Everything posted by drewpy
coating on rd250 cases
PJ1 black satin is the way to go, no primer required. I never seen a better paint to resist fuel and heat. I cried when the main factory was burned down ( well not quite!) as they stopped making My yamaha silver for the xs cases. they only make black now!! The stuff yambits sells is crap, it runs and you have to bake it forever to get the petrol resistance ( and it still pools silver if you spill on it) drewps
My Velocettised 1981 XS400 Cafe Racer
love the styling and its great to see what people do to these versatile bikes. bobbers, chops, caferacers, trackers, seen most of these but yours is "one of a kind" well done!
78 xs400e Electrical, upgrades, fixes, hacks.
you can get remanufactured fuse boxes on UK ebay. apart from 30 year old wiring issues, there no massive problems just need to ensure you have a good battery for charging. drewps
Upgraded xs400 to Electronic Ignition
good one, i'll copy and paste the info into the sticky for xs400's drewps
XS 400 Fork oil changing tips
i use 20w fork oil for 200 lbs bloke
78 xs400e brake caliper, will the xs650's work?
nice one
I got my 81 xs400 running WOOO!!!
flangers? do you mean the collars that hold the exhaust to the head? yep you would need those to get a gas tight seal! a dim head lamp could be a bad earth lead, so check all your black wire's connections and the bit under the seat where it touches the frame, make sure there is good contact (remove and scrape) does the headlamp get brighter when you rev?
77' XS Wiring confusion
first off goldfinger I got lost reading the text so I'll start from scratch red/white wire (1into2) connection is switched live feed to coils doubled grey wire goes to right coil doubled orange goes to left coil single grey and single orange to contacts, you will have to swop round these as there is little way of knowing which way round they go as on my bike the colour coding is different on the contact's wires. drewps
1981 Yamaha xs400 Restore
Pyro, It'll be nice to see ya in the classic section of this forum drewps
unseen derren brown reveals trick
blown wide open <object width="873" height="525"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="873" height="525"></embed></object>
malboro transformers
<object width="660" height="525"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>
indiana Mr Jones
Ipista is it the dohc xs400 or the sohc xs400?
please don't overfill as you'll blow oil seals due to the pressure build up. to replace the camshaft seal, you only need to take off the cam cover and you can do it without removing the engine or anything daft like that. get the manual that's posted atthe top of this section as it gives the order which you undo and tighten the bolts to stop the cam cover warping. tank off, top mount off, tacho cable off, cam cover off.... sorted!! so much for "professionally" rebuilt engine!! drewps
- cant spell
New look
hey OT your back? do you fancy going for a ride on 20th see rideout section... drewps
- paddy and the towel
exhausts for an xs400
they'll fit but for a cafe racer you need megaphones!! drewps
xs400 Brake options
some 650 were compatible but there were other brake types as well, that's why I said the other bikes to be sure. drewps
calipers won't rust they are alloy. there are rebuild kits around including stainless pistons.
first post and with pics
to the forum, like the paint job. Have I seen you on chopper underground?
- childbirth
MR3
If the weathers good I'll be there! drewps I'll give OT a ring as I think he's got pc problems.
78 xs 400 tach drive oil seal?
its getting the bugger out, unless you can use a thin screw and pierce the rubber, twist a bit to bite in, then pull out. replacing is a simple matter of driving a new one in!! if the screw don't work, you only need to take the cam cover off drewps
Valve clerance good but still noisy
on compression stroke of course. recommended oil is 20w 40 5'c plus and 10w 30 < 0'c plus with type SE oil
