Everything posted by drewpy
XS400 Yoke problem
AYE, Its no "Yoke" this problem I would say it was the steering head lock. its called a neuman lock, check it hasnt been inadvertantly been activated. The yoke should easily by pass the mechanism!! the bearing have cups on the stem and the headstock and need to be drifted out if renewing. drewps
could we get a section for snowmobiles
we could have a curry section that way we can have food AND wind like a 2-4-1 offer
xs400 Rocker Arms
thanks for the info Jim, checked the european parts book and its 1L9-12151-00 x 4 so that's a start! drewps
xs400 Rocker Arms
they are not handed if that's what you mean. It could be a batch number!!
'78 XS400E Update...
why not the green and white but the white in yellow to white flip tones. that would be cool?
- carbs
Clutch
did you forget to install the ball bearing near the "mushroom" in the clutch housing?
xs250 crankcases
VN800 thats a lot of bolts and hard to actually put into words. In future you should make a cardboard layout and place the bolts in the cardboard that corresponds with the cases. HERE 11= m8-150mm 10= m8-110mm 9=m8 80mm 8= m6 105mm 7 = m6 80mm 6 = m6 50mm 5 = m6 45mm 2 = m8 150mm drewps
78 XS 750 carb holders
Ben not sure where your habitat is in this world, but you can get them at yamaha or here
- rd350lc
New to a Tx 750
goldenE its a uk based site and we are out playing coz its weekend. I'm sure you'll get some replies soon!
New to board with 76 XS500C
there was a conversion doing the rounds which changed the oil filter to a larger one I beleive, maybe jim could shed a litle light on this?
is it a standard bike or modified?
My XS chop project
shaping up nicley, better pics would be good too!
Can't find any bits!
would this not fit? have to look at the airfilters to see if they will! http://www.cmsnl.com/yamaha-fzr400u-1988_model9365/partslist/
Eygpt Loves Jawa 350 Twins
that and your new uniform
Angels and Demonds
that added ending spoiled it for me was that the directors cut?
She Lives!!!
you can get petcock repair kits off ebay etc c/w new diaphram and seals. once you get that fixed, then see if the needle still leaks! drewps
Tragic accident
saw that today as well!! they just been to see a friend in hospital!
- Quiz
How not to clean a bike
bloody 'ell, worse than OG's Toe and that's saying summat!!
Stafford show 17th and 18th October 09
This is the international classic japanese bike show and its MASSIVE!! planning to ride out on either saturday or sunday depending on the weather. we normally go down via knutsford and stop off at little chef, stoke (near A500)for a brew and a bit of crumpet! then its filter riding near the stafford county showground as the roads are choked with punters. I usually set off about 8am and get to stafford 10ish with pre bought tickets as the queues can be rather long (it has got better over the last few years) if anyone wants to come along,your welcome but be prepared to walk a ways as this is a big show and takes 4 hours just to walk round!! http://www.classicbikeshows.com/
'81 XS400 electrical issues
nice one chris "current state" liked the pun with this charging system, you have to start out with a fully charged battery as this is needed to excite the field coil into a magnet which produces power for the battery!! the actual regulation of electricity that gets produced is done by either an electromechanical or electronic voltage regulator. this device sits between the battery and field coil. Its possible that the electromech one may need adjusting. electronic ones need replacing. you also have a rectifier; this goes from the stator where AC is produced and converts it to DC to charge the battery.these can also fail causing a big short! to test; you need a multimeter over the battery terminals and check that you have 13 - 14 volts @ 3k revs. there are other tests you can do for the regulator and rectifier which are in the download manuals at the top of this forum page. BTW to the forum drewps
- pieca pizza
tried yamaha? granby's motoward cmsnl
