drewpy
Everything posted by drewpy
  1. good photos, and a great day out, thanks!
  2. I'm jealous
  3. Hi
    drewpy replied to TheBat's topic in The Bar
    to the forum bat
  4. drewpy replied to Golden Eye's topic in Classics
    fouind a link to a stoty about the TX TX 750
  5. knowing my luck on a load of hells angels bikes
  6. what do the ones your looking at, look like?
  7. but you can't own those, this is for sale today!!
  8. half the link's missing!!
  9. No, its a bitch to remove, especially if you do infrequent lubes. there is an aftermarket bolt that has a 17mm head. you will need to coat the thread in copper slip when reattaching. the last one i did was to weld a larger nut over the head and the heat and greater leverage unscrewed the bugger. there is an O ring which will catch the cover when releasing, causing it to spin. drewps
  10. drewpy replied to bobbyhollie05's topic in General
    yes but it's different for certain classic/vintage bikes which depends on year of registration!! drewps
  11. drewpy replied to CadXS's topic in Classics
    drewps
  12. http://www.firebox.com/product/415/Moller-Skycar-M400?via=sfg please order one for me and leave at Manchester City airport! drewps
  13. including any sense of humour
  14. ha, the brakes can't hold the bike back
  15. drewpy replied to mervin's topic in Video Section
    I bet its too "deer" to buy, I "wooden" have enough money
  16. <object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  17. could be that it simply rusted in peace, is there no pinch bolts underneath? drewps
  18. you wil have to turn the key either was as one undoes the helmet lock and t'other the seat lock drewps
  19. "Up-yours" has 5 pairs of these <object width="560" height="340"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  20. lots of LOLZ <object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  21. don't watch if your squeemish <object width="560" height="340"><param name="movie" value="http://www.youtube.com/watch?v=56L6pdeRpq0&hl=en&fs=1&"></param><param'>http://www.youtube.com/watch?v=56L6pdeRpq0&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=56L6pdeRpq0&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
  22. drewpy replied to cegan09's topic in Classics
    you could try and cover the inside of the cones up. it is something to do with the diaphram air intake and the vortices of the air induction. try and see if you can use longer intake hoses between the cones and carbs as this is what I did on thew 400 flat-tracker! drewps
  23. at the top of this page maybe?
  24. green250 the electrical has been done to death in this forum, try a search ( more than 4 words)its usually a duff battery, or voltage regulator. the xs400 is identical to the 250 except for carbs, valve sizes and bore, so you can down load the manuals at the top of this page. ( its called xs400 links) clutch is really easy and the manual will show you how. if you have any probs come back to us drewps
  25. just recheck your connections and earth wire/s have you isolated the switches, they can be adjusted. You can manually pull the rear brake switch and see what happens and also bridge the two wires to switch to see if its the switch its self. All the wires do is complete a circuit! drewps
