up to 80(even lifts the front end), but it supped fuel and would wear the engine out quicker, your choice. you can use the xs250 sprockets. to recap on european models from my parts book; xs250 front 15T rear 43T england and swiss models xs250 front 15T rear 41T france holland belguim models xs400 front 16T rear 37T 1 tooth on/off front = 3 teeth on/off rear
  23. for chain longevity, try for a bigger front sprocket as a smaller rear will mean the chain has to run a steeper angle and wear quicker. i think i use a 102 link, but i buy whatever chain is cheap and cut with an angle grinder to suit using the link! check you have enough room for chain and sprocket first and don't use o ring as that's too fat to fit!
  24. do you have to use indicators on the bike? junk them as the cafe racer style will look better
  25. drewpy replied to fdw's topic in Yamabyss
    LOL
