Everything posted by drewpy
- xs360
Gear Lever keeps falling off
or thread lock/spring washer
- should I?
Bike electrical test sheet
thnks for the link
1974- TX500 Rear brake conversion
first question is, why do you want to go for a disk conversion
I got my 81 xs400 running WOOO!!!
still listed mate, http://www.georgiawatersports.com/ http://www.nwvintagecycleparts.com/ SKU: 95821-10145-00 BOLT, FLANGE as for the square tank, there are loads in UK ebay!
fork bolt size on xs500?
they are not stripped, they are turning the inside lower damper rod. you need to get a 15mm dowel and chamfer the end then ram it down the inside tube to lock the damper rod after taking out the spring. A grip in the vice to hold it and then try the allen again. it will be tight. next time you do this you need to "shock" the allen off or it will turn again!! drewps
XS250 Carb Problem?
to theforum wtf61! try a little oetrol additive as I think the carbs are displaying a blocked pilot hole at the top front of the carb. this tends to hang the revs. it usually gets worse when hot!! have a look at the sticky at the top of this section as there are some usefull links for you to try. drewps
black light tattoos
some cool shit, only shows up in UV one for you Goff? http://www.slightlywarped.com/crapfactory/...ighttattoos.htm
you can get the lower bolts from yam dealers still! you can also get pet cock rebuild kits off ebay
- Austria
79 400 xs cafe
just google, not sure who sells them in usa, but allens performance seels them in UK. I have seen some new xs650 34mm on ebay.com, should just need to re jet for the bike!! drewps
float height settings
I shoved a clear washer tube in the lower float bowl with the carbs off the bike and clamped level. easy to do and was 2mm from top of float bowl as per specs. drewps
79 400 xs cafe
white smoke = fuel, float too high or leaking for cafe look I liked the xs750 tank on the 400!! try new mikuni flat slides, they'll cost though
what sand paper to use to get a good crome like shine ?
chocolates good too
erm , I'm not sure about this, reminds me of OG
obviously not been to eccles lately
RAF attestation tomorrow :)
good luck foams and whtch for the left handed screwdrivers and buckets of steam
Is there such a thing
you can get the dials refaced with larger digits.
79 400 xs..
I would suggest you keep the airbox, as these are the best for the bikes ( and rare) you could always try bolting on an aftermarket megaphone, then everyone will hear you!!
79 400 xs..
rewiring is a matter of patience, wiring diagram and not being colour blind. If you can get a yamaha original service book, they even show where the loom goes!!
xs250 piston and block conversion
the engine casings are the same, but you will need barrels, pistons, head (inc valves), cam cover and bs34 mikuni carbs/manifolds/air trunking. all the rest will suffice!
Pilot jets snapped in half in carbs
which pilot jets? fuel air or mixture?
79 400 xs..
have a play with your idle adjustment, its on top at the front of the carb. you need to enrichen the mixture as the revs are "hanging" being too weak a mix. Mikuni BS34 is the 400 carbs can't see why the indicator switch cant work, double check its got all the correct buttons on and you may need to rewire the multi plug. drewps
can some one name this washer/bush
top hat spacer
1972 yamaha advert
just to offset candy bra, I give you a yamaha 1972 advert ">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="873" height="525">
